Hello everyone,
I thought that there hasn't been much discussion about the type of charge in these two systems going into the battery, so I decided to start this thread.
What is the real difference? The capacitive discharge chargers seem to convert the negative energy to positive before giving it to the battery, but the SSG circuit seems to give negative energy directly to the battery. What happens when one rotates batteries in the SSG circuit, which it is told not to swap the batteries? What is the difference? Does a battery charged with SSG put out negative energy?
I don't understand this difference quite well. Has anybody got better insight to this? I hope Peter would help us understand the difference.
Elias
Elias
rude electron gas). When you start pulsing, even in sloppy circuits, this ratio starts to charge to more radiant and little less current. If you have ultra low capacitance, high voltage discharges at high frequency, you will be charging with super high radiant but not enough current to get the battery in real charging mode (the fluffy charge that doesn't really pull a load).
The positive lead of the cap bank is connected to the charging battery bank consisting of three 12V 7Ah batteries in parallel. I am pulsing those batteries on the negative lead using a solid state relay rated for 250VDC and 70A. The relay is switched using a 555 timer circuit which gives it a short pulse every 6-7 seconds. This allows the caps to fill to about 15V before they are pulsed to the batteries . There is also a LED in the 555 circuit board, that flashes at the same time as the SSR, this way I can easily adjust the pulse width and the frequency. The primary battery is also a 12v 7Ah. The current draw from the primary is about 250mA. So far everything seems to work very good. Here are some pictures:
