about NH3..
The first point is that NH3 is created inside Gas Processor because you need an high energy source for creation of nitrogen in atomic state. Probably when ammonia burn inside chambre of combustion reform an little amount of NH3 but the high amount needed for engine is created inside GP. The second point is that probably Meyer use copper resistor for absorb oxygen (CuO) from air and sent only nitrogen molecular inside GP. Sometime ago I have been written about that in other thread. Artinvegas an your Reply is appreciated.
Ok if you are sure that Meyer don't use resistor copper for eliminate oxygen must use other method because for generate ammonia NH3 you need nitrogen; also you need enough energy source for ionized nitrogen and transform in atomic state and NH3 is surely created inside Gas Processor.
You have sent to me the web link of resonant cavity unit.. See my attached dbd pdf file, in fact resonant cavity unit is an dbd reactor!
Sorry but I think process is an little different.. Meyer process water from liquid to gas state using STEAM RESONATOR and RESONANT CAVITY UNIT (DBD REACTOR), after sent water gas inside GAS PROCESSOR mixing with air, after that GAS MIXTURE is sended to injector that in fact is another RESONANT CAVITY UNIT (DBD REACTOR). Inside that the mixture (watergas and air) is processed and transformed directly in NH3/N2O; burning with only 0.07mJ produce the thermal explosive energy asked from Meyer.
