Originally posted by John_Bedini
Bedini Earth Light
Exothermic Reactions
Allwest,
What is not simple?, it's pretty simple to me what is going on it's on youtube.
Adding salt what for what do you gain? And what is the list or do you like typing. You can do anything you want until the group is locked for safety reasons. I have seen it happen before here. It could be a safety issue to some people that do not know what you have done with the experiment. The Earth Lights Group is not about Exothermic Reactions that generate heat and possible danger to others, what is the group about here?. You wont be LOL if someone gets hurt or maybe you will. Been around a long time Allwest know what I see.
John Bedini
www.johnbedini.net
John,Originally posted by John_Bedini View PostAllwest,
Allwest, what is not simple, it pretty simple to me what is going on.
Adding salt what for?
If you think that a 3% Hydrogen peroxide and salt solution is dangerous in this application, then I must bow to your concerns
This cell will work minus the 3% Hydrogen Peroxide as well, it just takes longer for it to form
Note: My point being on the above listed posts is: All salts are not the same. Some form crystal structures that are more conducive to power on these cells, such as K2Ca2Mg(SO4)4 - 2H2O
Allwest,
Well do what you must do. You would be surprised what little things can do to you. I have worked with Heptahydrates here, nice formula. really great with Magnesium.
So just answer the question, what are you trying to do with the magnesium that has not been done here before. Are you trying to build a special coating of some kind?
Note: My point being on the above listed posts is: All salts are not the same. Some form crystal structures that are more conducive to power on these cells, such as K2Ca2Mg(SO4)4 - 2H2OJohn Bedini
www.johnbedini.net
I do not have much time these days for fun, business is getting in the way of fun
R&D takes so much time (as you know) One line I was trying for with interesting results, is by adding Copper to the cell when it was forming I was trying for K2Ca2Cu(SO4)4-2H2O crystal structure on the Mag
You can probably tell us more than anybody else how this cell differs than any other cells
Best of luckLast edited by Allwest; 09-28-2012, 02:21 PM.
leightonite
Allwest,
you know that if your trying to get energy from something that is leightonite is only going to produce about 1.5 Ma in a cell. How do I know because I tested it when I was talking about Sulphates in rock form. But anyway if business is getting in the way. Then I guess this does not make a living for you does it? The group has been all through these chemicals and some good rocks that generate energy. I have seen things explode by accident. it's not good when it happens and I never want to see people hurt. They may not do it like you and that is the only reason I bring up the safety issue here. It's the little things that get you, it's always unseen with mixing chemicals. One of the biggest problems is galvanic action with magnesium. that is why the rest of us moved to lead crystal forms. Anyway good luck. Oh, Leightonite is very interesting mineral.John Bedini
www.johnbedini.net
I understand why John and others have gone to the lead plates and Alum cells, to avoid the breakdown of the metals, and oxidation.
But, can't we make a cell that can be charged, by solar, or whichever way to charge them, but can also have a perpetual output of their own. Like with using stainless steel for the positive plate, and lead or some other electrode that would give a voltage, and some current.
Nick_ZLast edited by Nick_Z; 09-28-2012, 11:52 PM.
I think only John can answer this correctly. I will reformulate my question: Should I just give up on the magnesium/copper crystal cell or not and why? I have my alum mag/copper cells running right now but I dont want to spend 2 years of my life thinking it's the way to go and suddently see the cells dying in front of me....Please put the lights up on this! Just want to know whitch direction to take from now on..Originally posted by Nick_Z View PostI understand why John and others have gone to the lead plates and Alum cells, to avoid the breakdown of the metals, and oxidation.
Nick_Z
Did I waste my time
CrystalDipoleMatrix,
Ok I guess I will start here, As you know that we all started very early with the Alum Magnesium battery. I myself do not think you have wasted any time building these batteries as they pack a real punch for just a little water. Here is what I was facing with the group, I could not make anybody understand how important the cell was. I did my best to explain that loosing 1% to 2% of the magnesium was meaningless here, yes the magnesium oxidized to a point. The truth is I have been running one of the cell for over two years just by adding water. However, I do not stop here as I have been converting Lead Acid to Alum batteries since 1985 so I know a little about the chemistry and what the currents do. I saw Lidmotor get excited about using Alum with Lead and I knew that this corrosion factor would be like nothing else ( NONE). I wanted to jump right in and help to get something that everybody would be happy with at the same time gaining large amounts of current for extended time, I could not give the group the same amount of current with Magnesium Alum copper and no one else could either. The most I could get was 1 Ampere and not for very long because of the impedance changes in the crystal Hydrate.
I could not talk about Marcus Reads cell because of what I promised and signed with him. The Reid Cell can not give you the current of the Magnesium Cell with Copper and Alum, yes it is a true Free Energy device but very limited in power, anything more then 2 Ma and it just goes dead and you must wait for it to recharge itself. Your work with the Crystal battery is not in vain at all, you did not waste your two years.
I got tired of hearing it's galvanic it was like some kind of godsend buzzword that no one ever heard of. I plainly stated that 1 to 2 % in galvanic action was meaningless as far as the amount of power you got out of it. Yet, I had to put up with Dumb Crap and everybody knows from who, even when I left the rambling kept going on, so I just told him off, and yes Stupid Dumb Crap that was not going to give anybody anything for current, well maybe a Mr. Potato Head Clock, big deal a lemon will do that.
But see, this was carried over to other groups and boy did he complain to the biggest Monkey of all who will never show you anything he builds.
Back to the Hydrate Lead Cell, The Crystal Light Group was about learning how all this works and what can be done with rocks and compounds and metals. We all must start somewhere and this was the best place to start. Everything I said about things here were moved to other groups, and those groups claiming John B talking in the third person all the time and the comment being, I just hate that, well those people should look up what the third person is because they do not know anything except what they take from others. This is why I moved my Monopole groups to a new board and started a new crystal battery section so I could get rid of the Dumb Crap, that is not going to get you anywhere building things. But did you waste your time, HELL NO. I have built very big cells that do the 1 to 2 amps but the cost was not something people would want to spend right now, not in this ecomany. I did use Hydrates and had to buy them through my company. I spent my own money to try to help and gave the information away. I got nothing out of it, just more Dumb Crap. So I left to only check in sometimes here as I was asked to do. Did everybody waste time only the ones that do Dumb Crap.John Bedini
www.johnbedini.net
everything we build uses current.
Your the only one that can make that decision, I feel if your looking for a limited current for running led's in an emergency you have a winner for a few drops of water.
However, if your looking to run your house you have allot of work ahead of you. That is why Marcus is in trouble, no real usable current and everything we build uses current. Chuck builds the same crystal cells and lights his bathroom at night. I have seen Chuck build them and light many led's off one Crystal Cell. Now, Cream of Tartar slows the oxidizing down, but you can not use very much, one pinch. You should try both Cells as this is not very hard to do. My next video which I did not have time to put up today will show everybody some things they do not know about this type of battery. You can take the information and do what you want with it. People, I think misunderstand what can be done with Chemical bonds and what they can do with different currents when applied to them. Lead is no different here, except you do not have the same problem that you have with Magnesium, and it can be recharged for very little. You have not wasted your time learning all this and it's up to you what you want. The information is on the other group.John Bedini
www.johnbedini.net
Such hurtful things are said about me, but never the less I have kept a journal about my crystal cell research. I figured since it was about this thread i should post it here. It has my highs and mostly my lows. John don't think you're the only one who got insulted by others on your work. Here it is everyone *************
Edit: The Link has been taken down as requested by John. My real name was never important, it was about giving away the idea to everyone so that not just one person would prosper but instead many would. But what do i know i'm just a idiot.
Good bye everyone.
Last edited by ibpointless2; 09-29-2012, 04:25 PM.All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
