RE: video
Watched the video, VERY nicely done with the split screen.
I now see that you are counting the lines on the rotor to determine the number of pulses. what did you use for marking the lines? I am thinking of taping a black paper on top of my rotor to find get the number of pulses mine is using.
I am thinking we have a target of getting the most charge for the least amount of energy being pulled from the primary battery.
Suggestion for testing this.
We pull a battery down to a resting voltage of say 12.5 V Then we test given a 2 hour period for a given pulse method. We then load the battery with a given load and bring it back down to the 12.5 point. Then we do the same with another pulse etc.... I am thinking that we should be able to see a pattern emerging of which is the best charging method.
The trouble can be if we are using sulfated batteries, this can really mess up our results.
Since I have added the VX additive to my batteries, 5 of the batteries no longer charge back up to same levels they were before
However, the others are doing fine, they are consistant and are charging very well. With these I may experiment with the choke, and the Radiant soup method. I was considering aluminum foil....
Thanks for the video, it helped me to understand the led method more clearly.
However, the others are doing fine, they are consistant and are charging very well. With these I may experiment with the choke, and the Radiant soup method. I was considering aluminum foil....Thanks for the video, it helped me to understand the led method more clearly.
500 ma input 95 ma output.
