Do you need answers?.
I've problems with my violin too ...
This is your threat so you need answers.
Look my tip about 5 minutes off and on is a deeper study made by me, I've wasted many many time charging and descharging the battery:
First, if you batts are brand new you need keep them in good condition, please avoid discharge them fully, I've damaged two batts. Disconnect the circuit when charge goes below 12 volts, this keep the batt like new per years.
Second, you can make test a interrsting finding another batt, try to charge two batts in parallel is possible recover more energy than one battery. Batts don't takes energy at the same rate that you extract energy from them. Charging two batts you can recalculate if you're recovering more energy than one.
Third, with three batteries you can try the tesla switch mode, by putting two in series and putting the charging batt in parallel. I've reached 80% recover guarantee in this fashion without tricks, maybe is possible get more with more batts in parallel ? I'm not sure.
A little gift look in the attach the circuit please carefull if you make a wrong connection you can blow up the transistor... It's incredible but anybody has tested this circuit for now is my idea haha.
The circuit can recover a little of the energy wasted like current, if the coils are low impendance then this circuit can avoid heating on coil or transistors and send the energy to the charging battery. When transistor switch off then perfectly sends the energy to the charging battery with the correct polarity. C1 capacitor can be needed if the batt are small the cap match the impedance, normally I use my big audio cap 1.5 Farads, but I think 2000 - 15000 uf is ok.
80% eff for me is begin with the batteries fully charged correctly with voltage equalization etc, and discharge one with a bulb and calculating watts consumed, then putting the batt on the devices and measure how many watts are needed to recharge the battery. Then you could rotate the batteries and use your devices (like motor?). But Hey! you sooner o later will notice a fully charging is necessary to keep the battery is good condition, then you maybe will need to use a battery charger or well a Bedini solid state or connect your devices on wall transformer etc, To recharge correctly your batteries.
Regards...
Regards...
