Balance???
What if the thing that makes this work is NOT a potential difference between the higher voltage in the source batteries and the lower voltage in the bad batteries, but a potential difference between "positive charged batteries" and "negative charged batteries." Think about that for just a minute.
After all, I know for a fact, and so do many of you, that the bad battery actually flips polarity. and WHILE IT IS FLIPPED, that is when the magic happens. Now, that means that perhaps if we could get a battery to STAY flipped, we could run this thing forever. And maybe a lower voltage bad battery has a greater potential difference than a higher voltage bad battery (when they flip polarity) in relation to the two fully charged good batteries
So lets talk about that for a minute. OBVIOUSLY there is a source of reversed or negative energy hitting that bad battery that causes it to flip, but once it does there is also a source of energy that is great enough to get it to flip BACK to the original. What if those two sources of energy could be isolated from each other and/or isolated from the bad battery? If it is the motor that causes the battery to flip, then we need a different circuit when that happens. Maybe we run it off one bad battery until it flips negative and keep it running there, but the minute it flips positive again, we switch to a second bad battery. Something like that. Alternating between the two.
I have had a battery hooked up to a motor as generator for four days now, trying to create a negative transducer. It reads just short of -12 volts, but as soon as I disconnect the motor, the negative voltage in the battery starts dropping. Why is that? What makes that battery WANT to go positive, and where does that energy go that is showing up as almost -12 volts in the battery right now? It seems to want to settle at about -7 volts, and I can't get it to go any higher than about -11.78 on the negative side.
Until one can explain the process of how to transfer aether energy from one form (the kind we can't measure) to the form we currently use, we are but blind monkeys poking sticks at termites in the dark. I don't know about you guys, but I'm getting darn hungry for answers we can use in a practical way. Riddles do little for my sense of scientific attainment or understanding. This 3BGS conversation needs a refresher of what brought us here in the first place. Go back to post one. Lots of unexplained, translated power from somewhere other than the good batteries. Everthing else, is just a diversion or belongs on another thread.
