Emulsifying Brown's Gas
  • Emulsifying Brown's Gas
    Greetings All,
    I need input on this concept that has been nibbling at the back of my brain for some time. Please, any and all comments or ideas are welcome here.
    So many efforts.... all heading for the same goal...... running engines on water.
    For me, emulsifying Brown's Gas within a liquid... is an awesome concept.
    It is doable.
    It is, (imo) what em-Fuel has stumbled onto.
    I also believe, if we can crack this nut, this could help many of the current projects trying to run ICEs on water..... from plasma sparking, to vaporization and HHO, to small engine water projects.
    This concept, I would like to see developed open source.... my thoughts as to "how'd dey do dat?" will come .... but first I wanted your input(s).
    The below pic is from this site... notice what is being described... that sound exactly like they've trapped Brown's gas in micro bubbles.... ready for combustion and thoroughly blended throughout the liquid.
    Isn't that an awesome concept??? (or am I just tripping? )
    Micro Bubble Technologies
    Here are some youtube vids on the concept....
    50/50 ionized water / diesel emulsion in oil burner
    YouTube - water as 50% replacement for fuel
    40w/60d em-Fuel
    YouTube - New Em-Fuel
    MicroBubbleTech youtube site.... many vids here!
    YouTube - MicroBubbleTech's Channel
    one that Luc just posted
    50/50 Burn time demo...
    YouTube - 50% water mixed with 50% gasoline
    Excellent topic goldenequity
    What ever I can do to help please feel free to ask.
    @everyone, come on let's get the ball rolling,... it's time to rock and roll
    Oh...also, winter is coming and we want this working before!... right!
    Good one man I also just love the timing of it all.
    Luc
      Thanks Luc
      I'm glad you responded, I was actually thinking that you and others might be able to spearhead a simple experiment I had in mind.
      After doing some research and thinking on this
      Take a look at this video:
      YouTube - Ultrasonic Emulsifying of Oil in Water
      They are emulsifying oil and water using ultrasonics.
      To Luc and All who want to try to crack this nut.....
      My concept is to take a small 50ml beaker or baby food jar with oil and water and see if the emitter can put out enough mechanical energy to micro mix the solution.
      I would get really excited if it would.
      If not... perhaps someone experienced in hi powered ultrasonics can jump in?
      The next step would be to simultaneously electrolyze a brim full capped jar to generate brown's gas under pressure.... while running the fogger.
      If we could make and trap the gas.... we would be on the right road I think.
      I believe part of the reason the fuel mix stays emulsified is the ionization of the water through electrolysis.
      I guess the nice thing is.... this isn't theory.... they've done it.
      we just have to figure out how to do it in our towns and villages across the world.
        vapour or not to vapour
        this is also the intermediate direction before using 100% water, see - Rudolf Gunnerman: Water-Alcohol-Fuel Emulsion for IC engines: 25% + mpg. 2 Articles & patents
          Hi goldenequity,
          I looked at the video and also found this one: YouTube - water as 50% replacement for fuel
          and this one!...looks like the Japanese have been doing this for a while: YouTube - Em-Fuel Furnace Application
          I can keep going but most of them are Japanese.
          You know what I think ... I think this emulsifying is going on in the GEET bubbler! have a look: Panacea-BOCAF GEET Replicaiton
          Once I have my half geet plasma engine working we will know much more
          Luc
            wow.
            It's a well worn path.... seldom used.
            I have no idea why..... Hat's off to Gunnerman!
            thanks for that peteroks.
            The only thing different about this Japanese technique seems to be that they
            are electrolyzing the 50% water into Brown's gas during the process of emulsifying with the carbonaceous fuel(s).... in their case kerosene.... which is what I find so attractive and fascinating.
            Gunnerman describes the emulsification by both fluid dynamics using shear and votex as well as ultrasonics.
            The Japanese site states that they are indeed electrolyzing.
            Their results also indicate:
            that the emulsion is stabilized..... as I said previously, I believe that is due to the ionization of the water through electrolysis.... and that would seem to be a significant advance above just the shear or ultrasonic mixing alone as proposed by Gunnerman.
            Nice find.... let's do this.... HHO rocks!
              Same stuff..... different company (India)
              perhaps different process.... emulsified fuel!
              http://www.hydrodrive.co.in/HYDRODRI...TECHNOLOGY.htm
                The Nanomizer is the device MicroBubbleTech (Japan) uses in their emulsification process
                Here It is disclosed that they are electrolyzing water in the process! (aka Brown's Gas folks!)
                  emulsion fuel generally comes with loss of power
                  Seems the work around is to add burnable GAS to the mix.
                  "We made a different approach to emulsion fuel and solved the low calorific power problem that conventional emulsion fuel had."
                  "Energy-conversion functional water contains an abundance of dissolved oxygen and active hydrogen, thus, increasing the efficiency of combustion."
                  Link: FUKAI emulsion fuel "The world's first new energy source"
                  You'll maybe have to have more than just water and gasoline in the mix.
                  Air will enter into the mix during emulsion, maybe propane, hydrogen,
                  some gas to burn would probably be very helpful to the mix.
                    IS it real?
                    See Video:
                    WATER15% and 85% GAS NOT HYDROGEN HHO CFR JOE CELL
                    hand mixed water/gasoline works?
                      Hi Vortex thanks for the input...
                      the vid you posted is funny (if it wasn't so scary )
                      NOBODY should do this to their engine btw!
                      I have to agree with this little response video
                      YouTube - Re: WATER15% and 85% GAS NOT HYDROGEN HHO CFR JOE CELL
                      However, I'm glad you posted it because is shows why
                      a true emulsion process is necessary and certainly IS being done successfully..
                      and I DOUBT whether the FULL potential of what they're creating is being taken advantage of....
                      the fact that they're concerned with restoring the "caloric" value says to me that they are looking from the BTU lens regarding combustion..... which is wrong, wrong, wrong.... when it comes to exploding water and HHO.... heat is not what we'd be after with this fuel mix.....
                      (especially with a cold plasma spark inside a cylinder )
                      Thanks for your input again because you just got me thinking again about how this relates more and more to what we are finding out about HHO and plasma...... anything on this is helpful!!!!
                          Originally posted by Vortex View Post
                          See Video:
                          Vortex,
                          Thanks for posting the video link...
                          In that case I think the engine still running by gas alone, because the water in the bottom and the fuel suction line usually 10-20mm above below level. Would be good if he report his engine condition now..LOL
                          • #14
                            Nanomizer patent
                            Here is the link to the Nanomizer patent (thx to Wings/overunity.com for this!)
                            Method to produce the activated ... - Google Patents
                            • #15
                              Hi all,
                              I'd like to post couple of observations on the subject which I recently came across:
                              - The active element in the fuel IS water, and it is what burns and produces energy - see "Voda (Water)" Russian documentary on properties of Water and more. (Intention Media - Purposeful entertainment achieving global change , or on torrents)
                              - Relating to fuel in general, Peak Oil appears to be just a myth and nothing else - see Ian Crane's excellent lecture "Peak Oil" about it (up on torrents)
                              I know that most of you love to tinker with your cars and engines but anything to do with exploding things is a dead-end because that's not how Nature does things and it's really about time we stop pissing up the wind...
                              Whether you use petrol based fuel or hydrogen, you are still combusting things in our old combustion engines. We need to take a big turn away from it not just because it's not the "natural" way but also because by not doing so we are only playing into the hands of those who wish to maintain the status quo (if you can't charge for pumping it - it's not good for the business).
