Collecting best quotes from Eric Dollard proving his points
"The guy wanted to give me some cockamamie college explanation.. Well he was talking to Steinmetz. He just got this look on his face, oh my god! "You know its like a c'yote that shoved its nose into the wrong hole and something held on" - FQToE video part 2."Doesn't matter how many times you kick the coyote in the head, it's still gonna eat chickens". - EPD
For the Electricity extant between a pair of wires in your lamp cord, the closer the wires, the more capacitance, and thus the more Dielectricity. Conversely, for the same cord, the farther apart the wires, the more inductance and thus the more Magnetism. Therefore it is seen that the smaller the space (the more counterspace) the more Dielectricity that can be stored, and conversely the larger the space between the wires (the more real estate) the more Magnetism that can be stored. Very simple, do not let your mind make it any more complicated than that!
It can therefore be seen that the conducting materials serve as the walls of a container holding magnetic pressure. If the conducting material is in the so-called superconducting state and the ends of the circuit are shorted the electric circuit will hold this magneto-motive pressure indefinitely, in analogy with compressed air stored in a tank. In order for this to be the result of electron flow requires that this flow be in perpetual motion, an unlikely proposition.
It may be concluded that materials called electric conductors might best be called electric obstructors and serve not to conduct electro-magnetism but serve to reflect it back on itself. The flow of electro-magnetism is conducted by the aethereous space bound by the obstructing material.
The character of this aethereous space is represented by its inductance L and its capacitance C. Since pure space is considered a perfect insulator by atomic theory, is it not ironic that it offers the least resistance to the flow of electro-magnetism? It is then the insulators that are the true conductors of electricity.
Hence we have FOUR primary dimensions in electrical engineering. These are
1) Time 3) Dielectricity
2) Space 4) Magnetism
Every other relation, quantity, or expression, Volt, Amp, Ohm, etc. is derived from these FOUR dimensions. Time and Space are the metrical dimensions, Dielectricity and Magnetism are the physical dimensions. It is that basic! We are now prepared to move forward in our effort to stop being parrots.Last edited by TheoriaApophasis; 03-30-2014, 07:36 PM.
now this is funny:
Advancement will receive only a HINDRANCE, H, in the dimensional relation of B. S. Three primary dimensions give rise to hindrance H, in GOLDBERGS.
1) One will be PENDANTS, the Prostitutes of Electrical and Electronic Engineers, the P.E.E.E.
2) Another will be MYSTICS, the Quantum Car Mechanics, the Q.R.M.
3) Finally, will be DIS-INFOS, the Soviet Scalar Xenophobes, the S.S.X.
CAPACITANCE
The phenomena of capacitance is a type of electrical energy storage in the form of a field in an enclosed space. This space is typically bounded by two parallel metallic plates or two metallic foils on an intervening insulator or dielectric. A nearly infinite variety of more complex structures can exhibit capacity, as long as a difference in electric potential exists between various areas of the structure. The oscillating coil represents one possibility as to a capacitor of more complex form, and will be presented here.
CAPACITANCE INADEQUATELY EXPLAINED
The perception of capacitance as used today is wholly inadequate for the proper understanding of this effect. Steinmetz mentions this in his introductory book Electric Discharges, Waves and Impulses. To quote, "Unfortunately, to large extent in dealing with dielectric fields the prehistoric conception of the electrostatic charge (electron) on the conductor still exists, and by its use destroys the analogy between the two components of the electric field, the magnetic and the dielectric, and makes the consideration of dielectric fields unnecessarily complicated."
LINES OF FORCE AS REPRESENTATION OF DIELECTRICITY
Steinmetz continues, "There is obviously no more sense in thinking of the capacity current as current which charges the conductor with a quantity of electricity, than there is of speaking of the inductance voltage as charging the conductor with a quantity of magnetism. But the latter conception, together with the notion of a quantity of magnetism, etc., has vanished since Faraday's representation of the magnetic field by lines of force."
THE LAWS OF LINES OF FORCE
All the lines of magnetic force are closed upon themselves, all dielectric lines of force terminate on conductors, but may form closed loops in electromagnetic radiation. These represent the basic laws of lines of force. It can be seen from these laws that any line of force cannot just end in space.
Electricity is aether in a state of dynamic polarization; magnetism is aether in motion, dielectricity is aether under stress or strain. The motions and strains of the aether give rise to electrification. Phi times Psi gives Q.
Realize that the energy is not equal to mass times velocity squared. Electricity is mass free.
When the magnet is at rest its magnetic lines of force exhibit only internal aetheric motions, outside this they are stationary. However, if this magnet is forced into motion, the magnetic lines of force react to this force of motion. This is a reactive force, much like the E.M.F. As with the E.M.F. or the brakes on a car, this reactive force only manifests during a change in velocity with respect to time.
Originally posted by Aether View Post
Thats not oil, its glass. But still makes the point.
Odd you linked that video, since I discovered it on my own some 5 days or so ago.
Yes, the end of the video is fascinating.
Poor Dollard is yelling that everyone has electricity ass-backwards, and he is right.
I have the same dilemma in another area of expertise where there are none on earth that know more than myself about a few topics.
Dollard experiences the same thing I do, ....just on a different subject.
were both pointing out the "Emperor has no clothes on". The world is full of ignorance without end.
These mechanical forces, those of the dielectric, and those of the magnetic, exert actions so as to increase their coefficients of induction, that is the dielectric "capacitance", and the magnetic "inductance" are increased. Hereby, the dielectric field draws the conductors nearer to each other, increasing the counterspace. Conversely the magnetic field pushes the conductors away from each other, increasing the space. Hereby we may say that the dielectric field is contractive, and the magnetic field is expansive.
So what may aether be? Consider what are called the "states of matter."
1. SOLID
2. LIQUID
3. GAS
4. PLASMA
5. AETHER
Hence, the five distinct states of matter.
Electricity is embodied in the aetheric state of matter, or "proto-matter."
Also consider the J.J. Thomson concept of the
"electron" (his own discovery). Thomson considered the electron the
terminal end of one unit line of dielectric induction.
