YouTube - theDaftman's Channel) who showed you how to make one.
SO, i did. Im 23, i have a BTEC in aerospace engineering. Thats as far as my knowledge goes when it comes to electronics, im still learning! I had my motor running a couple of times before Christmas, i will put my hand up and say although it was running, i was still failing to understand what was going on. I let the motor sit in a cupboard for about 6 weeks, and i finally got it out yesterday, if been lurking this forum for a while and it seems you guys are all in it for the same reason, making it work. Plus if you look enough there are answers scattered among the posts
A friend of mine said i could have 4 "dead" 12v batteries from motorbikes that i can put on my Bedini motor. He said they had no charge.
I have left my results in my workshop, il get them later and post some more details THIS EVENING but this is essentially what happened.
My run battery was reading ~11v and my charge battery was reading ~7v, i then span the rotor, this is the freaky thing. My run battery started CHARGING as well as my CHARGE battery!!!
Now most of you may be thinking well he had it wired backward, i have a video that i will post as soon as i can find the usb cable and i checked SEVERAL times but yes, the run batter was charging. Im using the wiring diagram from thedaftman.
It ran for about 4 hours before randomly stopping but during the run i put some meters on, the charge battery had fluctuating voltages, started at 7-8v and nearer the end of the run it was between 10.5. and 11.5v. The run battery was charging steadily.
Again these numbers will be updated when i get my notepad back along with a video
Please ask for anymore info on it and il try and provide.
All the best,
Luke
All the best,
Luke
to the forum.
