  • Originally posted by machinealive View Post
    I have a feeling Dana has already used this code, and it works, just a hunch. I'll still wait to make sure.
    I agree with you here Machine....sometimes Science is like that...beyond all logic...We "assume" -based on our limited knowledge- something is never gonna work like that...and it happens all the contrary, it is a Great Success...then we find new reasons why it did worked out...
    Just "Hang in There" till Dana tells You...unless you want to "Unleash Your FET's Serial Killer Syndrome"...and destroy them All!!...once and for all!!...
    Warm regards..
    • Wow, a guy takes a day to pour sidewalks and all heck breaks open. A few weeks ago, when Garry first mentioned this idea I really tried to see how it would work in our system even though this methiod of pulsing is standard in Arduino. I mentioned several times it might not work but after checking it out further, saw that it would work. At this point I will say that if JohnStone said no go then I will go back to previous pulses. I have run this system on several motors and believe that the outcome is the same. As to fet killers, maybe my boards are magic but I see no problem at this point. My boards are just beefed up with vary heavy lines to diodes so as to draw spikes off the fets.
      Here is a link to see the pulse in a pulse.
      If anyone is at this point unsure about this different code, use the previous code until JS has checked it out fully. It does work and motor runs much smoother although I did not check amps on Imperial but on the 4x long motor I showed earlier the amps were down. I will do whatever UFO and JS wants with this issue.
      Dana
      Nikola Tesla
      • Hey guys
        Dana i'll give the new program a try, if you tried it and it works. You seemed confident in this program, before reading the last several posts. Some friends just left, and I'm pretty tired, that was a long week, but I may go try it now, it's all set up at 12 v.
        • I like plurality including your PWM approach Garry. Any attempt gives lots of information and often guids us to solutions we never have thought of. That is a very neat kind of taking options and convert them to success. The high grade is to cherry pick later on those elemts being proved to be successful.
          My concern is to have one Arduino setup with simple pulses in order to have the opportunity to run in our pulsers with simple pulse shape. Once they are known to function heavy duty we can go for complex pulsing of any kind. But with complex pulsing at very start some of us will not detect basic errors in the setup. I feel it to be important to support very beginners.
          The original UFO pulsing gives the opportunity to study cerain effects that might be essential:
          • Release the radiant event at a predefined timing.
          • If that effect holds true we need to play with voltage later on in order to shut off a predefined current at predefined time - at any rpm.
          • It might be important to concentrate the current increase to certain area of max torque
          And it might be essential to detect some additional artifacts in PWM scattered pulsing.
          Just now we are mostly in the realm of ISDN (I Still Don't Know). Let's cherry pick later on but before let's add to our reports what type of pulsing was applied.
          JS
          • QuadPulserConstruction.PDF
            Hello All
            I have created a PDF file showing pictures of my QuadPulser and closeups of important views.
            This is a downloadable PDF file.
            Dana
            Nikola Tesla
            • Still working on Site...
              Hello to All,
              I am still working on the site...and below, is a Direct Link to View On Line, the latest release of the Monster Pulser pdf...That was as per your post on other thread, Dana...
              VIEWER/MONSTER PULSER
              And here it is a link to be Downloaded
              Press on " Download File"
              The pdf file is not small...and I do not have a Private Server...so, it may take a while if too many hits, to fully download...so be patient.
              Let me know if it works ok.
              • Originally posted by prochiro View Post
                Hello All
                Dana
                Looks fine. Some small details are somewhat different from mine setup but if it works - OK.
                From what source do you feed the driver? Battery or other source?
                Is it really -18V or do you refer to GND of 18V power source.
                KS
                • Hi guys
                  Well, no blown fets, but... First I tried the original program 12 v, 3 neons lit instantly across ds, constant, and intense. So then I tried the new program 12 v, way less severe spikes and less often, but still, 3 neons lit. No rotation. I like the second program better. I'm done until my mercury switches arrive.
                  I don't know what else to due.
                  Machine
                  • @ Machine
                    While reading your last post a question came to me. Are you using the neons at the same time you are trying to run Imperial, if so that will not work. The neons are only a test to check out circuit. I am sure you know that but just a hunch. If you will PM your address I will send you a fet board that will turn your motor.
                    Dana
                    Nikola Tesla
                      Hi guys
                      Machine
                      That's why we need a plurality of attempts. In the end we need to know what approach fosters motor turning the best.
                      1. Availability of radiant energy without any timing requirements -> pulse packets
                      2. Availability of radiant with precise timing for radiant release -> well positioned single pulse
                      @ALL: For run in of setups please start with low duty cycle (approach 1. or 2.) and increase it gently while observing spikes and heat . If any abnormal effects do not increase load or duty - search for reason first.
                      JS
                      • Hello JohnS
                        You asked about driver voltage. I use one 12V and one 6V battery. Not sure where you got -18, maybe one of my diagrams labeled too closely to another label.
                        Dana
                        Nikola Tesla
                          Hello JohnS
                          Dana
                          One of your real photographs shows +18 and -18 labels.
                          These two batteries are in series. Do they power driver AND load at same time?
                          @ALL: I still wonder on why those dead FETs occure. There MUST be a understandable reason. I would like all setups to start with drivers powerd separately (i.e. simple socket charger) in order to get effects separated. In research state it is not necessary to operate with one single battery like in later practical applications.
                          JS
                          • Hi Dana
                            The neons were for testing, but like before, if I went to 24 v, we'd have a BBQ. I'm going to play with it a little more tonight, I never used gate resistors up to 50 ohms, maybe that would help. I just want to try relays before I start risking fets. They'll probably be here today or tomorrow.
                            @John, I'll make a vid today of the two programs running at 12 v, so you can pick which program you think works best. On pulse packets, neons flickered at increased duty, but still, over 300 v spikes at 12 v.
                            I'm on my way to work, Dana I'll send you my pm today after work, I appreciate your offer,
                            Machine
                            • Hi JohnS
                              I use three separate power sources. 12 to 60V for Imperial, 18V for pulse driver, these share common negative. The third source is ether computer or 5V plugin transformer. No common ground there.
                              Dana
                              Nikola Tesla
                              • @Midaztouch
                                I respect what you have posted and have found that any prefabbed board will have the same problem. The reason I say this is that you can not get the protection we desire thru just thin copper leads as they are covered with protected coating. Etching a board is so easy and takes thirty minutes and can be piled high with solder. It also is the cheapest board you can get. Give it a try and see. All my boards are now etched.
                                Dana
                                Nikola Tesla
