Closed-Loop Electrolyser
  • Chris didn't disassemble it...he loaned it to another guy and never got it back. I know the details of why, and why getting it back is now not likely to happen, but am choosing not to say because it really isn't anyone's business.
    Chris is not particularly interested in hydrogen production. There are any of a dozen good reasons for that. One major one is that hydrogen embrittlement will destroy an internal combustion engine, so any practical solution will likely require external combustion. That increases the complexity considerably, and as a reasonably poor 28 year old, I seriously doubt he has the resources to tackle the problem.
    Contrary to assertions here that there is no chemical answer, it seems that John Kansius' experiments would suggest otherwise. The fact that only a couple have managed to demonstrate the effect doesn't invalidate the fact that pure EM energy can cause water dissociation in an ionic solution. Since that is an established fact, rather than questioning Chris Hunter's statements, you might should be questioning why you were unable to reproduce the effect.
    The point I'm trying to make is that there really is more than one question here:
    1. Is it possible to dissociate water via magnetism?
    2. Does that process deplete the water of its ionic content?
    3. Can it be done at an energy discount?
    I think Chris would answer yes, no, and yes.
    John Kansius proved at the very least yes, unknown, and unknown.
    Before I ruled it a failure, I would personally be trying to understand why I couldn't replicate the Kansius experiment with a strong magnetic field, because that should be possible. Only after replicating that much, would I move into evaluation of the last two parts.
    There is zero doubt in my mind that if I stuck a piece of copper wire in water, and subjected that wire to a variable magnetic field, there would be a point when that wire would have enough voltage induced in it to start electrolysis. The key would be rate of change of the field. Too slow, you get nothing, but beyond some threshold you would get gas.
    If you were to increase the number of wires while decreasing the length of each, it would still work, but I expect you would need to increase the rate of change. You could do that by increasing the field strength at the same frequency, or by increasing the frequency. As before, when you hit the correct threshold it would work.
    If that conductor were reduced to something atomic sized, I would expect that the rate of change would need to be extremely high. To do so would likely require both high frequency and high current. That is something that doesn't come naturally, especially for those not skilled in the art. From what I have observed around these forums...the questions asked about drive circuitry...it is obvious to me that most would struggle to build a full H bridge drive that can push current and frequency to the levels that might be required.
    Since an atomic sized conductor would probably not produce a coherent magnetic field, I'm not sure that Lenz would apply, or would apply poorly. That has very significant efficiency implications that might affect question #3. Additionally, since a magnetic field does not dissipate power, in the absence or reduction of Lenz, the use of high Q resonant circuits might make it possible to create the magnetic field needed with very little input power.
    Once the threshold was hit, I would expect the knee of the reaction to be very sharp, since quite suddenly 10 to the gazzillionth conductors would hit the voltage needed to start dissociation.
    While I can't vouch for Chris, I can come up with enough reasons that it might work that I'd cut the guy some slack...
    There are obviously questions that need to be answered, so why don't those of us who are interested in a fair evaluation, wander back over to the thread on OU, and return this thread to Farrah's capable hands.
    • Hi LtBolo
      Don't get me wrong here, I'm not - and never was - at all against the possibility of this working in principle.
      No, what I'm so irritated by is AlaskaStar's continued unfounded claims, lack of any real details and the subsequent bull**** that follows. It's the clever manipulation of the facts and the deceit that really gets to me.
      See, even this part of the story has more than one version - and it all apparently comes from the same source!!
      I ask you, if you had just discovered a way to dissociate a gallon of water in 10 minutes with 5 watts of power, would you, for any reason, 'not particularly be interested in hydrogen production'? The 'embrittlement issue' is simply another get-out-of-jail-free card he's playing.
      I for one have not said there is no chemical answer, I've put up a possible chemical reaction - I've just no idea if it is valid in reality. What we do know is that there has been no validated balanced chemical reactions to explain what is or could be happening.
      There should be some doubt in your mind here. Where would the ions be exchanging charges for a start? This will not work, nothing will happen.
      I think I cut him plenty of slack in our first encounter. I simply know how he works now, and I also know that he's not half as bright as he likes people to think he is.
      You should check the whole story out here:
      OUPower.com :: View topic - Magnetic Hydrogen Electrolyzer
      It's getting the answers to questions from the person - or persons - making the claims that becomes the frustrating part. The very people who should have all the answers, if not to the reactions occuring, at least to the build itself. Good luck with that.
      • Banned??
        Banning is Bull****!
        I did not know that!
        As you can see by LtBolo's post above,
        Nobodies been "outed",unless you know otherwise?
        I will ask Stefan to allow you access to Overunity.com.
        he's on vacation still!
        Your input would most definately be appreciated if this does indeed start to bear fruit.
        In the mean time if that does happen I will post here [briefly]
        or not if you prefer.
        Chet
        PS
        opposites attract!
        BE that change !!
        • Farrah
          Can you please try to Log in at Overunity.com
          I have noticed other members posting again that where involved in some nasty flame wars have returned.
          Thank you
          Chet
          Ps
          If you chose not to ,thats OK but I won't like it![that could be enough motivation all by itself for you not to]
          BE that change !!
          • From what I noticed from the older threads was that Chris tossed out an idea that he claimed worked for him. Then varying degrees of spatting caused that to degrade into hurt feelings and chaos. Did Chris owe anybody anything then? Does he now?
            Please understand, I am anything but Chris' or anybody else' groupie. Quite to contrary, I have a successful business (evil business...this is where everybody jumps down my throat) that I started over 18 years ago. My interest in any of this is a healthy balance between altruism and capitalism. If I see something that makes some sense, I'm interested. Do I care about petty egos and crap like that. Uh, hardly. Didn't get where I am by letting human nonsense get in the way, and the affirmation of random names on a forum full of crazies is not something that I need. My interest is financial well-being while helping human-kind solve some pressing needs.
            That said, I personally think there might be something to this when viewed as an extension of John Kansius' experiments. Chris is clearly not university educated and may not have a clue as to the whys and wherefores. That is irrelevant. Sometimes not knowing what's not possible is what makes it possible.
            I would also suggest that your value system may or may not be his. I completely agree with what you say...something this important should be pursued. He is a young guy working long hours living paycheck to paycheck in the Alaskan interior. I am a well-off businessman. From a purely Maslow perspective, we must see things differently. I am sure that at other times of my life I would have seen this differently. Even if I did understand the importance (probably wouldn't have) I would likely not have had the resources for it to matter.
            Do I believe? No. Can I build a case why it might be true? Yes.
            Originally posted by Farrah Day View Post
            Hi LtBolo
            Didn't say anything about ions. I said a length of copper wire. Last time I checked copper wire generated current when subjected to a varying magnetic field. If that fails to work, transformers will cease to work, and I feel pretty good about them continuing to work.
            If the wire is long enough and the field changes rapidly enough, the voltage induced at the ends of the wire will be high enough to dissociate water. I assume that process will scale down if I cut the wire in half. Try that again a few billion times. At what point does it cease to work?
            That in itself wouldn't be the slightest bit interesting...except...when the conductor becomes so small that a coherent magnetic field cannot be produced, it might...might...confuse Lenz. If so, it might...might...be possible to produce the effect at a considerable energy discount. Given that Kansius demonstrated something dangerously close to what we are describing, I think there is a strong enough case to warrant further investigation.
            Until and unless you can recreate Kansius results via magnetic induction, I think the rest of the discussion is somewhat academic. After doing so...and since RF is just EM it should be possible...then reasonable discussions of questions 2 and 3 should be pursued.
            • Didn't say anything about ions. I said a length of copper wire. Last time I checked copper wire generated current when subjected to a varying magnetic field. If that fails to work, transformers will cease to work, and I feel pretty good about them continuing to work.
              You also didn't say anything about an electrolyte - you only stated water, hence my observation. Voltage alone will not dissociate plain water into hydrogen and oxygen no matter how long you go at it.
              Are you talking about an electrolytic solution? If so you then of course have numerous ion species.
              All these things have been tried, experimented with and considered in the past. Which is why when someone like AlaskaStar claims to have discovered the 'Holy Grail', so as to speak, it is so important to know the specifics. The devil is in the detail, and the details won't be forthcoming - as you will no doubt in time realise. Certainly, he owes no one anything, but why state these things and open source in the first place if you're not prepared to back it up with details? If he had dissociated a gallon of water in 10 minutes with 5 watts as he claimed, then he of all people would have immediately realised the significance of his discovery, and consequently dropped everything else to develop it. The fact that he did not do this, I think that says it all.
              Too much is wrong with the whole business, too many gaps, too many excuses, to much deception, which is why unlike yourself and others, I have no doubt whatsoever that he never did what he claimed.
              Someone might eventually crack it, but it will be with no thanks to AlaskaStar.
              Anyway, good luck with the wild goose chase on Overunity.
              • Farrah
                "The devil is in the detail, and the details won't be forthcoming - as you will no doubt in time realise."
                HHMMmm.............
                Are you talking about alaskastar or yourself?
                That raw data "open source" thing,you know where you share and save others the horror of your failures!
                Again sorry but your hypocracy is "Blinding"
                Chet
                BE that change !!
                • Originally posted by RAMSET View Post
                  Farrah
                  HHMMmm.............
                  Chet
                  Chet, whatever is the matter with you? Stop being so bloody childish - it's like conversing with a 12 year old - you're not 12 are you?
                  AlaskaStar is the one who made the claims... NOT ME!
                  Why aren't you simply badgering him - or Oswaldonfire - for the full details? That way you can faithfully replicate a fully working model that dissociates a gallon of water in 10 minutes, and forget all about my failed attempts.
                  You yourself never actually do anything in practice though do you? You never actually bring anything to the party... do you? You make countless pointless posts and expect everyone else to do the work for you. You're simply a Cheer Leader.
                  You know, I'd forgotten just how irritating and annoying you can be.
                  • Farrah
                    Sigh...............
                    Don't you see Farrah, if I can't provoke you into providing your raw data, then that's because you can't.
                    So with that I'll take my childish 12 year old lazy ass out of your
                    world of anonymous,slanderous, double standards .
                    Back to the sidewalks of OU.com
                    Chet
                    BE that change !!
                      Chet
                      Yeah, go back to your playpen Chet. We have our quota of mindless idiots. Good riddance!
                      • Farrah,
                        Mindless idiot or not,
                        It was just the Truth I was after,I'm told it sets you free!
                        If I didn;t Know any better ,I'd sware you where tryin to hurt my feelins [sniff]
                        Chet
                        BE that change !!
                        • LtBolo
                          I've noticed that Oswaldonfire has set up a replication thread over on Overunity.com. This I find a little curious in itself as the very term 'replication' surely suggests that someone actually has something to replicate in the first place. You would normally replicate an experiment in order to substantiate the findings... would you not?
                          So where is that something? What exactly do you guys intend to replicate?
                          As far as I can tell there is no working model to work from - so in reality, nothing to replicate. It's hardly a replication if you are all simply going to construct variations on the theme and experiment with them.
                          I'm not saying that experimentation is not the way forward, but the term 'replication' is lost on me.
                          • Farrah,
                            More in line with the original purpose of this thread. Have you looked at Andrija Puharich's patent for Water Decomposition by AC Electrolysis? Interesting read... Patent PDF
                            • Originally posted by iquant View Post
                              Farrah,
                              Yes, I'm aware of that patent, but the sparkplug looking device (component 2?) is not easy to replicate, and the electronics, being only blocks, are not clear.
                              Incidentally, I see things are going pretty well the way I predicted over on the other forum. Perhaps now, thanks to LtBolo, people can see why I was so negative and why it is so important that the person - or persons - that originally made the claims need to provide full details of their set up.
                              I pm'd LtBolo here, but not sure he looks in, so if you could let him know I'd appreciate it.
                              • Farrah,
                                This relatively new patent published 6/17/2010 for electrochemical energy storage and discharge is very much inline with your hypothesis.
                                WO/2010/066025
