Originally posted by Kokomoj0
It makes no difference if someone is sick and you can't borrow their machine when you have your own. The only thing preventing you from having what they have is you. This is just information and you have the same as everyone else has got, so you're not at any disadvantage. So it makes no difference what "someone else" is doing, they can't be blamed for your lack of a device to test and measure.
I can't answer your questions because I'm not an electrical engineer. I just do things and then see what happens as direct effect. I'm not actually all that interested in having equations and explanations in advance, it's of no use to me without any practical knowledge to put it into context. What happens as a result of doing it is what happens, enough said. No need for an equation to be able to kick a ball and watch it bounce off your foot.
Are you sure he's using the water as a conductor between transmitter and receiver, because I can't see any wires going into the water, and he explains the water as being the "return path to earth". That is, he is describing it in conventional terms. He's not saying the energy is coming in from the earth/water, he is saying it's returning to earth through the water?? Like a normal circuit. And in this case, why is his terminal capacitance sphere so high in the air? If it was working properly then he could make it a lot neater than that, no need to have a big mast on the boat sticking up in the air.
