Stanley Meyer
  • #76
    Originally posted by tachyon View Post
    if there's plasma there's an electric field... if this theory is correct it can only happen with electric field..
    absolutely not.. plasma can be produced also chemically.. i have been explain that about..
    • #77
      if ions move in respect to each other then no electrino theory needed... plasma is ion movement...
      N2 AND H2O NEEDED... everything is the same..xwhat other catalysts can we use besides platinum ?
      The pure in heart will see the light.
      • #78
        Yes .. plasma is electrons and ions flow.. similarry to plasma cutter air use thermal energy instead electrical energy.. is difficult understand that? The catalyst agent is used for increase time of reaction and maintain stable in the time the reaction.
        • #79
          the catalyst ionizes N2 for coulomb repulsion to decrease in fact the nitrogen react with water not oxygen ,the only problem is the cost of platinum, need to find a unreactive metal that can ionize nitrogen to test if this is correct.
          • #80
            Is not correct. Water molecule is splitted by plasma and nitrogen is just the catalyst agent into the process. isn't standard chemical reaction. you must think differently.
            • #81
              its a plasma reaction.. meyer must have found this.. can you tell me what are the products of this process?
              • #82
                If you use water steam you obtain hydrogen, oxygen and some heat produced from conversion of nitrogen from molecular to atomic and viceversa.
                if you use other type of gas like CO2 you obtain CO, O3 and some heat
                nitrogen plasma is an catalytic agent able to split molecules
                • #83
                  how is the proccess started? nitrogen must have a net positive charge and the other compound opposite net charge right?
                  • #84
                    make experiments..
                    • #85
                      how do you charge water, show some photos
                      • #86
                        You don't have to charge water.. air plasma split simply the water!!!
                        • #87
                          does CO2 reacts being neutral? .. is this started by a spark??? the primary interaction must be between nitrogen and other compound.. and I don't see how this happens without them being charged at some point.. with the spark they get ionized momentarily...and move
                          • #88
                            Remenber that heat is the main catalytic agent of the process.. spark is nothing.. you need more energy..
                            • #89
                              in my theory charged molecules are needed...except if I take each proton and electron to be seperate entity.
                              • #90
                                when you have an bigger flow of electrons and ions to high temperatire you can obtain what you want. I have processed different molecules and all work fine..
