radiant energy aerial circuit ASAP!!!
  • #16
    You need Chapter 7:
    To start with:
    Try with just the aerial, the capacitor and a voltmeter across
    it, with a good earth connection. You will find that the voltage
    builds up across the cap.
    Take it from there.
    Paul-R
    n.b. avoid electrolytic capacitors because it is uncertain which
    way round it should be connected. Use a high quality cap, and
    get several of different values. (The bigger the cap, the more
    energy is stored but the longer it will take for a voltage to build
    up.
    • #17
      alright looked at chapter 7.
      1)Does it matter if I use different/ assortments kinds of diodes?
      2)Does it matter if I use assortments of capasitors though out the circuitry?
      3) in the picture they show a special kind of capacitor HJC mkp x2 40/100/21
      What is it?
      4) The chapter 7 mention increasing the number of modules circuit ( as with the circuit board increases voltage) is this true??
      5) in chapter 7 on page 12 what is the red ??capasitior??
      6) can anyone explain what direction such as sizes I should use when I build my circuit board Because I plan to continuie expanding.
      Thanks for the help
      • #18
        alright that kinda blew my socks off tonight but im still not sure if I was actually getting anything... I mean when I stuck the testing cables into the dirt to measure 2000mVac it was like .2 then when i did the system it was .1 or something but then when I measured VDC it wen t to like 800 when the dirt did like 000-001 so i dont know. But it made me hopefull.
        So now im looking for a project something that will worth the time any recomindation would be great. I would like something with good output something that is worth the time. Time is the major cost to my situation.
        I will try anything yall recomend
        • #19
          The Bedini SG is a project ideally suitable for you. You will have first rate
          help and support from this group:
          Bedini_Monopole3 : Bedini_Monopole3
          Paul-R
          • #20
            Tesla radiant collector
            Good morning
            Here is a small youtube video which better explains Tesla's collector
            Enjoy
            Bizzy
            Utilization of Radiant Energy 1901 Nikola Tesla,My test - YouTube
            Smile it doesn't hurt!
            Jesus said,"...all things are possible through God." Mk10:27
            • #21
              So I got it up to 1.1 volts DC
              I am going to put a diode connect the areial to circurty
              hopefully it will light up a 2volt LED
              • #22
                mabey with the new diode
                • #23
                  Hi bpl
                  I glad that you are sticking with this. Your first impression was not so encouraging
                  I would also recommend you research something called a "joule thief" it helps power devices with low amperage. They are very simple to make. there are several youtube videos explaining thier design and a thread on this forum which would be a great source of information.
                  Keep up the work.
                  Can you can a video or take pictures so you can show us your work?
                  Bizzy
                  • #24
                    Originally posted by wrtner View Post
                    You need Chapter 7:
                    To start with:
                    Don't forget that the voltmeter will use up some current.
                    It would be good to measure, disconnect the meter, and
                    let the voltage build up again.
                    You can use a sheet plate instead of (or as well as) the aerial.
                    I straightened out the casing of an old desktop computer, and
                    supported it on an insulated copper pole.
                    • #25
                      zzzzzzzzzzzzz
                      • #26
                        I found that, all of a sudden, I had half a volt which would
                        not go away - however much i discharged my capacitor. I
                        went outside and saw that the plate had fallen off its support
                        and was lying on the wet grass, forming an electrolytic cell, a
                        battery.
                        BPL:
                        It is a bit of a cheat, but if you are desperate to show something
                        to others, you can always drive a thin copper water pipe into the
                        ground and beside it, a thin steel water pipe. Cable them back
                        indoors and you will get a voltage that is pretty useable. Put
                        a few more copper and steel pipes in the ground (different metals)
                        and connect them properly, and you will increase the voltage.
                        The morality of this is a bit questionable, but if you get on to
                        that yahoo group and build a Bedini SG, you should be able to
                        drive it off your copper/steel pipes.
                        That should pull the birds.
                        • #27
                          zzzzzzzzzzzz
                          • #28
                            Question about magnet generator??
                            The devices such as bedini SSG they use magnets, do these magnets ever loss there energy after running a load on the system?
                            • #29
                              Magnents
                              can I use earth magnents OR CERAMIC for bedini ssg monopole
                              • #30
                                Why have you chosen a thread that has nothing to do with magnets
                                to ask a question about magnets?
