Global Energy balance essential?Inject some Knowledge and wisdom please!
Hmmm sounds like the plot of a movie to me.
Ill take it seriously though and give you my thoughts.
If we are drawing energy from the aether in sufficient amounts I do believe it can have local effects on the environment and us, so if this was much larger the effects could be on a more massive scale, so this part makes sense. I agree that there may be implications to drawing aetheric energy as a source of power.
As a way to manipulate weather the description seems to make sense on the surface but from what I understand it is probably not possible that way, although it is a fact that the weather can and is being manipulated.
Obviously I cannot comment on the authors "system" and prototypes as they are unknown to me.
2012, the galactic alignment and numerology, hmmm, just imagine if we changed the date on our calender then the significance of numerology has gone.
As far as I am aware we have not been able to detect any significant changes with other alignments, lets face it that huge white thing in the sky does not have hugely significant effects upon plate tectonics when it is lined up with the sun during solar eclipses and that is very close to us. so this argument is weak.
The effect on the heliosphere isn't something I know much about but again I think the planets will have little effect on it. I would be far more concerned about the effects of solar flares during the more active parts of the sun cycle which it is now entering. This is something we know effects weather and plate tectonics etc.
From the data collected it seems likely that the earths magnetic field is changing and more rapidly than it has for a long time. A sudden collapse is not likely although changes in polarity and field strength are. The last data I looked at showed the earth currently has many poles, some getting weaker and some stronger and moving also. This hasn't caused any major events although has caused some compass adjustment on aircraft. The earths magnetic field will not disappear, firstly because even if the earths core lost its magnetism the crust has its magnetism locked in. and second we are already seeing how this change happens and it is a more gradual affair.
We are vulnerable to CME events, we always have been, and as I said before we are entering a period where they are more frequent and powerful.
The EMP effect, yes it is possible.
Crustal displacement, isn't pole shift although pole shift could cause crustal displacement to some degree.
We can expect earthquakes, volcanic eruptions, and tidal waves on a global scale, we always have. There will be some bigger ones than we have experienced in recent history and this is part of the earth and suns natural cycles.
For all this to happen at once on a given date, unlikely.
There is one other point not in this text. There is mounting evidence that some militaries are experimenting with tectonic weapons and the US military in particular.
There is something I would like to add, Fukushima is the biggest environmental disaster ever caused by man and it isn't over yet and wont be for a long long time. It is changing the world and life on it, I think this and the global bankster agenda are the things we should be taking action on now.
According to my intuition the second level device which I call them , operating like lightning are draining air from ions. They are not bad but must have been limited to lower then 100kW per place or they will disturb weather.
That's because they are operating on second level or an additional energy spread. Just my intuition.
I would not be surprised if Earth change rotation direction with pole shift. I will describe why : science is telling us that Earth magnetic field is weak but this is not so. It couldn't be resisting cosmic rays and solar flames if it was weak.Thus so it can't be created from internal dynamo without external power source. It is out of possibility of Earth core and a rotation inherited from the time of Earth creation to sustain that strong field. Earth is only a small iron ball propelled by currents from cosmos. Most probably from center of our galactic, but I have too low data and knowledge to identify the correct source.
Solar storms are almost sure and most probably they would wipe out every electronics.That's true unfortunately, we can live with that, hardly but we can. However if Earth change rotation or our solar system flip in space it will be disaster comparable to extinction ...
Hi all, I might be wrong but this sounds like the inventor of a big round yellow
transformer that uses a word meaning six controller.
Who has no way of knowing any of those things for sure, certainly not by
collecting data from his Toroid transformer builds around the world
(Device users). He claims his setup can cause tropical storms and
induce lightning strikes. I don't buy it, I don't even think his system is OU,
there is no over cop 1 demonstration of one of the setups that I know of. If
there is I would like to see it.
My understanding of "pole shift" is that it is happening all the time. However a pole
reversal is possible and has probably happened before. A pole reversal would
actually see the earth flip upside down relative to how it was before.
He goes from talking up his transformer saying it can be tuned to a weapon,
which to me sounds totally rediculous, to talking about galactic alignment.
The transformers put out about 60 to 80 volts AC and they require a power
source, I see no reason to suspect over cop 1 with the system, but I am
willing to change my mind if a over cop 1 demo is shown to me.
Thinking that he can deduce future events from the data collected form his
controllers appears to be delusional. Sounds like wishful thinking to me.
People shouldn't panic, a pole reversal is not caused by humans and is
unavoidable. My plan is to take shelter undergound if it happens. What else
could we do.
You really shouldn't be posting peoples personal emails without permission
Duncan. It's not difficult to tell who it is talking. I know. I received the same
kind of email snippet from a third party too.
CheersLast edited by Farmhand; 12-05-2011, 05:04 AM.
Fukushima is in China syndrome in at least two reactors, the workers there have blogged about it and they have said that nothing is being done to prevent it. what's the problem there? when the core reaches the water table, BANG
Back to the topic, there is much in the article that has a ring of truth but it seems like new ageist propaganda to me by combining all possibilities in one event. Remember the bankster w*nksters want us in fear so that we will obay.
boguslaw has the power level that I think Tesla quoted for effecting weather, at HAARP they have admitted to doing this and there are many such sites around the world. There is chemtrailing or geoengineering, as they now admit they call it, going on so I would not be surprised to find out that not all weather events are normal. The same goes for tectonic events.
Radiant devices can have an effect on mood, sleep and thought patterns too, as can other things when tuned to certain frequencies. Even physiological effects can be made.
For once I will have a tini disagreement with Farmhand, It has been noted that small changes in performance can be detected in radiant devices near the time of big earthquakes and similar events, some of which are in advance.
The B/Wsters are in to numerology so it would not surprise me if the tried to engineer such an event at a significant date (to them). So if something does start to happen around that date you can bet it was planned that way and has nothing to do with the existence god or anything else for that matter. Anything else is pure coincidence.
We had a huge earthquake in Haiti at the same time as tectonic weapons were being tested several hundred miles away. We had the huge earthquake at Christmas a few years ago and we had the Japanese earthquake. It has been claimed that HAARP was in full activity at the time of all these events. Is that true? I don't know but my mind remains open either way.
What I do know is the pattern of earthquakes around the ring of fire is suggesting another big quake is coming either on the American coastline or the Philippines. This plate has relieved stress in New Zealand and Japan and a third side will have to go to equalize out the pressures on that plate. Now there is a prediction for you based on common sense. Of course this is assuming that the Christmas earthquake was not a part of the same event.
I actually agree that haarp and other facilities are capable of altering things.
I think that's what they are designed for. I don't dispute that part at all.
I wouldn't like to speculate on all the possibilities. I can only wonder. Chemtrails
would seem to be very real too and are probably related to the operation of the
other facilities maybe. Just look at the ridiculous floods in Queensland, Aus
last year, it rained for months on end, nearly washed away whole towns. I've
got a few years on me and I've never seen that before. Not rain that heavy
for so long. And the water seemed kind of thicker than normal too, very
strange, maybe that core-exit stuff they used on the oil spill. Rainwater tanks
turned black inside and water went foul too. Very strange. had to clean em out.
Never seen that before either. So yes I am as concerned as anyone. Maybe it's
all a coincidence but I doubt it.
pole reversal, etc...
Every power "source" is already tapping the aether. That is where all
the potential comes from anyway. I don't see a connection between the
largest power stations on the planet and goofy weather. Those gigantic
dynamos, etc... aren't generating electricity - they establish potential
differences that tap the aether. When Bearden says power plants don't
contribute 1 watt to the grid, I believe he is right.
I am more inclined to believe our collective conscious has a stronger
effect on the weather than believing that "overunity" machines will
change the weather - when normal machines already tap the aether.
There are various technologies that can effect weather but not
because they tap the aether, it is what they do with the aether.
Like mbrown said, there are multiple poles (small ones) and they are
moving. This has been tracked for many years. There was a great
documentary on PBS or the Discovery channel over 10 years ago on
this. Those multiple poles will little by little start springing up all over
the place and the major N/S will get weaker and the whole field (overall)
is very disturbed and unorganized. And little by little smaller poles join
to make bigger ones and suddenly S is now N and N is now S. The earth's
geometry stays the same, just the magnetic field reverses. There could
be wild winds, tsunamis, etc... and other catastrophes but we really don't
know how it will play out. But the pole reversals have absolutely happened
in the past. Approximately every so many years the magnetic polarity in
various layers of soil have been found to alternate back and forth
periodically.
From the Federal Government website:
Defense.gov News Transcript: DoD News Briefing: Secretary of Defense William S. Cohen
"Others are engaging even in an eco- type of terrorism whereby they can alter the climate, set off earthquakes, volcanoes remotely through the use of electromagnetic waves. "Sincerely,
