Question, Mr Wizard the Lizard...
Not having enough material on hand to construct the coils in the kHz range I instead built mirror pairs for 4MHz. took some tweaking on the extra coil capacitance but managed to get a near 45* line on the 'O'scope still had a bit of a loop to it. need to dig up the pics.
couple things I noticed, it was exhibiting strange effects on my cellphone, the phone was squaking and buzzing of it's own accord, ended up pulling the battery out. I had a shortwave receiver set to pick up at 4MHz but it was dead silent. the session didn't last long as the signal generator stopped producing the signal, it powers up and will only produce a single base fq now. it also perhaps coincidentally seemed to attract 'fly overs'. that was all a yr ago.
Is there any reason to assume that the FTL transmission of this nature is being monitored? however that opens another question...
the single coil arrangement is passively receptive to the radio stations output and then transmitting without reception. In building a mirrored pair one is transmitting and the other receiving, correct? In taking measurements and getting a feel for the setup I was able to notice that measuring the transmitter side interfered with the receptive side, and vise versa. it would seem to be a very 'closed loop' data stream from a security standpoint. it would also point to a 'feedback' loop that would eventually self-destruct, right? how to modulate that would be key. now, if there is some sort of monitoring for such signals then wouldn't that be manifest when trying to 'tune' the coils? esp if it's a single transmitting set?
If I'm way off or wrong, please let me know. receiving a 'radio' wave of the sub C variety is passive, the telluric current signal would feedback to the source. this would probably explain why my generator is no longer generating.
powering bulbs, etc.. are now part of the circuit actively, neon bulbs would be easier to manage due to the low current draw and effect on the 'feedback' they are self limiting, a resistive element is not self limiting but would sink to failure, once the circuit is balanced for bulb being in place. LED's are in-between but as I found they still go 'pop'. Is that close?
that's my haphazard post, I hope it wasn't to confusing.
I'm toying with the idea of sending the coils to someone who may want to test them further. I'm short on free time for the next couple months.
