Dr Stiffler SEC Replications?
Jamie
Yes indeed, as Xee2 says, there appears to be no limit and yet there must be. We find that when attaching more and more of the same devices. At a point, all devices will dim together. There's nothing wrong with extracting everything up to that point though to increase efficiency and that may be what you were thinking ?
A traditional way of thinking about it, is that the energy that is wirelessly transmitted brings thoughts on feeding it back around. However, ultimately, there's still going to be a small loss. The most efficient setup would have no LED's lit and so would just generally take longer to stop, without doing anything useful.
A non traditional viewpoint (and why a lot of us are still interested in especially Dr. Stiffler's setups) says that at a certain resonant frequency, with careful calibrations, the received energy can be in excess of the output energy.
Dr. Stiffler himself has shown the PSEC apparently doing exactly that !
Oh and, a pill bottle eh, a 'Walgreen' ?
Ah thanks. I know the 'Walgreen' isn't strictly Dr. Stiffler related...except in the fact that as an L3 they do work well on the SEC 18x circuit.
Mainly I just wanted to see it
Your Primary should be wound in one direction and the Secondary in the other..i'll bet that's the problem. Just swapping your connections to the Primary should fix it though.
Shoot for 850 turns and a Primary of 2 or 3 turns. You can put a conical Primary inside, or a simple couple of turns.
Walmart and Walgreen small pills bottles are of just about the same physical dimensions, the only difference is the style of the plastic for the lid to go on. Any plastic bottle of an inch or wider diameter will work, less than that and ferrite may be needed inside.
Here's what I mean, with drinking straws as the diameter: Straw Resonance - YouTube
The larger diameter version of the 'Walgreen' with the same height is what my 'Windsor' was made from. The 'Windsor' is more in keeping with Tesla's geometry, but the 'Walgreen' has an equal perfomance and is a tad smaller.
Here's what i've got away with using in past experiments
The Windsor with a very rough twirl internal Primary: The Windsor Tesla Tower, twirly rough L2 - YouTube
Bashar/Russell internal coil: Bashar Tesla Windsor trial run - YouTube
Levitating toy car with working lights, scruffy conical internal coil: Flying with lights on - Mattel DeLorean - YouTube
1.2V Walgreen, twirly conical large internal coil (shown at end): 'Penny' at 1.2V - High Voltage - YouTube
'W' in keeping with Wardenclyffe
Your LED is reducing the Vce voltage across the transistor by 2 or more volts. That means you have less than 4 volts for Vce. I think it is better to put LED on base. Also, if you can get a 1K variable resistor you may be able to tune for better performance.Originally posted by jamesgsnelson View PostAny suggestions are welcome.
SEC replications
Hello, I have been keeping up with Dr. Stifflers work for the past year or so. I have replicated everything other than his PSEC. One thing I did notice was some activity on my spectrum analyzer (indeed a harmonic excitation of some kind) without any current being pulled from my battery. I was even able to light up LEDS wirelessly around the excited coils without the circuit running...or tuning LED being on I should say. This would only happen at certain sharp tuning right around the 13.4 Mhz Range. I will post some pictures of it soon. The effect was real, however the amount of power available was very little and any attempt to start another SEC from the power would either start the circuit into oscillation or kill the oscillation. Also, from my understanding a PSEC is a hard replication to do, due to his "proprietry" transistor making his circuits much more able to do so. I am using the MPSA06 's. I have made a couple circuits with diodes instead of transistors in the model of his PSEC's with diodes instead of transistors. These however I have only turned on by excitation from another SEC. I can post pictures of that as well. I think now is a good time to dive into the theory and start applying it.
The joule theif circuits are neat with the wireless electricity thing, but seemed to me no way applicable towards what Dr. Stiffler is doing, or trying to show us....
Also, did anyone of you guys catch the dr's "new diode electrolysis # 10" its not up anymore, and I didnt copy it, but if anyone did please share. It showed his setup with the battery running through the water and the SEC stimulating the water while charging the battery and making lots and lots of hydrogen. Not sure what the standing voltage was, but if it was pulling current it was pulling 40 ma and making a whole lot more hydrogen than usual, enough to run a flame consistently. Im disappointed it wasn't up longer. This however does not mean we should be giving up or looking into joule thief circuits. For those of you that are still working on Dr. Stiffler's work, dont give up, im right there with you!
Best of luck
SEC frequency
yes! I believe with proper energy recovery, a battery can maintain a charge at the same time using the slosh of current and voltage to do usable work. Say you vibrate water, causing it to separate with SEC excitation, while recovering the energy it took to cause that vibration and put it back into the battery? the result would be hydrogen and oxygen and a steady charged battery. This is just what has been going through my head lately, a hunch. The frequencies you could apply it to would be limitless.
Warren
13.4Mhz - check
Excitation into self oscillation - check
Sharp tuning - check
MPSA06 - not sure
Inherent to Dr. Stiffler's approach has seemed to be the reported Negistor properties of a few transistors. 2N2222A, 2N3904, 2N4401. Now, weirdly enough, they are the 3 in a pack of 5 each that can be bought at Radio Shack !
Why ? i've never worked that one out and so it raises some thoughts. A clever disinfo, correct and RS bundled them because of that trait, or maybe it's just how it goes as a fluke.
However, didn't the Dr. ship SEC18X's with MPSA06's ?
Would like all that clarified, as well as my memory of him having a 2N2222A in a PSEC without the Base leg connected.
Would also like to see some pics of your setup
Yes indeed, the inductive exciters aren't the same, it's a different form of wireless transfer. Such systems are a great intro though to the importance of tuning, applications of build skills and familiarity with the tolerances and uses of related components.
JonnyDavro's huge Joule Thief exciter thread is the better place for some of the circuits, but the relevance is there for this one
I saw the experiments with the battery and the electrolysis...especially of note was the zero amperage video. He said there was a small margin of error within a milliamp for his test equipment. Whatever the error, that was a very low input if it wasn't completely nothing !
Your results are confirming many wondered aspects
@Jamie - Another heatsink option is to take some aluminium sheet and bend it tightly around the transistor, with a small amount hanging off to one side as the escape route for the heat. Your copper penny is fine though, can superglue it. I've used hotglue before now...if the glue melts then the transistor is heating up.
Or, in fact, bring the Slayer Exciter more in line with Dr. Stiffler's circuits. Run 2x diodes and an LED to the Base. Xee2 is right if connected to the Emitter, you'd just drop input voltage.
Anything to do with heat is always waste...so the best thing is to drop the need for heatsinks or indeed resistors performing the same job as a mini electric cooker ring lol
I see you have a 1K resistor, that should be around 24K, otherwise to much current is going into the Base, hence heat. Too high and output will drop.
Your Walgreen should be wound with approx 38 gauge wire, single layer. I get mine from old Mabuchi 3V cassette player motors. 850 turns and 2 or 3 turns of the wire you have there for your Primary will be fine. From that, you should see plasma at 6V.
As a first go and introduction circuit it's done you well...CFL lighting is a good step forward, if indeed only via the induction.
Have subscribed to your channel
PSEC replication?
Thanks for the warm welcome!
Here is a video of some of the work I have done.
Dr. Stiffler SEC replication with PSEC - YouTube
First of all, I built myself a little coil table where I can experiment with the excitation of the coils. I am driving the middle coil as the L3 and have a capacitor hooked up between the L3 and the metal plate on the bottom. This allows me to adjust the capacitance between the coils and the plate. When I tune the circuit it will go in and out of oscillation switching on and off. At a certain point, the circuit turns off, but is still giving an output. The output is only there when the PSEC is hooked up to the coils. The PSEC seems to be stimulated by the driver circuit, even though it is off. Later on I tried disconnecting the center coil from the driver circuit and it still works. The PSEC is no longer attached to the driver circuit in any way. It is being stimulated into excitation by the non oscillating circuit hooked up to the solar panel. My question is now, could the solar panel and driver circuit be acting as a parametric circuit oscillating with the environment thus stimulating the coils enough for the PSEC to start running and exchanging additional energy? I will keep any updates posted, but I feel I am close to a true PSEC replication with only a ground or wire to act as an antenna/counterpoise. Let me know what you think. I will post another video in a couple days that is more organized once I get some time to experiment a little more. This is the first time I have noticed the output only stays on if I have a PSEC hooked up the the coils which are being excited. Very close to what Dr. Stiffler shows in his PSEC replication videos.
Warren
