Way to hang in there Garrett. That's a good rpm for a single coil, bike wheel energizer. A 12v battery discharged and holding 1.5 volt is a VERY bad battery. Let your Bedini charge that battery over night. Let it rest for 2 hours, if it holds >10v then charge it again. If less, then it is probably permanently damaged, unless it's an old battery. Do not try to use that battery to run your wheel. It needs a lot of conditioning. You should get a ohm reading of your pot by disconnecting one of the leads and get a reading where the leads were on your pot. This will tell you your base resistance for your wheel.
Great Job!
Randy
Great Job!
Randy
