3 Battery Generating System
This topic is closed.
Duncan,
I'll grab one of these extra motors and get it mailed out. I believe I have your mailing address somewhere back in an old email but you might send it to me again. I'll strip the motor of copper wire and that will save me a penny or two by cutting the weight in half. The you can use the wire from Kerry and wind it up and we won't have to wait for my order of wire to get here.
grant romundt real free energy alternative - YouTubeOriginally posted by penno64 View Post@Duncan, spend 5 minutes and see the similarities, Penno
Thanks for taking the time to research and post it however .. Its all going in the stew and every bit of information helps
Most kind!
Tis done David!Originally posted by Turion View PostDuncan,
Testing issues...
Greetings:
My testing has been done using FLABs @ 200AH for the primaries and the SLAB as the dead battery. The dead battery is a 17AH, or there abouts....
So, for this weekend, we'll hook up a bad 6 volt 200AH wet cell for the bad battery and use wet cells as the good. There should also be enough sealed batteries around to make a setup of that type for testing.
We'll see how this goes...(and have a good time watching!)
glen
OK,
Got one setup up and running with 2 FLA's as primaries and a bad FLA in the third battery position. The motor would not start when I started the setup, and would not allow the motor to start even when spun by hand. After about 10 minutes I was able to get the motor to start when I spun it by hand. I have recorded beginning voltages on a video and will post that if anything exciting happens. I assume it will take several runs of many hours with resting in between and the bad battery shorted out before I begin to see what I want to see, but I will keep you all informed. I have a .5 amp 12 volt electric fan running as a load on battery 3 right now, (an analogue amp gauge is in the circuit) but no load on the motor.
I have enough stuff to put together a second test circuit (including a second pulse motor) and will be doing that tomorrow. I have a battery that has a loose post, so I will trade that core in on a new battery tomorrow. I have several bad FLA batteries that are reading less than 5 volts, and one that is sitting at .87, so I will try that. I will probably try all of them and any that prove unsuccessful I will just convert over to alum. I have everything to do that with.
DaveLast edited by Turion; 01-23-2013, 05:34 PM.
crazy idea???
Hi all,
I found this video. Maybe can be used here as an experiment to substitute bad battery?
May 8, 2012 8:06 PM - YouTube
A copper plate is inserted between two batteries for a capacitive coupling. The other end of the wire from the plate is connected to the can of HV capacitor, forming a captret. The regular connectors of the capacitor go in the circuit.
Hopefully, whatever the battery magic will work with what we are trying to do in this thread.
tishatang
bad battery theory?
Hi Dave and all,
I found what may be a clue about batteries and extra energy. Maybe it will help to create a good bad battery?
In the last page of the Eric Dollard thread is listed a Bulgarian site with a download for a cosmic collector. The download is in English. Click on download button on right.
On page 20 is mentioned the coil (cosmic collector) and an ECM (brushless DC motor). Here is the quote from that page.
"The coil is being charged independently of the motor being run. The motor running is an effect on the moving frequencies through the coil and will run indefinitely without using any power from the battery. The battery is merely sitting in this dimension and nothing is happening or draining. In the 4th dimension it has created a magnet attracting the higher dimensional higher frequency energies. Hence we are pushing frequencies through the coil. Pushing frequencies through a fractal shape yields such results as a magnetic vortex to where when the surface of the coil interacts with the
higher dimensional energy it funnels that energy towards it. It literally opens a hole in our dimension that sucks the energy into itself.
When you reduce the voltage via an ECM you increase the current"
The article talks about the use of teflon. Maybe a capacitor made up of sheets of copper and teflon will make a capacitor equal to a good bad battery?
Chris
The Cosmic Collector
Hi tachyoncatcher,Originally posted by tachyoncatcher View PostChris,
The link take us to a 404 page. (Page Unknown).
Randy
Maybe this will help:
The Cosmic Collector - 34 page pdf
IndianaBoys
BS
Thanks IndianaBoys,
However, when I see "plans" for devices like that without actual photos, I have a hard time not putting it in the BS category. As you know, this forum is loaded with device plans that fail to work as promised. The promises made in that pdf are..... fairy tale like. Builder beware.
<<Edit>> Ok, I see this device has been covered, in this forum at an earlier time, as hog wash. My instincts were right on. <<Edit>>
Randy
if you want people to believe a lie, tell them a really big lie.
TachyonCatcher,Originally posted by tachyoncatcher View PostThanks IndianaBoys,
Randy
This was posted last night on RickOff's thread:
Hi All,
I did not post expecting everyone to build this device. I thought the explanation of the battery causing a magnetic portal in the 4th dimension is as good as any other theory to explain excess energy.
Just because something seems like BS, does not mean that everything is false. Even disinfo contains elements of truth to be accepted. Look at individual parts and ask yourself, is this true?
Is it true a battery has an internal resonance of 1 to 6 Mhz?
Can an ECM motor convert voltage and amps?
I do not know the answers to these questions. If this is true, what else is true in the article?
He mentions the coil getting cold. As I recall in this thread, one experimenter got a cold battery.
My simple mind is saying to me:
If a bad battery gets sulphated and acts as a crystal, then use it as in a crystal radio circuit. Find the resonance of the battery and build a tank circuit to tune to this resonant frequency just like a radio. Maybe a tank circuit will stabilize the rpm of the brush motor to the right frequency?
Try using an aerial and/or a ground in your 3 battery setup to help trap these ambient frequencies.
Not everyone has the money to build this device in this article even if true.
The beauty of this thread is most everyone has bad batteries and old motors laying around. I am not in a position to be an experimenter right now. I have all the stuff. But I am 76 years old and it is a cold winter and very cold in my unheated shop. Maybe this summer?
I am posting here in the hopes that ideas tossed around can lead to solutions for the benefit of everyone. I am trying to think positive, not negative.
Tishatang
