GEARTURBINE PROJECT / Atypical InFlow (Fueled) Thermodynamic Technology - ROTARY
  • GEARTURBINE PROJECT / Atypical InFlow (Fueled) Thermodynamic Technology - ROTARY
    Innovation Technology Concepts - Atypical Type Projects / Carlos Barrera
    YouTube Video/10.30 min.; Atypical New * GEARTURBINE / Retrodynamic = DextroRPM VS LevoInFlow + Ying Yang Thrust Way Type - Non Waste Looses
    YouTube - ‪Atypical New*GEARTURBINE/Retrodynamic=DextroRPM VS LevoInFlow+YingYang ThrustWay Type-NonWasteLooses‬‏
    *8-X/Y Thermodynamic CYCLE - Way Steps:
    1)1-Compression / bigger
    2)2-Turbo 1 cold
    3)2-Turbo 2 cold
    3)2-Turbo 2 cold
    4)2-Combustion - circular motion flames / opposites
    5)2-Thrust - single turbo & planetary gears / ying yang
    6)2-Turbo 2 hot
    7)2-Turbo1 hot
    8)1-Turbine / bigger
    Gearturbine; atypical fueled turbine engine, state of the art. New thermodynamic technology. Turbo-Rotary / Top system.
    -With Retrodynamic dextrogiro vs levogiro phenomenon effect. / Rotor-RPM VS InFlow / front to front "Collision-interaction Tpe" - inflow vs blades surface/(gear). Technical unique dynamic motion mode.
    -Form-function (flat) wide cilindrical shape / continue kinetic inertia, positive tendence dynamic mass motion. The rotary motor weight is going with the the circular motion power thrust.
    -Non-waste parasitic looses system for: cooling, lubrication & combustion.
    -Combustion 2Two (Inside dynamic) continue circular flames (like 2two opposite rockets, (at the same axis)).
    -2 Two (very) long captive compression inflow propulsion conduits. start at were ends, in perfect shape balance.
    -4 Turbos (rotary & translation motion) inside active.
    -Mechanical direct 2two planetary gears thurst, inside in a bigger shell, total lever, polar position. (Big torque) (like the Ying Yang simbol concept).
    -3 stages of inflow turbo compression before combustion; 1)1-Turbine, 2)2-Turbos 3)2-Turbos.
    *The most innovative power plant motor engine project today. Higher efficient % percentage. Next trend wave toward global technological coming change.
    Patent; Dic 1991 IMPI Mexico #197187 - Carlos Barrera. - Individual Designer - Inventor and project owner. / All Rights Reserved. - Monterrey, NL, Mexico.
