Originally posted by txaggie00
I had 3/4 inch magnets at about one inch apart. and it was pulling a lot of current and when I posted the scope shot John K said it was not quite right so I went to 1/2 inch magnets at the same distance from center as the first ones. They are much better and easier to control. When I calculated out my design I discovered that you can go closer to center with smaller mags and further out with larger and it makes no difference. Draw it out, you will see what I mean. Except in the physical size and specs on the specific hall you are using. I got some 3120 halls from mouser that have the same data as the 3020 halls JB had been using.
As to visual responses My meter will kick as high as three amps at first and then as it speeds up it will settle at a lower 700ma to one amp. I have a 75 volt 90 volt peak, 12,000uf cap and it charges within the second cycle of the wheel using tree lights as a load ( I am waiting on parts for the pulser). I tried a 300uf 250 volt cap with no load and after two pulses it was at 250 volts. I stopped the wheel quickly!
I have no idea how high it would have gone. I don't have any higher voltage caps to play with. So a word of caution on that. Anyway make sure the emitter is connected to the 220 ohm resistor or in my case I am using a 680ohm.
Hope that is helpful
Les
I am using a MJ2955 not a 8599 or MJE2955.
but this must be a very low impedance coil with a very low inductive reactance and it must run at no more than about 28 RPM (16 *28 = 448/60 = 7.46 HZ) to hit resonance. and if you are not there then your CE current will be very low. And now that I have said all that I realize clearly why Scott has the only coil with the right impedance. And perhaps why my circuit is not manifesting the same heating problems....
