A year ago, I followed the standard Bedini SG circuit replication completed successfully.
This is one of my friends do the same circuit existence problems;
Coil ---- 23,26 (AWG) enameled wire, and about 600 turns;
Coil Core ---- Radio AM antenna ferrite magnetic stick (crushed after the filling into a powder);
Transistor ---- MJE3055T;
Resistance ---- initial state selected 10 ohms (series 1K adjustable resistor);
Magnets ---- Φ10x9mm 6 Ceramic magnets
Battery ---- 10.8V Ni-MH rechargeable batteries;
Problems are as follows:
1) Use of 1N914 Circuit did not respond, replace the 1N4001 circuit appears the operating characteristic (oscillation coil loud voices), 1N914 should be SG circuit the first choice, but now use it not work. why?
2) resistance temperature is very high! Variable resistor (1/2W) because of high temperatures, burning smoke.
3) Although the circuit oscillations, but the motor still not work.
Thank you to help!
Xu Yuan
Thank you to help!
Xu Yuan
)... do you have any higher ohm resistors you could use? around 100 ohm to 300 ohm?
