Bedini SG - Complete Handbook
  • Bedini SG - Complete Handbook
    Here is the new book: Bedini SG - The Authorized Beginner's Handbook
    If you don't know what the Bedini SG is, get this free file: http://bedinisg.com/bedinisg.pdf
    Bedini SSG Energizer Kit
    wrtner
    You say "so I don't have to build it" but call it a kit. Will this product
    be a completed and "tried and tested" product?
    Wrtner,
    There is minor assembly required. The coil is pre-wound with 7 windings I believe and the circuit board is already built. You'll just connect the leads to the proper places. The frame can be assembled in less than 5 minutes and a couple minutes to mount the wheel. The entire thing can be put together in under 30 minutes since all the hard work is done.
    So it is still a kit but like I mentioned in the FAQ, it doesn't have to be built from scratch.
      SG or SSG
      Is either of the motor designs self runners?
        Bedini SG
        Mina,
        This book shows the exact specs and all the plans to build a SG/SSG just like John Bedini builds his. It is designed to draw from an input battery, charge an output battery while producing mechanical work at the wheel. There is a lot more in the book than just that, but that is the bottom line results.
        When adding up all the work (including the mechanical), it is more than what left the input battery when we look at the net work used since most is recovered.
        The book shows how to build that - it is not a book showing how to make a self running machine.
          Bedini SG
          Hi everyone,
          A few people have mentioned that the recommended coil winding direction in the book is opposite of what has normally been done with the classic SG for years.
          Basically, everyone who got this book will see something that is mind-blowing and we'll put an updated book on the download page by the end of the week explaining this.
          If you have the book, you have MORE than what we promised we would give you in the book... WAY WAY MORE. You just haven't seen the explanation as to what this is but we're giving it to you soon.
