Originally posted by citfta
In the past I've found much the same results as you've indicated with
using Schottky diodes, although what I've not found yet is how the transistor
or SCR would react when the potentiometer is such that it will only let through
sufficient current to turn on the Base or Gate when the Schottky diode is fully
open.
Perhaps the voltage of the charging capacitor would pass through the
potentiometer and meet with the Schottky until it is 90% open, and only
then would there be sufficient current to open the transistor. ??
Other than this, and the diac, there seems to be one other method
utilizing an op-amp.
[ The Schmitt Trigger ]
[ Schmitt's Comparator Circuit ]
[ Google Search - Schmitt Trigger ]
I have another device I will be showing soon that is designed to be powered directly by a dedicated panel, eliminating the charge controller
