Here is one booster method that ART has sent me...thanks!
See this post: http://www.energeticforum.com/renewa...html#post14763
Art's comment:
"my names art a newbie retired diesel mech had a little problem with web tv axcess but i think i got it worked out old school junk yard dog : ) i e mailed aaron telling him i have been making hyd boosters ..ive been monotoring this site for a month or so also been running two boosters on two vehicles 72 ford pu 3/4 ton v 390 appx 40% improvement on milage and 71 ford maverick 250-6 no specifics on the mav although about 10%increase in h.p.all of this is more noticable on top end cost to make $30.00 5 plate stainless walmart 1qt plastic container holding up well so far i cure olives with lye every year plastic bucket and i guess its called lexan holds up well the lye doesnt hurt it snapon cap..next project 99 buick century w/computer junk ...i had some anti foul adpts in the garage but they had a taper so i machined it flat w/my turet lath to seat properly also it was due for new oxy sensors at 97000 so i bought two one installed after the clataclismic perverter the other is behind the 3.1 eng waiting for good weather to complete instalation ...ran this by my local smog man it caught his interest said he would check with the snifer no charge ..the buick will get 30 mpg stock quite supprising.. also im going to treat the engs with xcelplus old name luberlon have used it before on my two hondas went from 34 mpg to 38 mpg with the luberon it works ...and hydroboost recommends it and sells it but the co is in virginia i call him today its pricy but it worth it at $29.00 for 12 ozs or case price of 12 at $21.00 per 12 ozs looking for input and idea exchange with any of you fine folks out there..... art"
Art sent me this:
"photos enclosed two boosters i just finished container is walmart sof ar holding up good everything else stainless plates ,flatwashers,allthread, i set them up -- + -- + -- 5 plates appx 2 1/2 by4 all insulators are common automotive hose cut to size 1/4 and 1/2 in i also decided to use a toggle switch 20 amp and old dodge resistors fromthe junk yard they varry in resistance its not critical but idealy youwant to cut the volts and amps anywhere between 2 and 4 amps makes decent hydrogen the idea is not to overload the alt ...also it runs cool and only add a half cup of water every couple weeks ....you want to get the plates as evenly spaced as possible for uniform hydrogen production space on mine slightly over 5/16 inch should be checked with ohm meter to make sure pos and neg arnt grounding to each other before you crank it up ..1 teaspoon of lye i use tap water though many recommend distilled ...used a 20 amp inline fuse in case bad things happen ...going into the top of the carb aircleaner my choice also a suitible check valve should be installed between eng and container in case of backfire for the plumbing i used 1/2 in black garden drip hose inexpensive the whole thing appx $35.00 to build ok to post on the forum if you like .....art hesperia ca"
Art's comment:
Art sent me this:
