Basic Electrolysis
Rosie
I've got to admit that I've not been following that thread, so I'm personally not in any position to comment on what you are doing with reference to the copper cylinder.
You have however got me quite intrigued, so I could be about to spend the next few hours reading through it from scratch.
Farrah
LOL Farrah - It's an old thread. Very well subscribed. You're looking at the closing chapters on the second thread. It's technology that has been proved - but not at a level that is easily usable. But watch this space. We're hoping to get our first application up and running. God willing. LOL. I'll let you know when we get something that we can use and prove - both.Originally posted by Farrah Day View PostRosie
Farrah
We're had set backs that you won't believe. Fraught but rather exciting nonetheless.
@Tim
Tim,Originally posted by chasson321 View PostNo, those two didn't discover anything, and call what they where doing passivation when it clearly is not. The main thing Bob, and others where doing is leaching out the metals that makes the water turn brown from the SS, not building up a coating on the metal. But Bob can speak for himself if he wants to, so you don't have just my word to go on, or you can look up passivation and learn for yourself.
Tim
Calling the coating process passivation with these water cell projects
was a reference to the actual chromium or other "plating" process for steel
that some people have done to their steel tubes for extra protection and
was originally NOT a reference to the white coating.
The white coating that I originally showed Ravi never had brown gunk
involved and anyone getting brown gunk is simply doing something wrong.
Most like that is from them using connections, bolts, or other metallic
pieces that are not stainless and submerged in water during the electrolysis
process.
The discovery that I made was the similarity to some of the battery plates
charged with Bedini's technology where a white coating formed on half
the plates where there was no calcium or magnesium involved. Those
coatings limit current so that the voltage potential could be cranked up
that were delivered to the batteries. It is a self-organizing and self-
repairing layer and from the tap water, I believe it is most likely calcium
AND magnesium. Being a natural current limiter, it is easier to stress the
water molecules even without using chokes.
Furthermore, each of my cells with the conditioning became PERMANENT 2v
electrets that could perpetually charge caps without killing that 2v dipole!
It does increase gas production from my actual experimental evidence,
which you seem to completely lack any evidence that you have done
anything other that act as h2opower's mouthpiece.
Please keep your uninformed opinions to yourself - you don't know what
I've done or what I haven't done.Sincerely,
white coating on tubes
Only a small percentage of people have developed the white coating whenOriginally posted by Farrah Day View PostThe passivation thing is of some interest for two main reasons:
Firstly, as stated in the link, it gets rid of any surface particles that may cause premature corrosion of the electrodes. (We have a stainless steel dogs water bowl that has a tiny point of rust just at one point, a tiny imperfection that leads to corrosion. Which goes to show that the protective chromium oxide layer can be breached even in undemanding environments).
Secondly, by virtue of preventing any corrosion it also obviously enhances the efficiency in that we are not getting unwanted reactions taking place and so sapping energy.
However, the question I've always been puzzled by is why this seems to work.
Oxide layers in general tend not to be very good conductors, but I expect that at mere microns, the oxide layers on ss and indeed aluminium are to a certain extent porous to charge exchanging. Irrelevant of their protective oxide layers, both aluminium and ss seem to conduct just fine, so I guess this must be the case.
The white layer that develops on the cathode when using tap water, I had always put down to being calcium carbonate, the same thing that gives use limescale on taps and in kettles, etc.
In fact I doped tap water with calcium carbonate and was able to build up these white layers on my ss cathodes very quickly. I was never 100% sure whether or not this actually enhanced my results, but I'm sure it went some way to stopping the leaching of iron from the ss.
Curiously, this white layer was a very good insulator. Using a multimeter, I was unable to get any resistance reading at all. Yet it did not seem to interfere with the charge exchange process at the electrodes. Again, this coating must actually be extremely porous on some microscopic level.
Ultimately, I decided that any gains in efficiency were miniscule, but that the coating might mean that the water contamination was much less of a problem, and for this reason alone made it worth pursuing.
I've attached a couple of old photos that show the build up that I achieved on the centre cathode in just a few hours with tap water doped with calcium carbonate. Though not shown, the white coating was also apparent on the -ve side of the floating plates.
Farrah
using tap water. I did it 100% of the time with my tap water but others
haven't. Some have added calcium carbonate, bone meal, coral calcium,
etc... as you have and it has worked to a point. My conditioning process
can be complete from start to finish in 1 day. If you were doing it with just
your tap water, then you have the right mineral content I suppose, but
I think there is magnesium in it too and not just calcium.
I found that the gas production does increase no matter how I powered
the cell with the coating versus before they are coated. There is also
probably hydrogen loading into half the plates/tubes. For me, the increase
in gas production was not only measurably more, it was visibly very
noticeable.
This is just one demo of the conditioned cells and only one cell is
connected in this vid:
YouTube - Stan Meyer concentric tube test
I reposted that vid on youtube in 2008 but it is actually a few years older
and the same goes for these other vids - youtube originally deleted 100%
of every video I posted so I had to get another acct.
YouTube - Water Fuel Cell Conditioning
how I conditioned 7 tube sets with less than 10 watts in one day
and no additives to the water - just plain tap water
YouTube - energeticforum's Channel
lack of conductivity
There are multiple threads in this forum discussing the coating.
Some that used calcium additives had clogged up the gap in their
tube sets.
My coating stayed the same thickness. Once it has the minimum
coating over the metal, it did not continue to build so water flow up
through the gap was never reduced.
Your findings pretty much corroborate everything I found but unfortunately,
so many people have problems getting that coating. And if it is even
desirable, I don't know but it worked for me and did increase gas
production substantially.Sincerely,
Aaron
Our tap water is known as 'hard' water due to its high mineral content, so I was also able to get the white coating build up from plain tap water.
Most of the minerals in our water come from limestone, which is of course primarily calcium carbonate, so I simply upped the calcium carbonate content to see the process greatly accelerate.
I did not do any in-depth before and after gas measurements at the time, so I'm not in a position to make any claims on gas outputs.
However, until my electrodes became coated, the water would continually and quickly become brown and scummy. And so it would seem to make perfect sense that if the coating prevents any unwanted chemical reactions of the electrodes taking place, that the process of evolving gases would naturally become more efficient.
This makes perfect sense too, as once the mineral content of water has been used up, the process would naturally halt. I would however expect the coating process to restart if you top up again with fresh mineral rich water. So once you have built up a suitable coating, the choice of water thereafter could prove to be an important factor.My coating stayed the same thickness. Once it has the minimum
I know that with the added calcium carbonate in my experiment, and the rate at which the coating was building up, that the spaces between my electrodes would have quickly diminished.
Farrah
Aaron
I discovered a similar thing and at one stage I was near to pulling my hair out as I could not understand how it could be happening.Furthermore, each of my cells with the conditioning became PERMANENT 2v
After electrolysis of only a few minutes, and before any coating had built up, I found that my cells apparently held a charge. But what I struggled to get my head around was the fact that I could not discharge this voltage. I assumed that simply shorting the two electrodes would achieve this, yet it did nothing!!
I took the electrodes out of the water and found that they still showed a voltage (I have it detailed somewhere). But still I could not get it to discharge... it was quite baffling. Not until the electrodes completely dried out, did the charges finally disappear.
I noted that the voltage was always less than the voltage required to initiate electrolysis, so concluded that once I powered down the cell and electrolysis ceased, ions would still remain on the electrode surfaces due to the attractive forces, but the potential difference was no longer enough to allow them to interact.
I experimented with this numerous times and the only way I could discharge wet electrodes was to physically wipe the ions off!
Very interesting, and at the time, a most puzzling thing.
Farrah
water cell electret effect
The only time I had any brown stuff - it wasn't from my tubes but was
from a non-stainless bolt in a worm gear that held the metal band around
the perimeter of all my tubes. It basically just that one screw that was
visibly rusting. I was using t304 ss tubes - but it seems L316 or 316L
ss tubes are supposed to be better but I've never used 316.
The electret effect can be used to charge caps, etc... without killing it
as long as you put that potential to something with very low impedance
like a capacitor. I turned some caps into electrets by charging them with
high voltage single wire transmission (longitudinal impulses). This self-running
oscillator I have a certain feedback method to put recovery from the back
to the front but the front side cap(s) were like the electret water cell that
can charge another cap without killing it's own potential difference.
This is the same as a solar panel. If it gives you 24 volts and you connect
it to a 12v battery, it will drop it's voltage greatly down to that of the
battery. But if the solar panel gives you 24v and you connect it to a cap,
you can get the full 24v potential from it. That is what makes Bedini's
solar Tesla Switch is that it makes full use of all the potential of a solar
panel since the cap is such a low impedance "load" that the solar panel
sees. So with the low voltage electret effect on these cells and caps,
you can charge multiple 2v caps in parallel and then switch them in series
to get a higher voltage punch out of it - if that is desired. Of course it
works best the better the coating.
Imhotep found the same electret effect with some capacitors he was
experimenting with. I've lit LED's by this method and it works but at the
time the switch that I was using took more power than the LED! So that
wasn't a good use of the output.Sincerely,
Heya Aaron,Originally posted by Aaron View PostTim,
process.
Have you had the coating examined? I would be interested if they are crystalline deposits?
Farrah, Aaron, and anyone who has or is testing with electrolysis, what are the levels of voltage you are testing with? I think a great test for any one with access to a mass spectrometer would be able to possibly measure if the increased voltage and increased length of tubes would produce an abundance of ionized hydrogen for the fact that hydrogen's ionization threshold is around 14V. Text books say 13.6eV. What are the ionization thresholds of oxygen and nitrogen? Is it possible to raise the voltage of the cell to at least ionize all the produced gasses from electrolysis? If we are able to ionize all of the gasses to some extent, how will that effect the water? I guess that's the angle I'm looking at it and I am trying to devise a decent test apparatus.
Farrah, I noticed you were testing with an ignition coil. What were you using to rectify the output?
Originally posted by HairBear View PostI'm sorry, maybe I should clarify that I was using an ion detector and not my nose to measure the 10 foot distance. Most corona discharge type ionizers emit a tiny amount of ozone as a byproduct of generating high levels of negative ions. However, the ozone output is actually less than .02 parts ppm, even within an inch or so of the ion emitter.Thank you both, they are valuableOriginally posted by Michael John Nunnerley View PostIn any gas in it's atomic state, whether on its own or a mix of gas will change to another state in 0.5-5sec, the difference is depending if there is another gas and its stability in relation to the secound gas, the longer time is normally when there is only one gas, but in the case of nitrogen, it is the quickest as it is the most unstable in its atomic form and the most difficult to put into it's atomic form, so that will give you some idea.
Mike
H2O dissociation by Dudyishev
This interesting information was found from Russian site:
Малозатратная электротехнология разложения Н2О. - НАУКА И ТЕХНИКА - Каталог статей - ЛИТЕРАТУРА ПРИДНЕПРОВЬЯ
HB
Actually HB, if you consider that most of us are attempting to only drop around 2v across any particular two electrodes, the overall supply voltage becomes somewhat irrelevant. So in most cases the hydrogen evolving never sees anything like 13.6V... if you see what I mean.Farrah, Aaron, and anyone who has or is testing with electrolysis, what are the levels of voltage you are testing with? I think a great test for any one with access to a mass spectrometer would be able to possibly measure if the increased voltage and increased length of tubes would produce an abundance of ionized hydrogen for the fact that hydrogen's ionization threshold is around 14V. Text books say 13.6eV. What are the ionization thresholds of oxygen and nitrogen? Is it possible to raise the voltage of the cell to at least ionize all the produced gasses from electrolysis? If we are able to ionize all of the gasses to some extent, how will that effect the water? I guess that's the angle I'm looking at it and I am trying to devise a decent test apparatus.
It's something I've never looked into as I always assumed that all the charges are used up at the electrodes and there would be no free electrons to ionise any of the resulting gases under these conditions. Good luck with your testing.
Incidentally the idea of the ignition coil was only to induce ionisation, but I assume the HV pulses to be dc anyway.
Aaron, at the time, with my electrodes holding a charge but my being unable to short out or even disperse this charge other than by physically wiping it off, I had not considered the fact that it could be used to charge a capacitor.
However, now you bring it up I'm re-intrigued by it.
Effectively I guess we have OH- ions sitting on the surface of the anode and H3O+ ions sitting on the cathode. So why doesn't shorting out the two electrodes allow the charges to exchange?
I think the answer might lie in the fact that either, only one plate is unbalanced due to the 2:1 ratio of evolving gases or unlike plates charged with electrons, the ions cannot easily react anymore to give up or take on electrons.
Whatever the case, if we have this static potential difference, whereby current will not flow, it makes sense that a capacitor across the electrodes will charge to the pd of the electrodes.
I say charge, but actually capacitors don't charge as often depicted, in reality all that happens is charge separation. But in this scenario how are charges separating if the static charge does not allow current flow?
I mean, a current normally flows in a capacitor from one plate to the other in order to produce this charge separation, yet our electrodes are only providing a source of potential? Unless that is, electrons in the electrodes themselves also are influenced.
Now, in this scenario, each individual electrode would be like a capacitor. We would have a static potential on the surface, the thin chromium oxide dielectric layer in between and then the metal electrode itself would be charged to balance the static charge potential. Now each electrode would itdself be electrically balanced, and even though one electrode with respect to the other would be more -ve, the unyielding static potential would not allow charge exchange between the two.
If we now put a capacitor across the electrodes, a flow of charges would take place between each electrode and one side of the capacitor. Hence we get a partially charged capacitor, though the total charge still balances the static potential.
But what happens when we then remove the capacitor?
In doing so we again create a charge imbalance on each electrode with respect to the static charge on the outside, so there would be an internal flow of charge within the electrode to once again balance the static charge.
How long we could keep doing this for would be interesting, and it certainly provides food for thought.
Farrah
Yeah, the capacitor charging with residual voltage is rather interesting isn't it?Originally posted by Farrah Day View PostActually HB, if you consider that most of us are attempting to only drop around 2v across any particular two electrodes, the overall supply voltage becomes somewhat irrelevant. So in most cases the hydrogen evolving never sees anything like 13.6V... if you see what I mean.
Farrah, I'm biting my tongue and really trying to hold back, but... Come on! Transformers don't output DC without a diode, even IST knows that... After countless posts of the name calling and condescending remarks to those that are not deemed "educated" in the world of Farrah Day, how could you miss such a vital yet fundamental of electrodynamics 101?
It boggles my mind how a person can build a simple 555 circuit and not understand simple transformer theory. And yet carry on in the manner that you have of an educated grandeur. You have become exactly what you have been complaining about, a clueless fool pushing assumptions and doublespeak enabling more confusion to the ignorant masses. How does it feel Farrah?
