Bedini RPX Sideband Generators
This is a sticky topic.
  • #16
    Rife explanation
    Originally posted by Dingus View Post
    Honestly, I don't know very much at all about radio equipment, I'm just going by what I understand of what Rife said.
    I'm just saying, wouldn't it be just as effective if not better to simply use a signal generator or even computer audio output connected to an amplifier, wired to a step-up transformer, to one of those phanotron tubes, dual coil induction tubes or an antenna? If that works as I think it would, what's the purpose of the sideband frequencies?
    Listen to the video I posted with John's explanation - you are being told exactly what the methodology is and why.
    • #17
      I re-watched the video & I still don't really understand. There's only 2 things he's said that really oppose what I suggested.
      • "Without sidebands, you don't have a real Rife machine."
      • The modulation frequencies need to be higher than audio frequencies.
      For simplicity's sake let's just assume I'm using that Velleman HPG1 1Mhz Pocket Function Generator instead of an average PC, which is usually only capable of up to around 22khz. With that out of the way, he still hadn't explained why the sidebands are needed, nor my previous question as to why 3.1 MHz carrier is needed.
      • #18
        Bedini RPX
        Rife's methods eventually used the sidebands so that all frequencies are hit along the way. You need a function generator to be in a sweep mode to "bounce" frequencies at a certain interval into the fundamental and that creates the "ripples" that will hit all the "Rife frequencies". Machines and methods that focus on a single frequency using a function generator do not work and are scams. Crane was Rife's assistant and thought he could simply do away with what Rife was doing and use a function generator and focus on one specific frequency and it never worked, lots of people got ripped of by him, etc...
        If you have a Rife microscope and find one particular thing and one particular frequency that can be used for one particular thing, do you think that frequency will always be the same? The answer is no because things change and evolve and it can change a bit so the original frequencies are not etched in stone. There is a certain margin of error that can be done and Rife even indicated that the frequency can be a certain ways off and with the sidebands, you hit them all without knowing the exact frequency. The microscope is no longer needed since it showed the basic frequency ranges for different things.
        With 3.1mhz as the fundamental, I did state that you get the strongest sidebands. With the other frequencies, 3.2, 3.3, etc... the sidebands that hit all the frequencies are down the scale a few spikes away from the fundamental, but with 3.1, they're exactly right next to the fundamental meaning those sidebands have the strongest power. It is as simple as that.
        • #19
          is this single sideband (if so is it USB or LSB ?)
          or double sideband ?
          • #20
            double sideband
            I believe it may be double sideband since the fundamental frequency is also there at the same time. If the fundamental is considered the carrier, then it is double sideband.
            Look at post #11 where I showed John's video - you can see it on the spectrum analyzer.
            • #21
              Bedini RPX
              3.1 MHz Sideband Generator
              NEW 1 YEAR GUARANTEE
              Although we have a NO REFUND policy for these units, we are now offering a 1 year guarantee! If your unit stops working within one year from the time you receive it, just send it back to us and if we can't fix it, we will send you a new replacement unit.
              MADE IN U.S.A.
              Our new RPX Sideband Generators are built right here in Spokane, Washington, USA and are assembled by a professional company that specializes in surface mount circuits. The quality and workmanship is guaranteed per the new 1 year guarantee above.
              Yes, we understand that other countries manufacture fine quality products too, but we're choosing to support a local company that is right here in Spokane, Washington, which employees people right here.
              BUYER'S AGREEMENT PAPERWORK PROCESS ELIMINATED
              Instead of having to sign a buyer's agreement and send it to us by mail like before, you can simply read the buyer's agreement on our website. You can simply agree by clicking the buy button at the bottom, which means you automatically agree. Simple!
              WE NOW TAKE PAYPAL!
              We no longer only accept checks, money orders or Western Union payments. Simply make your purchase with PayPal! If you wish to send us payment by other means, you can do that too.
              VELLEMAN HPG1 POCKET FUNCTION GENERATORS AVAILABLE HERE & WE WILL PRE-PROGRAM THEM FOR YOU FOR THE RPX SIDEBAND GENERATORS!
              We are now distributing the Velleman HPG1, which is your most economical option for a function generator that must be used with the RPX Sideband Generator.
              We will even program it for you! All you have to do is hook it up and turn it on - simple! This is only available in the combo package.
              RPX COMBINATION PACKAGES AVAILABLE
              You can now get the RPX Sideband Generator in a package together with the Velleman Function Generator, Talentcell Battery and the required cables all in one purchase!
              The only think you have to do is strip the ends of the cables on the banana plugs and connect them to your own electrodes, pancake coil or whatever method you want to use to transmit the output of the RPX Sideband Generator.
              This will save you a lot of time and effort by getting everything in one single purchase.
              BEDINI RPX SIDEBAND GENERATOR
              • #22
                Goodbye velleman hpg1!
                The Velleman HPG1 is a small portable signal generator that we use with Bedini's RPX Sideband Generator. The audio signals bounce off of a high frequency fundamental and causes other frequencies to ripple off that hit all the REAL Rife Frequencies. The HPG1 is affordable and works well but Velleman is discontinuing it. Therefore, we purchase the company's entire remaining inventory and there are only 20 something units left!
                That means that the RPX Combos right now will come with this HPG1 and once they're gone, they're gone! We will be forced to go with Velleman's more expensive replacement unit, the HPG1MK2 that could add more than $50 to the Combo price. Get your RPX Combo at the lower price here: Bedini RPX Sideband Generator
                • #23
                  Would like to hear some feedback from RPX owners
                  Hi, I completely understand that A & P Electronic Media does not want to make any claims whatsoever for this technology. And that it is intended for experimental use only.
                  But (just like with Amazon product reviews) I'd like to see some comments from users about how satisfied they are with their units. And what kind of experiments they have been conducting.
                  I realize that no claims should be made by Aaron or the owners of the units. (Such as RPX will do this or fix that.) But at least the owners could say what kind of practical uses they have found for their RPX. With the readers understanding that their mileage will surely vary.
                  Best regards, William
                  PS I am familiar with Rife technology, but have never owned any devices.
                  • #24
                    You can see what some are saying or asking here: Bedini RPX Sideband Generators more active than this forum on this topic.
                    • #25
                      Bedini rpx sideband generator - new signal generator to be included
                      BEDINI RPX SIDEBAND GENERATOR - NEW SIGNAL GENERATOR TO BE INCLUDED
                      We sold out of our second production run of 150 RPX units and just received our third production run of another 150 units. This is the most sought after Rife machine on the planet hands down!
                      The signal generator we were using was the Velleman HPG1 and we actually had to buy out the entire company's remaining inventory and we're just about out of them. Velleman has a replacement HPG1MK2, but the cost is higher and they don't even come with a rechargable battery pack built in. It looks like a great little unit, but we're not that interested in paying more for less and we don't want to charge more for less.
                      Therefore, for the time being, we're keeping the RPX COMBO price the SAME while providing a function generator that is way more robust than the HPG1. We have a small number of these units being shipped to us right now and these will be included with the next COMBO units that get shipped out. It may be 1-2 weeks before your COMBO can be shipped, but it will be well worth the wait. If you're just ordering the RPX unit by itself, it can ship ASAP. If we have enough interest in the new signal generator unit for those who already purchased an RPX or RPX COMBO in the past, we will consider making the signal generator available as a stand alone item. Otherwise, we will only offer it in the COMBO.
                      Check out the new Signal Generator here - available without a price increase for the COMBO: Bedini RPX Sideband Generator
                      The most authoritative expose on what Rife technology was really about, get John Bedini's DVD and Book set here - it will debunk all the misconceptions: Bedini RPX - Book & DVD Set
                      • #26
                        Wow that is a deal, let me think about it. That is low priced.
                        Are you sure you want to go that low? Well anyway people
                        will get a great bargain, you always come thru Aaron, Thanks
                        Let me study up on this and I'll get back to you. I hope there are
                        some left by the time I get back.
                        Thx Aaron for answering my questions.
                        Bedini RPX - What are the sidebands generated?
                        https://www.youtube.com/watch?v=v1sjADHELRI
                        • #27
                          Now I am catching on.
                          The REAL Rife Machine by John Bedini - Bedini RPX
                          https://www.youtube.com/watch?v=whfg6om-n_c
                          • #28
                            RPX System
                            While i do agree with the RPX system and it does seam to do it's intended job of what Rife did as i have been researching it for quite some time now i have to say without an MOPA RF amplifier this system is totally useless. it is completely impossible at these extremely low voltages to get any results what so ever.
                            Rife's original system output just the main MOR freguency that was so intense it could be detected for 8 miles. since the FCC shut him down he had to come up with a better idea.
                            advanced to #5 he used a carrier wave and modulated it with an audio signal. why, because the audio frequencies with out an RF carrier will not enter the body past the skin. he sure didn't use .5 watts of energy he used 50 to 100 watts of energy.
                            so again i have to say the RPX system without an MOPA RF amp is useless in it's self but matting it with an MOPA RF amp will get you to the point where you want to be.
                            MM
                            • #29
                              pumpwave
                              MM
                              I haven't been here in a very long time!
                              I've been researching this behind the scenes for a very long time. You're not understanding what the RPX is. There is a very low frequency square wave around 8 cps that the 3.1mhz and sidebands are carried on and that square wave is what delivers it. That isn't theoretical - that is exactly how it works and is why it can work at such low power. Bedini is a GENIUS. Watch his books and videos on the subject at least and then you'll understand it. That causes the "pump wave."
                              • #30
                                Rpx
                                Yes, i do understand it and have collected all i can and i am telling you the output needs to be hooked up to an amp.
                                there is no 8 hz wave and no the others are not carried on it.
                                the audio wave modulated the 3.1, 3.3 or 3.8 carrier wave that caused upper and lower side bands.
                                Rife machine's output 75 watts and was left there.
                                audio signals can barely penetrate the skin let alone the cells that is why the high frequency carrier wave is necessary .
                                read the part on skin penetration and you will understand.
                                if you watch Bedini's video you will see a MOPA RF Amp he designed and used not the RPX because it has to little output to do anything.
                                the number 5 Rife was designed by Hoiland to hide the original frequencies put out 75 watts RMS and 150 peak.
                                MM
