Kit Board For Hho Dry Cells
  • Kit Board For Hho Dry Cells
    We have specifically build an kit board for HHO cells completely made in Italy, this include special board with USB port for firmware updates and Suite for development of new firmware.
    That board (attached) isn't an simple PWM, you can admin via firmware some features, one the best is command positive and negative output indipendently including reverse of polarity.
    The board control the current of your hho cell (up/down) simply with two swicthes.
    The features inside this board transforms an DRY CELL into an generator that produce every same amount of gas when the power supply go to zero absorption.
    Actually we don't have tested on WET cells, we test next week.
    The cost of Kit board is 400 euro including cost of shipment in all world.
    The KIT Board for 12 and 24V is available from the end of April 2013.
    We accept pre-orders ,if you are interested please sent the order request to [email protected].
    Here videos from an simple test :
    fiamma prodotta con nuova scheda 25KHz - YouTube
    hho cell no current gas produced 400Hz - YouTube
    dry cell che produce gas anche quando non assorbe corrente - YouTube
    That is interesting how the current bounces up and down.
    But, is it a Stan Meyer Replication? No.
    Whether it is resonance, a problem with the power supply you are using, or something else, I find it difficult to accept that this is an ultrasonic/resonant effect.
    Looking at your videos, I can't even say that it is electrical resonance - I am guessing your circuit is programmed to vary it's output.
    For your information - that would not be resonance. That would just be a pre-programmed circuit.
    Regardless - you need to put your answers in a THIS thread, if you want to convince people.
    Treading on other people's posts - just to sell something - is confusing people - and irritating to those trying to share.
    If it is not the patented Stan Meyer effect, then why do you post advertisements in my threads? Please quit posting on my threads unless you are willing to talk about Stan's work.
    Please, stay here to sell your "beat" device. But, I would try to prove it first - BEFORE selling it.
      Heterodyne flame and cell test
      Today other test with heterodyne, the power consumption is reduced the 50%.
      Normally the cell consume 600W instead with heterodyne effect the cell consume 300W producing the same amount of gas.
      Here you can see the power of flame produced.
      test fiamma heterodyne 25/03/2013 - YouTube
      Here the test cell in action with power controller.
      test cell with heterodyne ON - YouTube
        Lpm Data
        tutanka
        Do you have an LPM spec on this,or efficiency data ?
        Thx
        Chet
        BE that change !!
          RAMSET, new video, I sent you the link.
          Can you help me explain that flow-gauge behavior?
          tutanka
          Thx
          Chet
            It would be convincing to use the hho gas to power a small generator to which would generate the power needed to operate the cell and circuit.
            Thank you for sharing
            Luc
              Luc
              For run an little engine 200cc without modifications you need an lower amount of hho, about 0.5-0.6LPM, plasma air and plasma ignition. If you add modifications inside the engine you need just 0.5-0.6LPM of hho using an normal ignition. In that case plasma air is produced internally to the engine!! I repeat again and again.. Meyer use the same concept.. air as fuel (plasma air) and hho gas just as igniter (free electrons)!!
                So will you be making this generator so we can see it working in a closed loop?
                This is the best way to convince the people
                Thanks for sharing
                Luc
                  Thanks for sharing
                  Luc
                  Sorry I don't understand why you are focalized on loop.
                  During my tests I have found that no NOx are needed if you want to obtain an stable reaction in the time. Exaust gas can be used just for HEAT because help to mantain the plasma air ionization. Meyer use exaust gas ONLY for that reason. In the suction phase of your engine you have enough air (78% nitrogen) inside cylinder and do not need additional amount of that for decrease the combustion rate. This appear also in Meyer system, do you think that Meyer use just wfc injector and do not suck air inside the cylinder ?
                    Hey Tutanka,
                    Maybe you should watch some of the Stan Meyer videos. In the Colorado conference, he talks about creating an air-tight system that only uses hydrogen, oxygen, and water vapor. He was moving in a direction to try avoiding Nitrous Oxides - not create it.
                    Take a good listen.
                      Originally posted by jonabel1971 View Post
                      Hey Tutanka,
                      Take a good listen.
                      I live on the earth and not on the moon!!
                      On the earth when oxygen atoms reacts with nitrogen atoms you create also NOx
                        You claim that your circuit uses 50% less energy then normal electrolysis. You also claim that Nitrogen from air will maintain a plasma state in an engine so less hho gas is needed.
                        I say build this engine!... and prove to us that it can run and have enough power to turn a generator to sustain the electric power needed for your circuit making the gas for this engine to continue to run the load and a big big bonus if it can run an extra load at the same time.
                        We all know normal electrolysis needs more electrical power then an engine can produce by using hho gas. So prove this wrong and you will have the worlds attention
                        Without this, do you seriously think anyone will buy your circuit just by seeing an hho flame burning something and the current on a power supply fluctuating???
                        Am I the only one here thinking this way?
                        Luc
                          Luc
                          Prove to us?
                          To the Florence event I explain how air as fuel work , I
                          present working prototype of stove and inside air burn in an plasma flame.
                          This technology can be used for run also an engine..
                          I have two patents been registered and the next month another two.
                          I have written sometimes the way.. instead to spent some time writing every same words I suggest to start real experiments.
                          • #14
                            Prove to us?
                            Instead to writing the same words I suggest to start real experiments.
                            Right ... I could of guessed where this was going!
                            You make claims that your circuit will run an engine but you want others to buy your circuit and do the experiments to find out if it works or not.
                            Well, sorry but I won't be the first in line to buy this. I'll wait to see the results first.
                            Hope you can find experimenters who are willing to do this and I wish them success.
                            Luc
                            • #15
                              Luc
                              Read better!!
                              My board is specifically designed for create hho gas and with heterodyne function ON saving more electric power.. for run an engine you need more..
