advice on engine rebuild
  • advice on engine rebuild
    the engine in my truck died yesterday, it seems that it's overdue for a rebuild. i was planning on adding some fuel saving devices to it, but now that it needs rebuilt i can start from scratch and try to engineer the thing for maximum efficiency. the question i have is what kind of modifications should i do to get the most i can out of the engine. the engine in question is a 4.3L 262ci in a 91 gmc c1500. i want to keep it reasonable as much as possible. i've found rebuild kits for $250 incl heads, before i commit to a certain kit i want to know exactly what parts to put on my list. any help would be appreciated.
    thanks in advance
    If you have money to burn check out the HHO link here - they do a $2600 system for engines up to 6-litres. He talks about 2-3 times fuel-efficiency, which if borne out and you make your living on the road, would pay for itself relatively quickly. Snazzy-looking kit, if nothing else.
      Engine Mods
      It depends on a number of factors? which systems or types of systems are you thinking of using.
      HHO: to what extent? Full water burn, you may want to teflon or ceramic coat a few things as well as an exsaust gas heat exchanger/condenser/re-circulation of some sort. You may want to add a dedicated alternator for your system?
      Geet: Lots of exsaust and intake mods
      Evaporative fuel/Carb: (Pouge) Again intake and maybe exsaust mods
      You said it's a 91, Don't forget your computer, it probably won't like most of the changes and some convincing with a soldering pencil or replacement with a programable after market maybe in order
      Good Luck and keep us posted
        The Pogue carburetor seems to be more myth than reality. Granted, there is a patent for it, but for something that supposedly was fitted to tanks during WWII by the allies, (also supposedly labeled as a 'non-servicable' part) there is zero evidence that it performed as the urban-legend insists. At least one guy tried & failed at a replication - not a shoddy replication-attempt either - and even Pogue himself refused to comment on its performance when tracked down and questioned about it when in a nursing-home.
        There was much more evidence for the Fish carburetor's performance, but that came nowhere close to achieving what the Pogue carburetor promised.
          Petrol engines need control over the timing of the spark. It will need to be advanced if you use a substantial amount of HHO.
          Another firm worth investigating is said to be connected with Bob Boyce, namely, Hydrogen Garage:
            Maybe-maybe not
            Sprocket: As far as Pouge go's I don't have a one way or another, yet in 1980 I built an evaporative carb based on the principals he used (supposedly), it was fitted to a Pontiac 400 ci firebird and it worked (kinda) testing got us in the 90+mpg range with a pile of glitches and problems that I never got to remedy due to shipped out to new duty station far far away.
            There is a huge amount of energy in hydrocarbon fuels, most of which is wasted and thrown out the tailpipe.
            I never went back to tinkering with the evaporative carb preferring to work in HHO and other types of alternatives as well as dealing with life's little curve balls.
            Problems: no acceleration, had to gradually come up to speed. Fuel build up in system, fire, fuel distribution on surface medium.
            Might be worth revisiting, in a different thread.
              Really interesting that you managed to get that high a mileage - much higher than even the Fish carb if memory serves. There are quite a few Youtube videos of engines running, but just sitting in the driveway for the most part. I don't doubt that the evaporation thing works - got a small engine running that way myself once - just don't see it as practical unless someone surprises us and starts selling evaporative carbs again. Manufacturers are kinda thin on the ground at the moment!
                Vaporized fuel systems
                Sprocket: Evaporative carbs I believe have their limits, although the
                Geet system reminds me of some of the designs we played with in early 80's.
                There are some other ideas I have on using the. Will start a new thread in renewable energy to discuss.
                see you there.
