Relaxation Time: The time it takes for the free electrons in a conductor (or material) to reach the skin of the wire after potential is applied, is, of course, called the relaxation time. During that time, the free electrons in the gas are "trapped" insofar as producing current (dissipation of the potential) is concerned. However, immediately after the relaxation time ends, current begins and dissipation of the trapped energy begins.
In copper, the relaxation time is incredibly rapid. It's about 1.5 x 10-19 sec. However, in quartz it is about 10 days! So as you can see, we need to get somewhere in between these two values, and so we will have to "mix" or "dope" materials. We must get a sufficiently long relaxation time so that we can switch and collect comfortably in cycle one, then switch into cycle two for dispersion of the freely collected energy in the collector. However, the relaxation time we get must also be short enough to allow quick discharge in the load, as soon as we switch the primary source away from the collector. Actually, we need a degenerate semiconductor material instead of plain copper.
that is from Tom Bearden's Final secret of free energy.
Could a very thin PVC Fluid Hose filled with salt water serve as a conductor with slow relaxation time?
I mean, 100 ft of 1 mm PVC FLUID HOSE filled with salt water. winded like a coil. and then we pulse that water coil in bedini fashion.
I am too crazy? or it is a good idea?
best,
Alvaro H
best,
Alvaro H
Search for his capacitor patent with salt solution as electrode !
