Done with straping the magnets
@ Patrick,
Real thanks for the safety advice
Makes me feel more confident now for trying higher rpm. Put in an aluminium strap of 2thk around the ends of the magnets . Post pictures a little later today ...
How bad did your setup get hit when your magnets flew off ... Are you still able to run the motor??
Did you happen to try adding more coils in parallel in the reed switch circuit ? Does it sound ELECTRICALLY stupid to try putting all the coils in parallel on the same circuit ??
@ren,
I couldnt positively decide between Aluminium and SS on the video posted . I have made an Aluminium 2 thk strap . Would you see any disadvantage of using Aluminium for the strap ?
Yeah the circuit seems more doable after seeing the full bipolar circuit in operation with the trigger wire setup
Rick's kit is cool . It provides the replacement for MPSA when using the reed switch circuit . How did it go on the large motor you were building . I have got 12 ceramic magnets 6 x 4 x 1 and was hoping to do your tutorial sort of setup !!! Any tips ...
Did you try paralleling coils with the reed switch circuit as well??
Thanks for the help Patrick and Ren.
Bhargav
@ Patrick,
Makes me feel more confident now for trying higher rpm. Put in an aluminium strap of 2thk around the ends of the magnets . Post pictures a little later today ...How bad did your setup get hit when your magnets flew off ... Are you still able to run the motor??
@ren,
Rick's kit is cool . It provides the replacement for MPSA when using the reed switch circuit . How did it go on the large motor you were building . I have got 12 ceramic magnets 6 x 4 x 1 and was hoping to do your tutorial sort of setup !!! Any tips ...Did you try paralleling coils with the reed switch circuit as well??
Bhargav
!!! I got the kit running to about 3500 rpm on 1.7 amps at 48V . Put in 7.5K ohm in place of the 4.7Kohm trigger resistance. Put in 750 ohms in place of the heating 220 ohm and ofcourse tried out 3.3Kohm in place of the 470 ohm in between legs of the MJL .
sounds like fun.
