My article on free energy. Meyer, Gray and Puharich explained.
  • My article on free energy. Meyer, Gray and Puharich explained.
    Hi all,
    During the past couple of years, I investigated many of your posts and tried to figure out what was going on. What I found out is that when you look at the dirty details of what we know as electricity, it is the electric field that really powers our circuits. While it seems like we convert mechanical energy into electrical energy by turning the shaft of a generator for example, in reality it is the electric field that powers our circuits. And because the electric field is the real energy source that powers all electrical circuits in the Universe, we can use that energy source for free, if only we manage to find the right tricks to do it.
    With this knowledge, I investigated three independent inventions that claimed to be able to power cars seemingly out of nothing: Edwin Gray's "fuelless engine" and the "water powered cars" by both Stanley Meyer and Dr. Andrija Puharich. To my own surprise, I discovered they all used the same basic principles to extract power from the electric field itself, principles that can be explained from the bottom up without any difficulty using nothing but hard Electrical Engineering theories.
    With the work of Professor Turtur, we know for certain that the electric field is a clean energy source that is free for the taking. We also know now how three independent inventions, of which two have been shown to work in public, used this energy source using the exact same set of tricks. So, either all three inventors were incredible frauds, or my theory explains how they did it.
    So, I have started to write an article about what I found out:
    Article:Free Electric Energy in Theory and Practice - PESWiki
    The conlusions so far:
    Based on my analysis of the systems built and demonstrated by Gray, Meyer and Puharich, I came to the conclusion that the basic principle is that you decouple load circuitry from driving circuitry in an unusual way, using a rectified carrier wave. By making sure that any frequencies the load circuitry may create are much lower than the carrier frequency, you separate the frequency bands wherein driving circuit and load circuitry are operating. Once you have done that, you can use a simple high pass filter to completely decouple load circuitry from driving circuitry in that sense that virtually no current goes back and forth between driving circuitry and load circuitry. So it's in essence a separation in the frequency domain combined with a high-pass filter trough which only the HF electric field from the carrier wave can pass. No charge carriers are actually exchanged between driving circuitry and load circuitry.
    The basic theory for this is Tom Bearden's "don't kill the dipole" as described in this article. Basic conclusion of that: the electric field comes for free. Potential (voltage) comes for free as long as you don't influence the charge carriers that create your dipole, your voltage source. In the analysed systems, they all excite two inductive loads in series. Gray excited both terminals of the load train in phase, while Puharich and Meyer did this out of phase. This explains why Gray most likely used bifilar wound coils. To understand the basic principle, it is perhaps best to think in the line I have been following towards the solution of this mistery, which is as follows.
    When you resonate an open coil in full wave resonance, you get high voltage, zero current at the terminals, in phase. So there you have the basic connection to using the voltage source for free, but you have to figure out a way to do that without disturbing the charge carriers that give you the voltage source.
    With a single coil, the current stays inside the coil, so you can't use that. So, when you split the coil into two, you get the current in the middle for free, provided you don't disturb your voltage source, your driving circuit. So normally, when you use the current, you will disturb the resonance, which will eventually also disturb your driving circuit (because it is somehow coupled with it), so you still have to provide current to keep the system in resonance and pay the price.
    And here's the trick: the driving signal is delivered to the coil on top of a half rectified carrier wave, which is fed into the circuit trough a high pass filter. Because the carrier is half rectified, you basically "touch" the coils into one direction, so you don't get any HF in there.
    That way, you get the current and the power, but the disturbances caused by using the power, cannot reach the driving circuit, because of the high pass filter! And then you finally got what you want. You can use your voltage source, without disturbing it, so then you don't have to pay the price.
    Once you have that clear, you can also imagine that you can drive this principle much further. As long as you make sure you have a proper decoupling between driving circuitry and load circuitry, you can most likely get by without driving the load train into resonance after all. At this moment, this still has to be experimentally verified.
    If you would want do go beyond what these three did, the final trick would be to drive two identical loads in opposite phase, so the whole system is perfectly in balance and in resonance.
    Since this stuff is being discussed all over the place and my thread on "the ultimate secret" is groing into something like a "food for thought" thread, I thought it would be a good idea to start a new thread to focus on the discussion of the theories I explained in my article.
    Any feedback, suggestions, etc. is welcome here. It is my intention to work further on this stuff the "open source" way, according to Linus's Law:
    Given enough eyeballs, all bugs are shallow.
    A.k.a. "Release Early, Release Often." - See: http://www.catb.org/esr/writings/cat...r/ar01s04.html
    Just updated the article with a piece on Meyer.
    Enjoy!
      Just a quick suggestion.
      Clean up your hand drawn photos, take out a ruler, and make some nice straight lines! This makes for a more visually appealing presentation.
        Great Job!!!
        You are doing a great job!!! Thanks so much for putting all this together.
        Enjoy!
          lamare,
          I have a question. You spoke of open ended quarter wave coils in your paper regarding them having high current at one end and high voltage at the other. Do you know any way of calculating these figures for designing an appropriate coil, or some rough formulas to give me an idea. Basically for a given input power how thick of conductor does the base need to have and how thin can the top conductor be is really what im trying to figure out. Probably not an issue with small designs but i have a larger project in the works and wire is not cheap, want to spend my money wisely. Would be really appreciated if someone knows anything about this.
            Will do at some point. At this point I am focussing on the contents. I can draw and scan a sketch in 5 minutes like this. When I want to draw the same sketch on the computer, it takes much longer.
              Web Design, Photo Editing and DTP software | Serif – Inspiring Creativity
              For me it takes the same time to draw and post in JPG with Serif as it did before to hand draws, scan and post. Better still your drawings is always ready for your own reference and very easy to do modifications on later stage.
              Thanks for your methodical presentations; which more people will place all their posts in such order! MUCH appreciated!
                Originally posted by cody View Post
                lamare,
                At this moment, I can't give you much detail.
                However, the oscillator coil/transformer (as f.e. used by Dr. Stiffler and Slayer in various configurations which give you some typical values) most of all needs to deliver the voltage (electric field) to the load coil/transformer in order to drive that one into resonance. In the ideal, theoretic, situation this should not draw any current from the oscillator, but in practice it will have to deliver some current. If the oscillator frequency is sufficiently high, say 10 times higher then the resonance frequency in your load transformer, then the load seen by the oscillator is dominated by the self capacitance of your load transformer. So, at sufficiently high frequencies you can neglect the inductance of your load coil/transformer, as I have shown in this picture about Grays spark gap oscillator:
                So, your oscillators load at HF is then formed by the couple capacitor and the self capacitance of your load coil/transformer in series and therefore it has to be capable of charging these. And this load also influences the resonance frequency of the driving circuit....
                By the way, I'm beginning to doubt wether or not you absolutely need a couple capacitor, because the coils act as HF chokes too, so that may be enough to keep LF junk out of your oscillator.
                These papers give some formulas how to calculate/measure the self capacitance:
                It would probably be best to start with your output transformers and design these as you would normally do, or just take two standard power transformers. Then, you need to figure out what the inductance of the primary is and what the self capacitance seen from there is.
                Here is a procedure to measure the inductance:
                Untitled
                Measuring Inductance
                Once you have that, you can determine the capacitance by finding it's self resonance frequency, for example using it as the oscillator coil in Slayers circuit. Since f = 1 / (2 * pi * sqrt( L * C )) you can calculate C.
                Once you have that, you can design your oscillator coil.
                Of course, you are free to do whatever you like, but at this moment it may be a good idea to start with a low power proof of concept using stuff you have laying around or cheap stuff as much as possible, as I intend to do myself when I have some time. Slayers oscillator does not need big investments nor do two identical standard power transformers. I think it would already be a real big deal if someone were to power, say, a 10 W car light bulb while inputting may be 100 mA at 12 V to the oscillator.
                So, my advice would be: don't spend much money on big stuff just now, but try to get something small working first. That not only saves you a lot of money, but that way you can afford to experiment and make mistakes.
                Here is a online calculator for calculating some values of air-core coils:
                Inductor Designer / Calculator
                Calculators for Electronics
                Some more articles on transformer design:
                Electronics/Transformer Design - Wikibooks, collection of open-content textbooks
                Producing wound components
                This one mentioned one thing specifically, and that is "self resonance", which is what we intend to use as much as possible, even though
                Self resonance is the term used to describe the way in which the electrical characteristics of wound inductors deviate at high frequencies from that of an ideal inductor. The reactance of an ideal inductor increases linearly with frequency.
                The practical inductor model includes a capacitor in parallel with the ideal inductor in order to represent stray capacitance between each turn and the turn next to it. There will also be distributed capacitance to any core that is used, and an exact model is too difficult to derive.
                The consequence of this stray capacitance is that at some point (called the self resonant frequency) the impedance of the inductor will reach a peak. At higher frequencies the stray capacitance will become dominant and the impedance will begin to drop.
                If you are deliberately using the inductor as part of a resonant circuit then it is important to note that the Q factor of a self resonant circuit is generally not high. Better values of Q can be obtained by choosing a smaller value of L and adding external capacitance to tune it. This behaviour is the reverse of that predicted by the simple formula for Q.
                Let me add one more thing: this is an adventure and anyone that feels like it, can be part of it. I know my article is not perfect yet and there are details that are either missing or even plain wrong. But, I am convinced the basic stuff is correct and will lead to results. The same kinds of results Gray, Meyer and Puharich got. So, it ain't a piece of cake, but we will get there and change the world for the better by working together and solve the issues that still have to be solved one by one. To me, that means starting as simple as possible. So, while I have no doubt that eventually we will be able to actually design WFC systems like Meyer and Puharich's, there are a lot of details in the design of the WFC that make this a complex undertaking. So, I think the first thing to aim at is to get this idea working as a proof of concept:
                This should not be too hard. The Stiffler / Slayer oscillator is well known and it should be easy to combine that with Puharichs modulator. Identical transformers can be had for very little money, for example by ripping them out of cheap battery chargers, mains adapters, etc. Once we have a proof of concept of this, the ball will start rolling and then we can scale things up and also work on driving WFCs.
                Update:
                For a first proof of concept, all you need is to switch the exciter on and off using a function generator or a 555 timer:
                This way, it should be pretty easy to see wether or not this works and wether or not you need a couple capacitor, or that the coils themselves provide sufficient filtering.
                  @ Lamare
                  some interesting documents for your collection :
                  Index of /krscfs
                    Originally posted by wings View Post
                    @ Lamare
                    Index of /krscfs
                    Are these yours?
                    If yes, can I post them at my site?
                      Are these yours?
                      not from me.
                      are directly from Kenneth SHOULDERS site / ftp
                      his work:
                      Ken Shoulders' Electrum Validum
                        Wikipedia
                        Edited the article on Stan Meyer over at wikipedia:
                        Stanley Meyer's water fuel cell - Wikipedia, the free encyclopedia
                        Will be interesting to see what happens...
                        Removed within a few minutes.. So, just re-added it
                          Hmmm...
                          "Since this stuff is being discussed all over the place and my thread on "the ultimate secret" is groing into something like a "food for thought" thread, I thought it would be a good idea to start a new thread to focus on the discussion of the """""theories""""" I explained in my article."
                          Theories are food for thought not facts.
                          Hmph.. Ok then what exactly is this thread?
                          "So, I think the first thing to aim at is to get this idea working as a proof of concept:"
                          Meaning based off of the "Food for thought" you provided.
                          If I digressed from the original thread then all you would have said was thank you but this thread is my version of the "food for thought". I would have understood and backed away and let you fling your food for thoughts around with no additional input. Which by the way you asked for input...
                          "Let me add one more thing: this is an adventure and anyone that feels like it, can be part of it." Obviously this is not the case....
                          • #14
                            Well, there's theories and theories. I'm all in for discussing theories like hollow earth, ufo's and whatever. That's what I call "food for thought", thinking about the unthinkable, no matter how far out it may seem.
                            The theory presented in my article and this thread is aimed at explaining and reverse engineering the stuff built by Gray, Meyer and Puharich and combine that with Stifflers and others. So, this straight out practical theory and engineering.
                            • #15
                              Just read this and you will see...
                              "Experiments with Alternate Currents of High Potential and High Frequency"
                              Everything is there including one wire transmission. I would have to say instead of using the uncompleted experiments of guys like Gray and Meyers that one reads the works of Tesla. They were in fact based on his original works. If anyone had it right then it would be the one most familiar and most versed in that area.
                              Even Tesla didn't have all the answers but he goes to great lengths to make sure that observations = experiments. If he didn't know the cause or couldn't then he experimented to see if it could be replicated. If it could, then he devised another experiment to see if it was a common thread. I believe that his final experiment was a proof of concept power system, The Peirce Arrow car experiment was that proof.
                              Like all good experimenters, one experiment fed the other. And finally he figured out the right combination to extract the energy he required. It is all related and one needs to follow his discoveries from beginning to the end with each experiment influencing the other.
                              Lets take for example when he figured out that the radiative event flowed like a fluid over the conical coils he designed. He discovered that the medium was actually rigid and when properly stimulated that the charges were the fluid. The coils when checked had zero current flowing in them but there was still a flow outside of them and that flow was mighty powerful or highly charged. This made him think to start experimenting with fluids to learn the laws that would allow him to take advantage of that flow. The Tesla turbine was born. This was only a test to see if a flow could be harnessed in such a way as to not interrupt the flow but still gain the advantage of motion from that flow. If one compares the one wire experiment in the reference that I provided you would see that it is directly comparable to the Tesla turbine.
                              This showed him that the rigid part of electrical flows is only an attractor of the flow that builds out from the radiative source. This allows virtual connections like roadways to form and collect charges which were the fluid component twords that source. Was he wrong about the radiative event? no it only showed him that what we thought was one component was actually two components. An action, reaction event. Voltage leads current because the potential must establish the connection for current to flow in.
                              You are right though about the flow going outside of the conductor and thats where resonance comes in but that depends on the ambient potential in the conductor. Think of it as a plasma conduit with zero resistance with the wire being the attractor of that conduit making sure it does not return to the environment.
                              I would also think that you are correct about modulating a signal on top of the base potential and I think that is how Tesla did it as well. With a driving (discharging) layden jar feeding a larger oil filled layden jar with inputs and inductive outputs. <Thats the oil filled transformer he used. This would allow him to have a standing potential that could be modulated like you suggest. This works on the same premise as another person talked about when you hook a magnet to a coil. The magnet raises the force that it can use to swing the output higher, weathger or not this is the case it should be looked into. I don't know all the details on that experiment and should be looked at substantially to see if an advantage can be seen there as well. I think if one looked at the magnet one would have to agree that there is a standing potential that could be used to raise the force we get out of a coil and core. Since the magnet is a source of potential created in the process of an electric field it locked that potential into it's structure and maybe used in a novel way to amplify the normal output of a coil core setup.
