This thread is to explore the problems in achieving an LC circuit to power a motor. It relates to AC and DC motors as a method to produce an overunity motor.
With an LC circuit we can create an oscillation in a coil whose magnitude is bigger than the supply, that is the energy in watts oscillating in the LC circuit is bigger than the watts sustaining it from a source.
Why is this important? it is because the magnetic force produced by a coil is proportional to the ampere turns of the coil and therefore torque produced by a motor.
We can have, for example, 20 amps oscillating in a coil with a supply being only a tiny fraction of that to cover the losses. Nothing new here, just stating a fact. This single fact tells us that an AC overunity motor is possible if the AC is in an LC circuit with the motor as the inductor.
The problem begins when we introduce further losses by giving the coil an iron core. In a motor we may only have 5% losses in the coil due to ohms law but the motor may have up to 80% losses in all.
The other losses consist of friction, cogging depending upon the motor and iron losses etc.
Our other problem is the frequency of the oscillation, the mains frequency gives us around 1500RPM in a 4 pole motor but the resonant frequency of that motor may be in the kHz range requiring an induction motor speed of enormous magnitude making it impossible to reach. Let us assume we can get our hands on a motor with enough poles to slow the motor down to a reasonable speed, or we use a Universal motor. Now we only have to consider the iron losses.
I have been running some tests on a Universal motor using DC, Pulsed DC and AC. I don't have accurate measurements of the efficiencies but it is obvious that the universal motor performs best on DC for a given voltage and amperage. I believe it is the iron losses that is the cause of this.
As we need AC or pulsed DC to create a resonant circuit we are fighting the iron losses.
Do any of you have any knowledge on this subject as this is the problem I am trying to overcome at the moment.
