Pocket oscilloscope or the Large One?
  • Pocket oscilloscope or the Large One?
    Should i consider buyingg a pocket oscilloscope, are they worth it? Vs the cost/ readout experience of a metal larger one. Say for teaching purposes for someone just starting out at electronics Thanks<<((8 8))>>
    0P3N S0UR(E 3NG1N33R1NG
    Pocket scopes are handy and becoming more affordable. My first one was Russian 2 ch monster which could easily keep my room warm in winter due to large number of vacuum tubes. I like traditional screen and somehow can't get use to lcd display. I guess it it depends what you'll be more comfortable with. You may look at some youtube videos where people use both and see for yourself which readout you'd prefer.
    Just my 2 cents.
    Vtech
    General D.Eisenhower
    http://www.nvtronics.org
      Just my 2 cents.
      Vtech
      If your frequency response is fairly small, you could
      start off with a free public domain software programme
      that works off your sound card, like Winscope.
      Winscope
      What are you measuring?
        Pocket scopes are neat but not very versatile and unless you go for the much more expensive ones they generally don't even go over 1 MHz so if I had to have only one scope I'd get one of the desktop types and depending on budget I'd get the one with the highest frequency I could afford. It is generally the frequency they can read that determines the price. 20 Mhz are cheap used and can easily be found under $100 of ebay. I would try to get one at least 60 to 100 Mhz or higher if possible.
          DSO nano
          It's 1 chanel, not really even 1MHz, but for things like joule theifs, pulsed motors(low voltage), learning about 555 timers, it works well. I have the old one with the sticky buttons but for 50 bucks it was worth it.
          If your going to be working over 800kHz stay away from the nano 1.
          Jake
            wow thanks, im learning so much already~
              DSO Quad
              The DSO Quad is much nicer then the DSO Nano. Its also more expensive.
              I'm not sure if its still in its beta stages or not but it might be worth looking into.
              DSO Quad - 4 Channel Digital Storage Oscilloscope [TES101D2P] - $199.00 : Seeed Studio Bazaar, Boost ideas, extend the reach
