House grounding wire as a small scale antenna for immediate use...
Since LessEMF.com has a product that shoots a frequency into the grounding line of the house wiring...
EARTHSAFE WHOLE HOUSE
...and you can even ask them to calibrate and mark the tuning knob to help locate its 7.83Hz output using their "Tuning Service" on the same page as that linked above, it's immediately apparent that the grounding wire of the house wiring is another possibility for emitting Rife Frequencies to heal everyone in the same building as yourself alternating with the Schumann tone as the predominant tone without resorting to attempting to implement the technically difficult "Ray Tubes" of Rife's bygone era as the emitting device of choice.
But if Eric Dollard's description of our low voltage neutral grounding wire within our buildings is truly being shorted with the high voltage neutral on the utility side of the power company's transformer outside our building,...
... and since our building's grounding wire is linked to our neutral line at the bus bar in our breaker panel where our power enters our building from this transformer short at the utility pole, maybe using our building's grounding wire as our choice for broadcasting Rife and Schumann Frequencies may have a mild chance of propagating down the entire power line despite the huge voltage occurring on the utility side of the transformer, and thus heal everyone else in our local community within a limited range?
At the very least, any possibility of impact is better than doing nothing about this...
There must be a way to modify the audio signal output from our audio system to be able to drive the single wire of either an antenna or our building's grounding wire just as the EARTHSAFE WHOLE HOUSE device accomplishes? Then, a simple recording of these frequencies could be piped into any style of antenna.
And if our building has a metal roof, in all likelihood this too is grounded and thus connected to our building's grounding wire making it an excellent output as an aerial.
Since 7.83Hz, 2008Hz, and 2127Hz (+/- 1-2Hz) are well below radio broadcast frequencies because of their distinct audio range, this is not an FCC issue - right?
