3 Battery Generating System
This topic is closed.
  • Originally posted by tachyoncatcher View Post
    My 3BGS thread friends. You are engaging in troll chatter. A teenage ego in and old man body. That falls under "whatever". Instead of reading, build. I did! Dave and Matt have nailed this one. What we have here is real power. Not the kind you get with buzzing circuits and leds, but the kind you get with gas powered generators. Only no engine! I am blown away! I have spent thousands on Bedini tech and understanding it. I spent less than 50 bucks on this. Get busy. You won't regret it.
    Good Luck,
    Randy
    No its none of that. See The PUTTS is over here to get people fired up. He knows whats going to happen when he shows his ego off. This why its important to confront him. He makes a point of not allowing people to research the way the feel best doing it he must have piece of it. He must inject his spaced out science into the answer. Its narcissism at its sickest. He is upset because he does not have any success. He would rather threaten to have me removed then to just leave well enough alone and go away. (Oh and good luck with that PUTTS)
    Its a shame really, he is sick in the head and so obvious to anybody who thinks for themselves. He just wants his little cult following to call him wonderful (Ring a Bell). Right now most of those people are dwindling. Alot of competition in that cult thing.
    You need to make film and show that success!!!
    Matt
    • Let him just go away
      Hi guys, can I suggest we just let the goof ball go back to his thread. He apparently wasn't getting his ego stroked enough over there so he came here looking to start trouble so he would have something to cry about. If you just ignore him and his silly gibberish he will go away. After all these months so far all he has proved that you can rewind a motor to make it use more current. Not a shining example of free energy I would say. So anyway just ignore him and he will soon be gone like so many others we have seen over the past few years.
      Respectfully to my peers,
      Carroll
      • There's the Cavalry!!!
        • Our whole purpose here was to show a very simple circuit that anyone could put together (if they had the parts) and produce positive results BEFORE they started spending money. My first build I used old batteries that were laying around in a couple different garages and the motor from a hot wheels toy that had been broken. I soon upgraded to a larger motor but essentially everything I got was for free. That setup made of junk produced unlimited power.
          I too have spent thousands of dollars on the pursuit of "free" energy. It is far from free. It has cost me five years of my life and a whole lot of hard earned cash.
          But it's worth it. I got an email today of someone using the 3BGS to charge up six dead batteries. During the time the batteries were charging up, he was running the motor and another motor as a generator powering a small light as a load. And during the time it took to charge his batteries, one primary remained level and the other gained 1/10 of a volt.
          So lets see, thats charging three batteries for each of the primaries, plus running the inverter, plus running the generator with load, and oh yeah, using ZERO power to do it. I keep trying to get folks to understand that it may only be 12 volts of power...just enough to run the inverter, but you can run loads off that inverter AND get the work of the motor for FREEEEEEEEEE and it doesn't drain the primaries. That is the potential of this setup. I have seen it. Others have too. Do you REALLY think we are going away???!!!!!
          • Not Quite
            I'm not sure, but didn't you forget the pulse motor? Wouldn't that have to run the generator at a loss?
            _
            • this is an interesting thread, I am still making my way through it. It seems to have a lot of replications, which adds to the credibility, IMO.
              I may have to try this. I wonder if we could figure out a way to charge a bank of 12 volts with this? I have a solar powered home, so that would be really good, if I could keep my battery bank full with something like this.
              Also, do the 3 batteries need to be about the same size, like amp-hour ratings? I have several good lead acid solar batteries, and an older, drained car battery. Could I make it work with those together?
              • Originally posted by velacreations View Post
                One replication that was just done (We're waiting on movie or something from him) he charged 6 batteries the same size as his primaries.
                Not all dead batteries work. You need an AGM. They so far show the best results. Not to say something else won't but it been our experience they work the best.
                We are currently looking into coming out with a better recipe for success from the word go but feel free to try what ever you. So far we have had 8 confirmed replications.
                Matt
                  Matt
                  I will look for that, thanks. I am still reading through the thread.
                  I don't think I have any AGMs, but I will look around. It seems like some people have had luck with lead acids. I have some sealed lead acids I can try.
                  • velacreations,
                    I have charged a bank of batteries of different sizes when I was running my original setup, They ranged from 3.5 amp hour to over 30 amp hours. I basically took every battery I could get my hands on and wired them in parallel to battery 3. It is not something anyone here has replicated that I know of, but definitely something I want to try again. I was just thinking last night that I have about 25 batteries of all different sizes, some that are good and some that are not and it would be interesting to put them all in parallel with battery 3 and see what happens. I think I will give that a try today and will let you know the results.
                    All kinds of batteries and motors give you different rests. We are finding that some work better than others and are just trying to give everyone the info so they can have the MOST successful experience. Everybody should have SOME degree of success no matter WHAT they use.
                    • thanks, Turion.
                      has anyone figured out how to run to run continuously and/or charge the primaries?
                        thanks, Turion.
                        Most Sealed Lead Acid, Or spill proof Lead acid batteries are AGM's.
                        Matt
                        • You can run for as long as you can keep battery three from charging up to a certain voltage. Beyond that voltage it won't work. With some systems it is minutes....with some it is hours or days. My original setup went several weeks before I took it apart and it never worked again...although new discoveries have shown me that had I just reversed the wires on the motor at the time, it might have continued to work. It all depends on matching your battery 3 with your motor and balancing the loads (see post one). We are getting increasingly long run times from different things we are doing with batteries, and believe we may soon have this problem solved. When we solve it, it's all over but the celebrating, which will go on for decades.
                          • any progress on replacing battery 3 with something else to be able to control the process?
                            • That is what we are ALL working on and the reason for the existence of this thread in the first place. We're trying all kinds of different things Some of them seem to work, like MJN's salt battery, but nobody else has replicated his success. Or at least nobody has REPORTED replicating his success. So until we have a verified solution, we keep looking. I got the stuff to make salt batteries per MJN, but just got home from a trip and am still getting my house in order.
                              It may take me a day or to to get to it.
                              That's kinda the way of it right now.
                              • Hi Dave and all,
                                I have made a small attempt in replicating your setup a few months ago, didn't have a good batt 3 candidate though... and then I got cought up in other projects I'm working on.
                                I still follow this interesting thread, there has been mention of caps instead of batt 3 from time to time so I apologize if this has already been discussed, but since the problem seems to be that the bad batts become good batts my question is, whenever you had a system working as it should, have you ever tried replacing batt 3 with a cap readjusting (if necessary) the loads so that all voltages across the motor and the cap are the same as when running with batt 3?
                                regards,
                                Mario
