You are going to have to hook up polarities correctly. All my coils are wound the same way and are placed the same way. This is due to the geometry of the rotor. If all coils are to fire at once then they must be aligned to the correct poles on the rotor at the same time.
It sounds worse than it actually is. A quick test by placing the coil and briefly supplying current directly from a battery will sort you out. You will see quite quickly how they must be placed, and how the current must alternate if rotation is to be achieved with the coils firing on all magnet passes.
