lean burn
T, with this ignition, and we still only used small capacitance and voltage, it ran much stronger being as lean as we could get it and with the throttle open. With the magneto, it did not run that strong even with the gas setting roughly halfway between lean and rich. Also, with the magneto, it was not as smooth.
Originally posted by tstorey
That is, if the cap is actually doing what the diode is doing. The other possibility is that the cap is too small, and that it charges up first, before the spark occurs, and then discharges across the gap in an accentuated spark.
In this case, there will be an optimum size in relation to the coil output.
