Hi all, i have built a bedini ssg setup that seems to work as predicted but i have a few questions.
1. Assuming all magnets around the wheel are North facing out, should the coil core facing the magnets produce a north magnetic field?
2. The coil is triggered AFTER the magnet passes the core. With a compass i can see the invisible south pole in between the magnets. Does this not mean the coil would need to produce a south magnetic field to push the wheel?
3. Does the coil produce a magnetic field during the field collapse when passing the signal in to a charging battery or other load?
Thanks.
Thanks.
