3 Battery Generating System
This topic is closed.
  • Yes it works!
    I had a few minutes last night to try Matt's circuit. I didn't have a 100 ohm 1/2 watt resistor so I decided to try a pot instead. With a pot in place of the 100 ohm resistor you now have a speed control for the motor. The only problem with that is if you are not real careful tuning you will let the magic smoke out of your transistor. I let it out of 2 of them last night. When I have some more time I will put together a mosfet circuit as I agree I think that will work fine. I was just playing around last night. So it looks like Matt has done it again. Congratulations Matt!
    I think we could also use a control circuit like a Pic or even a 555 circuit to control the transistor and maybe get some more interesting effects. With the Pic or any of the other small microprocessors we could maybe make the tuning automatic.
    Carroll
      Carroll
      Thanks Carroll
      I do have a little bad news to report. Under a 5 hour test which was started in the video I lost about .15 of a volt out of both batteries.
      The resistors were getting hot so I think that is were it went. Not a loss from the motor. And not having the switch in place caused this.
      We might could get around this....
      I do have an idea. Maybe NOT use the resistor and use 2 diodes one to collect the ground and one to collect the positive. Both the diodes will deposit into the correct pole of the battery. You do not want to use a Ultrafast but rather a slugish diode with a high voltage drop, like 1n5408 or somthing along that line.
      Follow me?
      The resistance of the diode will act the same as the resistor but the polarity will be routed directly to the correct pole of the battery.
      This may or may not work but I think its worth a try.
      The switch is counter acting the BEMF and forcing it back to the source. If you follow the curve of the motor on the scope you can see that the negative leg of the wave form gets cut off. The left over power is then in serial with the source batteries and is force back through the coil of the motor so it can deposit on the opposite plate in the battery.
      This is why you have little to no heat in the resistors when you use the switch. But the diodes may allow the same interaction at a faster rate but we have to see.
      Anyway I am glad to see people working towerds the goal, but you have to make sure you cover your P's&Q's. Measure everything, detail everything, get as much info on your setup as possible and start documenting it in formatted way, or else alot of us are just going to be going over the same ground. That not needed in alot of cases other than to prove out a setup after that its time to move on to the next steps.
      Matt
      • Matt,
        If you think the absence of the switch caused the loss in voltage won't replacing the switch with one that won't fry solve the problem if we can do that? I'll give mine a shot tomorrow with the diodes and see what happens. Those I have boxes of. And I'll also try the Mosfett switch on a duplicate motor to see what happens with that combined with diodes. It'll give a basis of comparison for a long run, say five hours with each setup. I have enough batteries to run them both at the same time, although one of my bad batteries is probably a better "Bad" battery than the other, so after recharging my primaries on a conventional charger and letting them rest for a couple hours, I'll switch bad batteries and compare results. That will take the whole day.
        At least I won't be sitting around waiting for the big resistors to arrive in the mail and can get on with testing.
        • Dave have you been doing any runs with your coiler setup. Seems like you were
          saying you were waiting to get the welding done and then you were going to
          be experimenting. I had been holding off trying different things because I wanted to get the motor/generator setup working before doing more. But then
          I tried the 2BGS in the meantime. Now I might be leaving tomorrow or Thursday
          at the latest, so don't know when I will try something again.
          George
          • Still Working On It
            Great Work, Matt, and guys!!
            I've been working on this but haven't made any post lately. I'll try the new schematic soon.
            Here is a suggestion. You can find heavy diodes in car/truck alternators. Maybe your local garage has some alternators in their scrap heap.
            Also, if you need some high watt low ohm resistors, put several of the high watt low ohm ones in parallel. The resulting resistance goes down and the watt rating goes up. For example, I needed to be able to do a one ohm check to see what my current draw was in the circuit. I put 2 @ 2 ohm resistors that were rated for 10 watts each together in parallel, I got 1 ohm and 20 watts!!
            Keep up the good work!!
            Tony
            I believe in THE Way, THE Truth and THE Life.
            • FRC,
              I have been doing some runs with my original motor (110 volt DC) as well as two very small DC motors I bought a while back. The problem with the two small motors is I have nothing to use as a load, and I know from experience that you need at least a little load on the motor to try and balance the system. The best I have EVER gotten has been a six hour run on my large motor where I had it balanced perfectly and had no draw down on my two primaries.
              I have all my welding done, and am in the process of winding coils for my energizer, which is going to take a week or two. But I have pretty much put it aside to concentrate on getting a MOTOR working. My priority now is getting this setup to run as Matt had done, and as David P has done with the large resistors or possibly the diodes and Mosfetts as switches. I have the large diodes on order and that is the only thing I don't have right now.
              I picked up four 24 volt Razor scooter motors today, and should be able to salvage two or three of them by the time I clean them up, tear them apart, and put them back together. Then I will have several setups running at the same time with the same motor and the only variable will be the bad battery and whatever else I do to the setup to test out. Luther is also sending me a couple 12 volt motors, so I will have no shortage of test setups. I wish they were all the same, but then having a variety of different kinds of motors will come in handy when we think we have something and I can plug six or seven different kinds of motors into the system and see how they function. I am pretty committed to this thing. I have spent the last four years of my life messing with it on and off, getting discouraged and putting it on the shelf, then dragging it back out when I got some hair brained idea.
              I also have the pulse motor I rewound for the Peter Lindemann Lockridge thread, and have thought about using it, since it really is designed to be a pulse motor. The one I am considering only has one set of brushes, and it probably needs to have an external commutator to run with this setup, but it is lying around too. I also have a 12 volt fan with a motor and a car vacuum that runs on 12 volts, so I am in motor heaven.
              I know Matt rewound one of the Razor motors for Peter's thread too, so maybe he will try that one with this.
              One of the things I really want to convince myself of is that running that 110 volt motor on high speed with a balanced load hooked up to my energizer draws down my primaries. Will it or won't it. I have only run it on two batteries, and I have 9 that are the same that I could use, plus a bunch of others that are just random 12 volt car batteries. I need to run those kinds of tests and record the data and share it, so for th next couple weeks I intend to be a data producing machine.
              We'll miss you while you're gone. It was good having another pair of hands working on the bench and reporting in. Get yourself back here as soon as you can. We may have it all figured out by then.
              • Thanks Dave, was not expecting that much of a reply. You did answer something that had puzzled me foe a while though, and that is why you had not done that much with the 3BGS in the last four years.
                I will probably be gone for a month at the least. I will still try to check in with
                my iphone. I do not have it hooked up and can only use it with WiFY, I have
                another cell I use for a phone. I will be staying in a camper van and do not
                have an internet connection there. I still might try working on this in the van,
                but space is limited.
                Now that things have started to advance, thanks to Matt and many others I do not want to miss a beat. So I will try to stay involved as much as possible. Also I will pick up those couplers that I need for my motors and try them out. So I will not be completely away from this. It is just too important to ignore this now when things are rapidly advancing like they are.
                George
                • FRC,
                  I went through a really rough patch with this where everybody was telling me that it didn't work and I was seeing things and I didn't know what I was talking about. And even though I KNEW what I had seen, when enough people tell you it can't be, you begin to believe it and doubt yourself. I can't believe I let that happen, but I did. I was a newbie to all this stuff, with very little actual electronics experience and I had "experts" telling me it couldn't work. I could wire a house, but that ain't the same thing. I also went through a move and a divorce and everything else at the same time, and this setup was definitely NOT a priority. So it was really awesome when Luther contacted me a while back and told me he believed in what I had been saying and that got me motivated again. And now a whole bunch of people have seen at least part of what I have seen, so that has done a lot to restore my confidence that there IS something here worth exploring. It has meant a lot to me to see you guys get excited about this and jump on board. I was afraid I was going to get shouted down again, and that hasn't happened, so it's all good! All I needed was for some other people to see the same thing I saw, and now some of you have. And that is just awesome.
                  Hey, and if you can't access the internet, just call one of us and we'll get you caught up! LOL
                  • Originally posted by albertMunich View Post
                    the last developments sound really interesting.
                    I have tried two identical 12 to 18 Volt dremel tools. connected them very simply by putting a drill in one of the chucks and clamping the other chuck to it. I never could get more than 7 to 8 volts out of the one that ran as a generator. It lit up my car lamp though, so there must have been some current. what is the output Voltage you are getting on your generator side? Can you charge both primary batts at once?
                    • @FRC Takecare and have lot's of fun, hoping to see your comments and suggestions soon. We'll be waiting your return
                        Matt,
                        If you think the absence of the switch caused the loss in voltage won't replacing the switch with one that won't fry solve the problem if we can do that? I'll give mine a shot tomorrow with the diodes and see what happens. Those I have boxes of. And I'll also try the Mosfett switch on a duplicate motor to see what happens with that combined with diodes. It'll give a basis of comparison for a long run, say five hours with each setup.....
                        No doubt adding a switch in is what is needed, but the diode thing is easy so it can be tested quikly. Getting the Fet to drive off the signal coming out may not be as easy as you would think. After all you have to have 15-16 volt at the gate and ground to shut it off. I am not sure thats going to be a simple little task.
                        You can try and Carroll will probably get it right the first time so I may wate see what he has up his sleave.
                        Matt
                        • Notice To All
                          I noticed alot of you subscribing to my you tube account. I do not make any videos public there fore you will never get any updates out of a subscribtion on anything I do.
                          Sorry
                          Matt
                          • Matt and Carroll,
                            I know I am not the sharpest guy when it comes to electronics, so mostly I just hide and watch, but I know I have wired MJL's in parallel for other applications to handle a higher load. Is that worth trying here or is that another waste of time?
                            If it IS a waste of time, what are the specs of the transistor we need for this application? I have contacts at a LOT of places in San Jose. This is, after all, the Silicon Valley, and I made some calls this morning. I came up with two different places ( I have a friend that works at one of them, so I can get kind of a discount deal by going through him.) that will put together a transistor to spec, and one of them specializes in LOCATING transistors that meet your needs which are currently being manufactured. To have one made would cost from $8 to over $100. 00 each, but I'll outlay the cash for a couple to do the testing with, and we can go from there. NPN, PNP, JFET or MOSFET, it doesn't matter.
                            So....
                            Using the MJL as a guide
                            Collector-Emitter Voltage is 250 Vdc
                            Collector-Base Voltage is 400 Vdc
                            Emitter-Base Voltage is 5 Vdc (This should stay the same, right?)
                            Collector-Emitter Voltage 400 Vdc
                            Collector Current- Continuous 16 Adc
                            Peak 30 Adc
                            Base Current 5 Adc
                            Do either of you have a rough idea of what we would be looking for based on what you have seen? We can always try one and change our specs if it doesn't work. And if our specs are beyond what is possible, they will certainly let me know as well as discuss options with me.
                            • Still Here
                              Might be leaving tonight. After reading Matt's and Carrol's posts I was thinking the exact same thing Dave. Something like a Darlington Pair with the MJL's. Also
                              of how to not push things to far so that you could still use Matt's original circuit
                              but maybe still draw some load off the good batteries.
                              gEORGE
                              • No you don't to go through all that. If you wanna parrallel some up it will most likley work. I would use 47 ohm resistors with 2 or more, instead of the 100 watt.
                                Matt
