Hi Guys,
I am busy building my Second Bedini, the first ran but was highly in-efficient, But that is due to a bad build with recycled equipment.
I have a few questions before i start building my 10 coiler:
Does anyone have a Schamatic of a 10 coil system?
I have seen the following http://www.energeticforum.com/attach...-schematic.jpg
I see that there is a single trigger coil to fire all the coils, so does this mean that i need to wind 1 Bi-Filar coil and the Slave coils will all be single coils?
I will be building my Rotor in a sausage shape with 2 sets of 5 coils set at 90 deg from each other so should i rather have 2 trigger circuits?
_____________________ Rotor
__ __ __ __ __ Magnets
[] [] [] [] [] Coils
I also do not see in the Schamatic above where you add the Neon Lamp, Is this necessary?
if i only need a single trigger coil then would i gain anything by making Bi-Filar coils of the same guage wire then making it a 20 coiler? (18 power + 2 Trigger) if so does each coil have its own circuit?
Regarding Magnets, I have very strong Rare earth macnets 30mm X 3mm round is this OK?
What should the Gap be between the magnet and the coils or does this not matter?
Finally what should the resistance be on the coils?
Any help with this will be great
K-
K-
