  • oops! 24.
    Did you make a spool like John said? I was assuming that your resistance 4.6 and 6.5 in parrellel would be 11.1 ohms so did you get to the 14 ohms?
    Also I just realized there is a latency created in using two gauges of wire like that, and I wonder if this is one of the differentials John is talking about....
    Learn while we build righto'
    Les
    • Originally posted by Les_K View Post
      oops! 24.
      Les
      Hi Les,
      I should point out an earlier post....
      "@John B, I measured the resistance of the coils - the 2 thicker wires are 9.4 ohms each and the 2 thinner wires are 16.1 ohms each."
      I will measure the total parallel resitance of all four strands tonight and post it to the group. JB suggested 14 ohms total. According to my parallel resistance calulator I should be at 2.9675 ohms, but will confirm when I get home. (No where near 14 ohms!)
      BTW, if I "lock" the rotor over the hall so the coil is energized it pulls 2A from the primary.
      John K.
      http://teslagenx.com
      • Originally posted by John_K View Post
        Hi Les,
        John K.
        Thanks, I thought I was bonkers. When I ran the numbers it was looking like I need 4140 feet of each strand? Two #20 and two #23.... I know that I have to be misunderstaing what he was saying. After all, I thought I read all the posts and yet missed this one...mmmmm Maybe been at it to long!
        Les
        • @Vissie
          Read this post again. John tells Jerdee his setup is for the most part correct. READ JERDEE'S DESCRIPTION after the picture.
          Matt
            John K,
            How big is your coil ? what is the Z in DC Ohms?
            John B
              Could be that they are wired backward. Wound the same direction just wired backwards so they are pulling. After all look at the offset.
              It would also produce an "interferometry" situation as the spikes coming out of the slaves would be reversed from the primary.
              Big potential as well.
              Just me thinking out loud though....
              Matt
              Matt I think your right! This would also explain why the rotor would kick backwards at start up and why the rotor speed is not very fast.
              The other thing I still dont understand is why JB wants to pulse the output with an SCR. I have done quite a bit of testing and found that using an SCR is not as efficient as letting the spike go directly into the battery after the bridge.
              This question is a little off topic but after watching Peter's Lockridge video I was wondering if anyone has tried to partially incase the outer portion of their coil in iron to concentrate the colapsing field.
              Mark
                @Vissie
                Matt
                Hi matt
                Then I think we must assume it is correct.
                It won't be to difficult to just swop the wires of the slave coils to test the results once we are there.
                Vissie
                Jeremy's quote:
                The side coils are opposed pulsing a weaker south pole to create attraction, while the Main center coil is creating a huge repulsed north field when switch goes on.
                • Bedini GT3
                  To All,
                  I have been detained helping out with a friend that has died, so I have been busy.
                  I also will not be here for one week but do not think I have left the group.
                  I will state this again I never use Neo magnets with these motors because they do saturate the cores I do not want that at all. If you saturate the core then you must use a lot of current in the system I do not want that either.
                  The only way to use that magnet is like I did by placing the magnet behind the ferrite magnet to shape fields. When you shape fields you can cause them to switch magnetically. If you build a Mag Amp out of the monopole coil you will see why, and do not think that you can not do that I do it all the time. Also the welding rods have changed from the time I first started using them, the iron retains a magnetic bias in the new material, not good.
                  I have always said do not use Neo magnets in my monopole motors, the only place you should be using them is in Iron-less coils then they work fine. If you use this Neo magnet you will fail at what your doing and I'm not going to be able to help you get yourself out of trouble with this machine.
                  John B
                  John Bedini
                  www.johnbedini.net
                    To All,
                    John B
                    John,
                    Thanks for the info on the Welding rods. Do you, or anyone, have suggestions on where to get the right kind?
                    Also Please accept my apologies, I looked at my post and can see how this could have been misunderstood about Neo's. I only tested one piece of welding rod. I did not mean to imply running a machine using Neo's.
                    your corrections are a great blessing to us in our growth here. Thanks again John.
                    Les
                    • Hi John B,
                      I'm sorry to hear about the loss of your friend. Thank you for the additional detail on core saturation as well.
                      Thank you also for the idea of building the mag-amp from a monopole coil. I had come recently to realize the mechanical SG is a rotary magnetic amplifier. This makes some sense to me then that you would suggest this as a venue of study. I just finished making myself a 1000watt mag-amp (which so far can only actually thru put about 400watts with a 40 watt DC bias). Given that its comprised of three separate but same model 1000va trafos, its not designed to be used this way which is probably why the skew in large DC bias being applied.
                      The way I would expect one could make the Monopole coil into a mag amp would be to setup a 3 wire stator, 2 wires in normal SG layout... 3rd wire connected directly or via caps to the sine source. Then the SG should switch based on the frequency of the AC applied to the source isolated winding eh? Then when only one half of the sine flows the stator it should trigger the DC oscillator to pulse... I'll give this some more thought.
                      Thanks again, Merry Christmas!
                      Gene
                      To All,
                      John B
                      • John,
                        Those of us who have ever lost someone in our lives know what you are going through, and you have our deepest sympathy. It is amazing that you even took the time to come and post what you did to let us know. We appreciate your time and efforts on our behalf. You and those close to you, will be in our thoughts.
                        To our group.
                        As a member of the Monopole3 group I am continually amazed by the people who log onto that site having made some change in John's design and then wanting help with figuring out why it won't work. And they have an EXACT schematic to follow with specs on every part! This INCLUDES things like using neos, different sized wires, the wrong transistors, etc. If I was the moderator of that site my response to EVERY one of their questions would be, "Build it exactly like John said. When you have done that, then we will answer your questions. Until then, do not bother us."
                        Here, it's a little different. We are all searching for answers and feeling our way. We have a lot of information, but not specific schematics and specs on every part. There are some brilliant folks in this group, and I value ALL your opinions, even when some of the answers turn out to be the wrong ones, because it provokes thought and opens our minds to new possibilities! I just wanted to take this opportunity to thank ALL of you for your hard work and invaluable contributions to this and other threads, and for the friendships we are building here. Those friendships, this collaboration, and this work will stand long after some of us have moved on. I wish all of you a happy holiday season.
                        "Try Not! Do! Or Do Not. There is no 'Try'!"
                        Yoda
                        "All truths are easy to understand once they are discovered; the point is to discover them." Galileo Galilei
                        YouTube - 11Turion's Channel
                        • Well put
                          Hi Turion,
                          Well put. I am particularly enjoying the fact that John B is really making us think, kind of like have all the pieces to a jigsaw puzzle but no picture on the box
                          I'm one of the moderators of the BM3 group and yes, you would be surprised how many times we moderators have to tell people to build to spec. I was the same when I first joined that group and was probably one of Rick's worst nightmares at the start. The question about neos usually comes up a couple of times per month.
                          Anyway, I made some progress on my build. I think I figured out why John B has the timing wheel magnets so close together and why he says the fields overlap. It's all got to do with the dwell time. Think about what the coil/s are doing when the hall switches on and off and how to take advantage of this. It might be hard to work it out if you don't have a machine running in front of you.
                          John K.
                          John,
                          To our group.
                          Yoda
                          • Looking at the pictures of the timing wheel I can see that the magnets are spaced about one magnet width apart.
                            My wheel is only 30 cm and when I place a little round neo near the axle to build the timing part the magnet lifts up on its side and start to roll around till it get stuck to one of the outside magnets.
                            Maybe my outer magnets are too big for this small wheel. I will first try to trigger the hall from the outside magnets although I would not be able to adjust the dwell by using rectangular magnets.
                            I was successful with the etching of my bipolar switch PCB and will built and test it today. The wheel still needs to be mounted and it looks like I will only get some of the stuff I need for that after Christmas.
                            • hi all,
                              ive been following this thread on & off since it started, and also watched the few youtube videos showing the BFW working etc...
                              but im still puzzled as to.....what does it actually "do"?...... ie....what is its specific claim? (im assuming theres some claim of OU in it somewhere )
                              so, my honest question.......what exactly does this machine "do"?
                              thanks,
                              David. D
                                Hi Vissie,
                                I think that the timing wheel magnets are closer than 1 width apart. It's important that the fields can overlap. That way you can get a >50% duty cycle on the hall if you need it. Have a close look at the pic John B posted of the timing wheel with the red lines drawn on it.
                                I don't think it will work with using the outer magnets to trigger the hall. The timing wheel magnets should be ceramic discs, not neos. I've found that the fields of the ceramic discs spread out from the disc a little bit, so the hall can trigger before it is physically over the magnet.
                                Good work with the PCB!
                                John K.
