Ok,
These kits are put together with Quality components from Fairchild, National SC, and Texas Instruments, NO Garbage Components like The "Kits" that are out there!
All of These Circuits Have Been Redesigned and Modified To Be Used For HHO Generation and Operation Of HHO
Boosters
Full EFIE Kit (Fuel Mixture Control) For One O2 Sensor $22.00 US
Used To Control A/F Mixture For Fuel Injected Vehicles
Includes:
1 Cut PCB (Just needs to be drilled) ADD $3 for additional board
1 Complete Set of Electronics
1 DPDT Mini Toggle
Please Specify Which Rotary Switch You Want
1 SP 6 Position Rotary Switch (For Complete Range)
or
1 SP 3 Position Rotary Switch (For 3 Preset Setting i.e. Power, City, Highway)
Full Dual EFIE Kit (Fuel Mixture Control) For Two O2 Sensors $40 US
Includes:
(2) Cut PCB (Just needs to be drilled) ADD $3 for additional board
(2) Complete Set of Electronics
(1) 4PDT Mini Toggle
(1) Double Pole 6 Position Rotary Switch (For Complete Range)
or
(1) Double Pole 4 Position Rotary Switch (For 4 Preset Setting i.e. Max Power,Power, City, Highway)
Full Pulse Width Modulator Kit $19.00 US
Used To Pulse Voltage/Current To Cell. This Prevents Run Away Current and Controls Temperature of Electrolyte
Includes:
(1) Cut PCB (Just Needs to be Drilled) ADD $3 for additional board
(1) Complete Set of Electronics
(1) 50A Mosfet
(1) Heat Sink (Heavy Duty Aluminum)
Full Hi Power Pulse Width Modulator Kit $24.00 US
* This Version is Capable of Driving 4 Off Board Mosfets
Includes:
(2) 50A Power Mosfet
(2) Heat Sinks (Heavy Duty Aluminum)
Add Additional Mosfets $6.00 US
(1) 50A Power Mosfet
Pre Drill Boards $2.00 per board
This is being offered "By Request" This is the most time consuming step, but for those who do not have access to the Proper Size Bits or Drill I will do these for you. It will add a day or two to your order.
This is the easiest way to offer Kits that way you only get what you need...
TIPS:
* Remember allot of these components are STATIC sensitive, so be careful!
** I know this isn't the most ECO Friendly route but use 60/40 solder if you can get it. It has a higher lead content so it melts faster. This will help the more inexperienced.
*** Check the tracks and pads on the PCB. If they are touching or close scrape between them with a small flat head screw driver. This can occur during tinning.
**** Practice with the spare boards first. Just practice until you get a nice little solder pad at each hole spot. If your boards have the Blue coating over the copper, just wipe it off with acetone, or nail polish remover.
Notes:
**If you can solder 2 wires together soldering a small PC board is NOT out of your capabilities....
*** I will also be throwing in spare boards so that you can practice soldering on the boards and get the hang of it BEFORE you attempt to mount the electronics.
Shipping VIA Priority Mail will be $5 for Domestic. International should contact me first to check....We are in the Houston, TX area (Pearland)
International Orders Via Priority Mail runs $18.50 if however you want me to send it via Plain Air Mail I will but it will take awhile plus there is no way to track it...
Anyone who wants these should send payment whenever they want to get these... I will only be ordering once a week on Wednesdays for the people who paid the week prior. I will not Stock Extra, I have no use for a bunch of components I might be left with.
Process:
Each Wednesday I will make orders for all received that week prior.
Each Saturday I will Make Boards.....
That following TuesDay I will ship out Everyones Order that was received that week before...
*So there should be only 2 to 3 weeks from the time you pay to the time you receive everything give or take a couple of days (Just in case my suppliers are out of stock on something and I must go to a different distributer, Rare But POSSIBLE).....
I just set up a Paypal Account Solely for this....This is also an email address you can reach me at anytime directly....
[email protected] <<<Use this for PayPal Payments as well as Contact via email..... Also if you need to speak directly to me call 832-860-6686 If I Don't Answer Leave a Message and I Will Get Back to You ASAP.
Lee Cribbs
Mira Cribbs
Boosters
Includes:
1 DPDT Mini Toggle
or
Includes:
or
Includes:
(1) 50A Mosfet
Includes:
TIPS:
Notes:
Process:
Lee Cribbs
Mira Cribbs
....I checked all of the kits before we bagged them, I guess that one slipped by.
