Breaking free from the ferrilens.
  • #31
    • #32
      • #33
        Oh dear.
        Looks as if the ferrocell guys have fizzled out!
        • #34
          • #35
            Wiki.
            The basic principle that allows the device to operate is the fact that a caesium atom can exist in any of nine energy levels, which can be informally thought of as the placement of electron atomic orbitals around the atomic nucleus. When a caesium atom within the chamber encounters a photon from the lamp, it is excited to a higher energy state, emits a photon and falls to an indeterminate lower energy state. The caesium atom is "sensitive" to the photons from the lamp in three of its nine energy states, and therefore, assuming a closed system, all the atoms eventually fall into a state in which all the photons from the lamp pass through unhindered and are measured by the photon detector. At this point, the sample (or population) is said to be polarized and ready for measurement to take place. This process is done continuously during operation. This theoretically perfect magnetometer is now functional and so can begin to make measurements.
            • #36
              • #37
                Understand
                This seems to be important as far as the case for ferrocell goes.Magnetic anisotropy is the directional dependence of a material's magnetic properties. The magnetic moment of magnetically anisotropic materials will tend to align with an easy axis, which is an energetically favorable direction of spontaneous magnetization. The two opposite directions along an easy axis are usually equivalent, and the actual direction of magnetization can be along either of them (see spontaneous symmetry breaking).
                • #38
                  • #39
                    Magneto receptor
                    Cryptochrome.
                    • #40
                      Good find.
                      • #41
                        Come on you guys.
                        Come on you ferrocell guys, break free from a tiny round thing with
                        multiple LEDs and look at the bigger picture.
                        Do something more scientific than a gimmick, you don't need loads
                        of lines on a postage stamp size.
                        Look at how far a tiny magnet's effect reaches. What's needed is a
                        super size lens, the smallest magnet that works and a single light
                        source.
                        What I'm seeing from bigger lenses is a series of concentric
                        circles and if they were "filled in" you'd end up with a flattened
                        cone like you see with Mike Palazzola's latest offering (viewed pole end on).
                        John.
                        • #42
                          violation
                          n 2011 the OPERA Collaboration published (in a non-peer reviewed arXiv preprint) the results of neutrino measurements, according to which neutrinos are slightly traveling faster than light.[165] The neutrinos apparently arrived early by ~60 ns. The standard deviation was 6σ, clearly beyond the 5σ limit necessary for a significant result. However, in 2012 it was found that this result was due to measurement errors. The end result was consistent with the speed of light,[166] see Faster-than-light neutrino anomaly.
                          In 2010, MINOS reported differences between the disappearance (and thus the masses) of neutrinos and antineutrinos at the 2.3 sigma level. This would violate CPT symmetry and Lorentz symmetry.[167][168][169] However, in 2011 MINOS updated their antineutrino results, reporting that the difference is not as great as initially expected, after evaluating further data.[170] In 2012, they published a paper in which they reported that the difference is now removed.[171]
                          In 2007, the MAGIC Collaboration published a paper, in which they claimed a possible energy dependence of the speed of photons from the galaxy Markarian 501. They admitted, that also a possible energy-dependent emission effect could have cause this result as well.[50][172] However, the MAGIC result was superseded by the substantially more precise measurements of the Fermi-LAT group, which couldn't find any effect even beyond the Planck energy.[47] For details, see section Dispersion.
                          In 1997, Nodland & Ralston claimed to have found a rotation of the polarization plane of light coming from distant radio galaxies. This would indicate an anisotropy of space.[173][174][175] This attracted some interest in the media. However, some criticisms immediately appeared, which disputed the interpretation of the data, and who alluded to errors in the publication.[176][177][178][179][180][181][182] More recent studies have not found any evidence for this effect (see section on Birefringence).
                          Search for Lorentz violation.
                          • #43
                            From Wiki Lorentz.
                            • #44
                              See how.
                              See how it wants to make a CIRCLE!
                              John.
                              • #45
