FEMF, BEMF, and Inductive Collapse
  • FEMF, BEMF, and Inductive Collapse
    Hi Gurus,
    I have been around under different names for a while. I am still not an expert, but I get frustrated by the use of terms that are simply incorrect! I am trying to clear these terms up and with help from others here, trying to define their definitions more clearly, so a better approach can be taken to the industry we have all created.
    FEMF :
    The term Forward Electro Motive Force, or just EMF, this is directly a result of Induction. There are two types of induction, Flux Cutting and Flux Linking. Each are separate and defined differently, by separate equations.
    The Flux Cutting equation is : EMF = Bvl
    The Flux Linking Equation is : EMF = -dPhi/dt
    Defined by George I Cohn.
    BEMF :
    The term Back Electro Motive Force, the same as CEMF, is also directly a result of Induction, defined in the FEMF section. However, BEMF or CEMF is always in opposition to the Input Power we put into the device that is being acted upon by the BEMF in the first place.
    An Example, we are driving an Electric Motor, our input is 12V @ 1 amp. The Rotation of this Electric motor will be affected by BEMF in the opposite direction to the for mentioned input, causing more input into the Electric Motor than is actually required to run the Electric Motor in the first place. Thus, only a fraction of the input we put into the motor is actually doing work to turn the Shaft of the Electric motor, the rest is actually being destroyed by the BEMF, caused by induction as the Shaft, Rotor turns.
    BEMF is Induction as a result of the Rotation of the Rotor, which is in opposition to our Input. (In most Cases but not all - Some Motors have no BEMF Issues)
    BEMF is NOT Inductive Collapse!!!!
    Inductive Collapse :NOT Over Unity, but it is a very good way to do work, and then recover some of your energy back. This arrangement can easily be measured as Over Unity but most of the time this is Measurement Artefacts and this circuit can never run itself which is the only real proof of Over Unity.
    DC to DC Converter :
    The DC to DC Converter has been around for quite some time and runs on the same principal, Inductive Collapse. The most efficient DC to DC Converter I have ever seen is 95% efficient. Inductive Collapse increases the DC Voltage at the cost of DC Current.
    Over Unity :
    Over Unity, where our Input (X) is exceeded by one or multiple Outputs (Y...). So, for example : our Output (Y = 2) divided by our Input (X = 1) = COP = 2. The Coefficient of Performance = 2. This means we are 2 times above Unity. Instantaneous Power Measurements are usually the best to compare.
    In our above example with a DC Pulse Motor and Inductive Collapse (Energy Recovery): Over Unity can be achieved if Torque on a Motor Shaft and Energy Re-Capture can both be accounted for in the one device, as long as you have a motor that does not suffer from BEMF and is above 90% efficient but the gain is minimal and the device becomes a Desk Toy and nothing more.
    Radiant Energy :
    We have all heard about Radiant Energy as far back as the days of Nikola Tesla. Nikola Tesla explained Radiant Energy as Electric in Nature and NOT Magnetic. Radiant Energy can be proven to be Electrical in nature by Experiments done by Prof Konstantin Meyl. Do the Research here yourself.
    See : Prof Konstantin Meyl - Scalar Waves - Theory And Experiments (2001) - For the only known Circuits that work for Radiant Energy and theory of Experiments. Its interesting to note the Circuits have been measured Over Unity by Prof Konstantin Meyl!
    So, if you have proof otherwise to the above facts, please post a detailed no mess around, reply to this message so it can be easily replicated. No Loads of Neon, Fluorescent or any other Gaseous type Globes will be accepted as evidence as these loads are nothing more than Fools Gold for FE Researchers.
    Scalar :Summary :
    I hope this has cleared up many of the hard to understand aspects of this grey area of magnetics. I think it is important to note that Peter Lindemann has pointed this stuff out a few times in his posts and also in his Videos.
    Links:
    Measuring DC Power : Measuring DC Power (Basic guide)
    Measuring AC Power : Measuring AC Power (Basic guide)
    Power Factor Guide : Power Factor Guide (Very good explanation here!)
    Self-Resonant Frequency of Inductors : Self-Resonant Frequency of Inductors
    Generating Negative Energy : Generating Negative Energy
    All the Best - EMJunkie
    Last edited by EMJunkie; 03-18-2012, 01:36 AM. Reason: Adding Information to Post....
    Hi EMJunkie, I was right with you in agreement until you mentioned Meyl and scalar waves.
    I think one of the big problems around this type of research is that ie. I can
    agree with almost everything you wrote but not everything, and it's not worth
    my time to argue about what I disagree with.
    I agree with the Back emf example but Back emf is not restricted to motors, it
    happens every where current flows in a wire.
    When we use a home made inverter circuit to switch a transformer with two
    primaries or a center tapped primary when there is no load the flux in the
    transformer is maximum and the resistance to primary current flow is increased so the
    transformer idles with very little current draw, isn't this Back emf ? Then when
    the secondary is loaded the flux is reduced which in turn reduces the
    Back emf which then allows more current to flow to replenish the flux in an
    attempt to keep the flux in the transformer at maximum.
    Without Back emf current would just keep flowing and everything would burn
    up. We should thank our lucky stars for Back emf. Without Counter emf
    transformers would just keep using full power even with no load.
    Many people want to have setups where the load does not effect the primary
    current draw. That might be alright for a system that uses a few watts, but in
    a system that uses kW power levels that would be the most ridiculous thing,
    a transformer using 5 kW with no load absolutely ridiculous.
    Tesla considered it very important the wireless power system he designed
    would use less input when there was less load and more input when there was
    more load, it makes complete sense.
    At some point we need to decide if we want to experiment with novelties or if
    we want to experiment with devices to power our stuff. Problem is most of
    the experimenting, false info, incorrect terms and whatnot on such a basic
    level makes it almost impossible for useful collaboration.
    I'm no expert, I'm trying to make sense of things and ignore the rubbish, it's
    not easy to ignore it all, but it is easy to spot most of the crazy stuff that
    makes no sense or less than no sense. And it's getting easier every day.
      Nice Healthy Debate!
      Hi Farmhand!
      I hear you and agree with debate especially with this type of topic. First, however:
      Why is it that you disagree with the Meyl Experiments?
      I think one of the big problems around this type of research is that ie. I can agree with almost everything you wrote but not everything, and it's not worth
      I agree with the Back emf example but Back emf is not restricted to motors, it happens everywhere current flows in a wire.
      When we use a home made inverter circuit to switch a transformer with two primaries or a center tapped primary when there is no load the flux in the transformer is maximum and the resistance to primary current flow is increased so the transformer idles with very little current draw, isn't this Back emf ? Then when the secondary is loaded the flux is reduced which in turn reduces the Back emf which then allows more current to flow to replenish the flux in an attempt to keep the flux in the transformer at maximum.
      Without Back emf current would just keep flowing and everything would burn up. We should thank our lucky stars for Back emf. Without Counter emf transformers would just keep using full power even with no load.
      Many people want to have setups where the load does not effect the primary current draw. That might be alright for a system that uses a few watts, but in a system that uses kW power levels that would be the most ridiculous thing, a transformer using 5 kW with no load absolutely ridiculous.
      Tesla considered it very important the wireless power system he designed would use less input when there was less load and more input when there was more load, it makes complete sense.
      If you can point me to some links with more information about this. I have not read this anywhere, so I would like to study this in more detail?
      At some point we need to decide if we want to experiment with novelties or if we want to experiment with devices to power our stuff. Problem is most of the experimenting, false info, incorrect terms and whatnot on such a basic level makes it almost impossible for useful collaboration.
      I'm no expert, I'm trying to make sense of things and ignore the rubbish, it's not easy to ignore it all, but it is easy to spot most of the crazy stuff that makes no sense or less than no sense. And it's getting easier every day.
        Originally posted by EMJunkie View Post
        Hi Farmhand!
        I didn't word that very well, I do that a lot. It's not that I disagree with his
        experiments or conclusions as such, I must say I agree with much of his
        findings, it's the scalar wave thing mainly. And also I think he may be equating
        potentials with power or energy sometimes, he can be vague even though he
        says a lot.
        Yeah that says it better than I did.
        I agree with that, I don't have a full grasp of the proper terms so I try to say it how I think it makes sense.
        Yes I can understand all that and I agree too, but won't that mean the
        output is limited to the constant input more or less, as in if the setup was
        designed to deliver 100 watts 100 watts is all that you can get maximum and
        when you take nothing the input is still the same ? Basically a constant
        current arrangement ?
        Yes here are two snippets, from here -
        Nikola Tesla On His Work With Alternating Currents -- Chapter IV
        This one is in the second last paragraph of the 5th reply to council by Tesla
        after figure #79.
        Now the vast difference between the scheme of radio engineers and my scheme is this. If you generate electromagnetic waves with a plant of 1,000 horsepower, you are using 1,000 horsepower right along -- whether there is any receiving being done or not. You have to supply this 1,000 horsepower, exactly as you have to supply coal to keep your stove going, or else no heat goes out. That is the vast difference. In my case, I conserve the energy; in the other case, the energy is all lost.
        This one is in the third paragraph below figure #82.
        Theoretically, it does not take much effort to maintain the earth in electrical vibration. I have, in fact, worked out a plant of 10,000 horse-power which would operate with no bigger loss than 1 percent of the whole power applied; that is, with the exception of the frictional energy that is consumed in the rotation of the engines and the heating of the conductors, I would not lose more than 1 percent. In other words, if I have a 10,000 horsepower plant, it would take only 100 horsepower to keep the earth vibrating so long as there is no energy taken out at any other place.
        The way I see it one way is primitive like a stove radiating heat as Tesla put
        it ( catch and use what you can when you want but the input goes on
        regardless if the system is to be kept running and available, the other way is
        smart and advanced like storing the energy in a very low loss machine or
        (oscillator) to use only when wanted, efficiently and when the demand is less
        so is the input. I know which I would prefer in anything other than a constant
        load or (demand) situation, with a constant unchanging load it would be
        practical to have a fixed input but with changing demand the input must
        reflect the load to be efficient.
        Yep.
        No probs, Thank you for the sanity check. I needed it.
          I kind of have mixed feelings about the scalar wave issue though.
          If all energy is expressed in waves then if energy can be derived from a scalar
          "something" then that energy would have to be expressed in a wave of some
          kind, this all comes down to peoples definition or understanding of definitions.
          Ill ask some theoretical questions, no need to answer them.
          eg. What is a wave ? There are many different types of waves even hand
          waves. But seriously if a wall of water with a vertical side and unvarying
          height was headed at you would you call it a wave ? What about if the wall of
          water was standing still and you were moving towards it " Is it a wave then ?
          But then what if you didn't perceive it that way, what if you perceive it as the
          wall moving towards you.
          What if the entire wall of water was moving up and down without changing
          it's own height would it be moving in a wave considering the planet it is on is
          moving through space ? It would have considerable energy.
          But still a completely non varying value in nature is impossible anyway.
          Nothing is still and nothing goes unchanged for any period of time. As far as I can tell.
          So any application of energy must have a start and an end, and
          therefore must be a wave, even a DC wave. All energy is expressed in waves. It must be.
          Some things are and will always be theoretical for the sake of an easy
          explanation or to finalize something, Like "infinite" the universe is said to
          infinite or finite depending on your outlook. If you say it's infinite it saves a lot
          of explaining and unnecessary thinking. The term is a tool to use or misuse.
          I think we should be able to define what we mean by a term in fairly simple terms.
          When used with the word wave as in (scalar wave) what does scalar mean ?
          Does it mean the wave amplitude cannot be changed by anything ? Or is it
          like a a square wave of energy ? or is it like prods from a stick as in directed
          focussed energy blocks ?
          I can't visualize what is meant by the term scalar wave.
          P.S. Thought experiment. If I was to apply 12 volts DC to a simple circuit with
          a bulb in it for 1 Hr then stop, the supply is ideal (theoretical) so the 12 volts
          does not vary at all. I think what we would see is a wave of energy through
          the circuit with a period of 1 Hr. It could be 24 Hr's if that was the experiment
          but it is still a wave it's just on a bigger "scale", isn't it ?
              Hi Farmhand,
              Re a few questions you had on Inductors in paticular, it may be worth your while to check out the Power Factor Giude Link above on the first post, especially the Reactive power section of that link. It may explain the questions better than I can.
                Hi EMJunkie, I just noticed this link in another thread, so I thought I would share it.
                This link more or less tell the concerns I have with Meyls setup and his claims.
                Skalarwellen_Versuche
                The basis for his OU claims seem to be folly and the basis for the wireless
                transmission claims are baseless he uses a connecting wire. The basis for the
                Scalar waves is also dubious.
                I showed much better results than he did with my pair of Tesla coils I made.
                I showed from a 12 volt input to the transmitter receiver voltages of over 800
                volts charging a capacitor and could run small motors banks of LED's and
                such.
                This is from inside one steel shed to inside another steel shed. The transmitter
                is powered by a 12 volt battery and the receiver shows 24 volts under load.
                Transmitter Test 3-1.wmv - YouTube
                This is a capacitor charged to 700 volts from the receiver which is receiving from
                the transmitter which is powered from a 12 volt battery, the two transformers
                are identical (transmitter/receiver) so the receiver should step down the same
                as the transmitter steps up. But that is not a big deal because voltage is not
                power or energy. At the end of this video I drivel some stuff about Bemf which is not really accurate so ignore that.
                700 volt cap charge.wmv - YouTube
                Using a "ground wire" for such transmissions is very easy, however using the
                actual ground in place of that wire is a totally different thing altogether.
                Meyl's setup is configured to transfer the energy mainly through the "ground wire".
                I think his main concern is to make money and he cares little for the truth in
                my opinion. He may even be organised disinformation. But I have no way of
                proving that.
                My conclusion on Meyl is the same as I have stated here in public before a few times.
                Meyl is full of it. He a scammer in my opinion, he tries to get money for something which is NOT what he says it is.
                He should be made an example of and denounced at every turn.
                If an uneducated soul like me can build a setup like I did then it is nothing
                special it's just another way to do things. I learned a lot of things from that
                setup I built one of the things I learned is that a lot of so called experts are
                full of it, and either know less than they make out they know or they are
                disinformation agents.
                I'm a rank amateur so I am allowed to make mistakes and misconceptions.
                I don't profess to be an expert.
                  www dot intalek dot com
                    Hi EMJunkie, Yeah I have a strong opinion but no real proof and I lack a good
                    grasp of the terms to explain what I think well. The German link summed up
                    fairly well how I feel about the claims of Meyl.
                    The electrical phenomenon is quite complex and I don't think it follows a single
                    set of rules in all cases.
                    I'm not well educated in a formal sense, I think I can see fairly well what is
                    happening in my experiments even though I can't always explain it in words
                    that make sense to others.
                    This is what I think about the system of one wire or ground transmissions.
                    Some systems if the transmitter and receiver are close enough can transfer
                    energy between the air terminals.
                    My experiments tell me that this will work even without a connecting wire if
                    the two transformers are close enough to each other. So therefore when the
                    wire is connected in that situation there can be some of both.
                    When transmitting from inside a Faraday cage only the current through the
                    ground wire should reach the receiver. In my linked experiment I transmit from inside
                    a steel lined shed with a metal mesh door.
                    In this case the air terminal is just a reference like a ground connection but
                    it's air, the reference is about the same for both transformers which makes
                    the air terminals neutral, but not really from our perspective, it's difficult to
                    visualize but not impossible.
                    So when the two transformers are a long way apart I don't think they
                    transmit any energy to each other through the air, the air terminals are just
                    like a fulcrum or a point to push from. The energy is bounced back and forth
                    from one transformer to the other through the ground connection, and the
                    system idle's like a transformer does when no power is drawn, if power is
                    drawn from the receiver the resistance to the flow of current in the
                    transmitter primary is reduced and more current flows which puts more energy
                    into the system to replace what is drawn.
                    There is no hocus pocus or anything even all that special about the way it
                    works, the air terminals are designed to radiate as little as possible so energy
                    is not lost there, but some radiations are inevitable and can be utilized in part.
                    In my mind it is not much different to a single wire Earth return power
                    transmission system, except the ground is the conductor and the return path
                    and the air is the reference point. The return path is a bit of a moot point
                    with standing waves but there must be one to get them.
                    The length of the connecting "ground" wire or the distance between the
                    transformers should be considered as well as stated by Tesla in the patent
                    787 412 page three lines 30 to 63 or so where he outlines the things needed
                    for transmission of energy this way (through the ground).
                    Patent US787412 - NIKOLA TESLA - Google Patents
                    I don't see how a system for the transmission of energy can be demonstrated
                    with both transformers only a few meters apart on a bench, they will interact
                    with each other in ways they would not interact when separated with a
                    mountain or a steel cage or a big distance.
                    I came to the point where it was not worth continuing with transmitting and
                    receiving experiments because I am more interested in actually using the
                    ground to transmit through, which Tesla says requires the use of frequencies
                    below 35 Khz around about, this presents three major problems.
                    1. The size of the transformers.
                    2. The distance required between them to get to a 1/4 wavelength or multiple thereof.
                    3. The input required to power such a big transmitter.
                    Early in my experiments when I was trying to tune my transmitter coil to
                    resonance, another person who lives here came home and complained that he
                    was picking up my noise from about 5 Klm away with his car radio as he got
                    closer it became louder until he turned it off, I was using only less than 10 watts.
                    I didn't believe him at first so we tested it and sure enough my transmitter
                    was causing the noise in the car radio. When the transmitter was tuned to
                    resonance or ground connected the radio noise stopped but transmission
                    through the ground with 500 khz won't work very well. And transmitting with a
                    wire is old hat, my electric fence does that in single wire earth return.
                    So of course there remains one more option, which is to use a magnetic cored
                    pair of identical transformers which operate at resonance below 35 Khz and
                    use them like a pair of Tesla coils with an air terminal and the bottom of the
                    secondaries ground connected, with enough potential at the terminals and the
                    low frequency with the correct distance between the transformers ground
                    transmissions should be very possible and actually work using the ground.
                    I'll get around to trying that sooner or later.
                    I don't see how there would be any OU though unless a multiple of 50/60 Hz is
                    used whichever is the local flavor. Which would make our system OU but drag
                    the COP of the local power station down a miniscule fraction.
                      Hey Farmhand - go and purchase a Wind Turbine and measure the 'hocus pocus" happening there.
                      Mate youre desputing repetable experiment's - This is "hocus pocus" everyday of the week if you look up the meaning. Dont kid yourself, do the experimentts and proove points.
                      Out of respect, I am just getting to the point.
                      If you really are serious do the experiments. You can purchase Meyl's equipment to replicate his eperiments if you really need to. A wind turbine is COP = Infinity! An Atom is always in continuious motion (for 13 Billion Years? or something?). The problem is simply, we are not smart enough to do it, not that it cant be done.
                      EMJunkie
                        many ways to skin a cat
                        You might want to try this.
                        WARNING:- use only in a well ventilated area as the coils give off large amounts of ionized gases
                        enjoy
                        Mike
                          Read this
                          14-37 Arc Electron Avalanche
                          Read this together with the post above, you will see how this applies.
                          Mike
                          P.S. this applies to more than one thread hear on this forum.
                          this is in part, part of my electron beam tech: and I am sure you see why.
                          • #14
                            [ATTACH]11178[/ATTACH]
                            enjoy
                            Mike
                            I find that interesting, it's an eerily similar layout to the circuit I'm working with. the only difference is that instead of L1, L2 & L3 being coils they are capacitor plates, L4 is a bifilar winding around the plates. there is a ground lead at the capacitor off L4. input of pulsed 9vdc output of 70vdc and 70vac rms, there is a massive spike that exceeds my meters every 3secs though. 6kv is the meters limit.
                            • #15
                              Thats why I posted it here
                              Thats why I posted it, and by the way I will say so if I have not tried it, there are a few differences to e-beam, but, I think this is what you are looking at, it is an electron and photon multiplier and will give you high current if set up in the right way.
                              High voltage is needed for the input "15kv" so as to energise the air around the coils. Just heed my warning of nasty ionized gases if used in a small space "NOx" if used in air.
                              Mike
                              It will also glow in the dark if working properly
                              Last edited by Michael John Nunnerley; 05-24-2012, 04:49 PM. Reason: bad memory again
