Well....
I checked RPM with my tach meter.
I will have to check my charging rate with my spread sheet, I has not been climbing very quickly, but I have changed many things about my system.
But, mind you I am using GOLF cart batteries. and only one coil SSG. And... to add more varibles I have added the solution to the batteries that desolves the sulfate from the plates that Aaron suggested. ( too many variables to for me to give an accurate idea now). I think I will pull the coil off and check it again. I bet the charge rate will go up but... again old golf cart batteries.
I am now using ceramic skateboard bearings. The hard drive bearings could not take speeds over 1,100 RPM. ( considering I have 6 lbs of PVC and magnets I could see why
I first tried using a spare coil that I had with 20 Gauge wire that had no effect.
I then got in today my 8 relays for my battery swapper. One of them is rated for 12V. So I tried one kind on it and immediate results. But... I have not checked for voltage increase.
Since I have no scope, I have to ask the question what would Nicoli Telsa do
since he had no scope. ( I bet he would buy a scope
But, I was happy to see the RPM the same and the amps drop. Charging may be a factor...
) I first tried using a spare coil that I had with 20 Gauge wire that had no effect.
)But, I was happy to see the RPM the same and the amps drop. Charging may be a factor...
