recently i made my motor according to bedini motor. but it did not manage to rotate. I speculate my triggered winding is not enough current / voltage to open the transistor gate and make a pulse system....
1. my power winding i use is 1mm diameter and triggered winding 0.5mm .
2. the turns of solenoid is around 600-800 turns
3. magnet that i use is neodymium magnet
4. this is the circuit that i used
https://imageshack.com/i/n64kb6p
this is my motor
https://imageshack.com/i/n8du4mj
this is my solenoid
https://imageshack.com/i/na6vd7j
5. my core is around 2.5 cm in diameter.
6. when is hand rotate, my induced voltage obtained at triggered wire is 50mA -300mA....
7. when is test to switch directly power sourced 12v at power coil, the magnet is manage to repel...
so, when i assembled the circuit, my motor did not rotate AND I TOTALLY STUCK
anyone could help me?? please
this is my motor
this is my solenoid
