Size of cap dump needed
  • Size of cap dump needed
    [/URL]http://[/IMG]
    Starting Out
    John Bedini uses 31vdc in his video for charging a 12vdc battery.
    Figure twice the batteries ending charge cycle voltage of 15-16vdc.
    This is why John used 31vdc.
      Dumping
      20k, 40k or 60k microfarad
      For a small battery 20k and you will get a 2-4 amp pulse maybe.
      As the amp pulse gets bigger it takes longer to charge the big bank.
        Ok thank you for that info.... should i times the voltage i will need by the amount of battery’s or line them up in parallel... ?.. and why does it take longer to charge a bat bank with higher impulses ?
        Thank you for your reply all
          No it takes longer to charge a bigger cap bank before you dump it.
          Yes if you have 3 batteries in series like I do then dump at 90vdc.
          I have pallet size batteries.
            Thank you for your advice ....
              why do you have your batterys in series like you say rather than paralell ? its my thinking that in para It would share the discharge equally between bats...or does sending the discharge throu the bats in series have an advantage...?
