i tried an experiment this morning, seeing if i could take the output of the ssg and use it to fill a capacitor and then using a transistor pulse the charge back into the coil at the right time using a slave trigger coil at the virtual south pole point. (or possibly just after the magnet had passed)
the thing accelerated like i have never seen before, and when i connected a battery instead of a capacitor it seemed to charge extremely well and started spinning upwards of around 10,000rpm (hard drive platter rotor) at a best guess! needless to say i left the room as i was quite curious what would happen, and it was lucky i did as it accelerated to the point of rotor failure with a bang.
has anyone tried this before? i expected a longer spin down time or less input and no charging of the battery, instead the battery was going up at a rate higher than i have seen on the machine.
heres a circuit diagram, someone make it and see if it works, you need to move the slave coil untill you get the sec battery going up and the rpm going up, i was also running a winding on the coil that wasnt powered to collect energy thru a diode to the output bus.
I thought id share this, obviously i have no working machine now, so i cannot tell you if the battery charges or not.
