Self Oscillating
What's wrong with self oscillating, if the pendulum is working ? My SSG circuit
does the same, but is still charging. I was told the circuit is self oscillating because there is too much resistance somewhere.
FRC
FRC
It was barely using any mA. Yes, you have to have a solid arm. I used rollers skate wheel as a top bearing with brass rod and magnet cradle on the bottom. Had to play with gap and gravity a bit. I put another rod lined up with the long one (just as I would drive the rod through the wheel leaving few inches on the top) I attached a steel ball to the short end and adjusted by cutting pieces off until I found balance spot where pendulum was swinging without rolling over the top. However, charging wasn't successful. It seems to be pure radiant without current or too little. My charging battery eventually died after few months. I kept it running without, just a photocap with neon across which fired every few seconds. I found this being inspirational and have a very calming effect
